Question about Singer 5050 Mechanical Sewing Machine
Start/Stop button light red
I just got a singer 4166.  I threaded the machine and was ready to use it, however when I put the presser foot down, the red light on the start/stop button comes on and beeps rather than sewing.  The up/down button beeps rather than working as well, the foot pedal too when I tried to use that.  It's green and looks ready to go until I put the presser foot down.  I made sure the bobbin thing on top of the machine was in the proper place, and it STILL WON'T WORK!  Am I missing something, or what else could I be doing wrong?!?  Any help is GREATLY appreciated!
  • 155 Answers
SOURCE: Singer 6217C Bobbin Thread bunching
please check out this link
http://sewvacdoctor.com/cate.asp?categoryID=6#1082
goodluck
 thanks.
Posted on Oct 26, 2008
SOURCE: Hand Wheel Won't Turn
The "Bobbin stopper" is in the incorrect position. It moves from side to side in a switch like motion. In one direction, it locks up the machine. That is, you can turn the wheele backwards, but not forward.. The bobbin stopper can be found in the book that cam with the machine. In our book, it is item #9.
Posted on May 01, 2009
SOURCE: Singer Pixie - trouble threading bobbin
look at the bobbin direction. if it dont pick up that way, change the direction
Posted on Jun 26, 2009
Mongo32
  • 111 Answers
SOURCE: Singer 8280 bobbin thread not taken up by needle
needle in backwards?
Posted on Jul 08, 2009
  • 192 Answers
SOURCE: Singer Sewing Machine model 9224. Bobbin thread
If you turn the handwheel, can you see a metal ring rotating around the outer edge of the bobbin case? If not rotating, broken gear or timing belt off.
If that ring is turning, remove the needle plate and bobbin case. As this ring now rotates, you will a finger on the ring that will pass behind the needle from right to left and it should catch the thread from the eye of the needle. If this finger, the "hook" passes above the eye, you have a timing problem.
Let me know.
Posted on Feb 16, 2010
I have singer 4166 and it is all threaded and looks ready to but the red light won,t let me sew , what is wrong???
The red light usually signifies that the machine is not ready to sew because some function has not been turn off or has not been activated, the machine is not threaded correctly, or a myriad of other explanations.
Refer to the troubleshooting page (33) in the manual.
Singer 4166 Instruction Book Helpful Hints
Remove the thread from the machine. ALWAYS RAISE the presser foot and rethread from the beginning. Verify the thread path is correct and the needle has been installed facing the correct direction.
May 27, 2017 | Singer Sewing Machines
I have no tension on my singer 8734. The tension will not get tighter when I turn the know the + direction. The tread just pulls through very easily.
You must thread your machine with the presser foot UP, and here's why. There are disks that face each other on EVERY sewing machine; that is what applies the tension. Those disks are spread when the presser foot is UP to allow the thread to pass in between them. When you put the presser foot DOWN, the disks come together again and apply the tension. You will only feel tension on thread with the presser foot down.
May 22, 2014 | Singer Merritt 8734
How to wind the bobbin on the singer creative touch 1030
on touch and sew models thread the machine up as normal, select straight stitch, presser foot up, take the thread from the needle and wind it round the presser foot screw a few times, open the slide plate, push the little button over, press gently on the foot control to wind the bobbin, when finished close the slide plate to drop the winder down and pull the threads to the back and start sewing
Sep 04, 2011 | Singer Sewing Machines
How to fill a bobbin on singer sewing machine model 6268
Raise the presser foot and turn the hand wheel to put the needle at the highest position. Next open the slide plate by sliding it towards you. Make sure the bobbin is empty (remove any remaining thread or use a new bobbin). Slide the plate forward (partially closed) so that the arrow on the plate lines up with the arrow on the machine bed. Bring the thread from the needle under the presser foot and wind it around the presser foot screw (on the left of the assembly) once. Make sure that the thread is in the spring groove. Press the One-step Button hole A button (has a bobbin symbol by it). Then begin running the machine. Watch the winding process carefully and stop when you have enough thread on the bobbin. Do not let the thread continue to wind past the outermost line on the bobbin (black). Slide the plate fully closed and raise the needle. Pull the thread to the back of the machine to a length of 4" and cut the thread in the middle of the loop you just pulled through.
Now position your fabric under the presser foot, lower the presser foot and select your stitch. Begin sewing.
The manual is available for sale or download here: http://www.singerco.com/accessories/instruction-manuals/search . Just enter the model number. The direct link is: http://www.singerco.com/uploads/download/1272_6268-_-6268_6267-wholeas-of-6_23_05-special.pdf . Pictures for winding the bobbin are on page 16 (page 18 of the PDF).
I hope this helps.
(make sure that the machine is correctly threaded before starting to wind a bobbin)
May 25, 2011 | Singer Sewing Machines
Singer inspiration. When using zipper foot. Excess amount of thread on bottom of material, very loose and loopy. Wasting alot of thread for such a some task.
Your top threading is not right, check to make sure that your thread hasn't jumped out of a guide. Totally rethead with the presser foot up, now pull thread, it should move smoothly, next put the presser foot down, the thread should barely move. This will seat your thread in the tension discs. If, that does not work, insert a new needle.
Apr 23, 2011 | Singer Inspiration 4210 Mechanical Sewing...
Singer 5050 sewing machine threads gathering under fabric and becoming knotted. how do i fix this
Try a new needle and rethreading. Check your threading by putting the presser foot up , then pull thead, should move smoothly, now put presser foot down, now pull, it should barely move. This usually seats the thread in the tension discs.
Jan 02, 2011 | Singer 5050 Mechanical Sewing Machine
I just received a singer 4205 (inspiration) and the presser foot does not move back and forth to pull the material through the machine. It seems to be stuck. I am not a seamstress, but 3 other people...
It is not your presser foot, you must mean the feed dogs, they are what moves the fabric along. Clean and Lubricate your machine. Remove the bobbin case and clean it out. Replace your needle now Totally rethread the machine, according to your manual. Test the threading by putting the presser foot up, pull on top thread, it should pull smoothly, now put your presser foot down, the thread should barely move. This will seat the thread in the tension discs. By the way, try your tension on 3. Also, make sure that your presser foot is down before sewing. Always move the handwheel towards you, never away from you because you will mess up the timing. You will see your feed dogs move if you watch. Download a free copy of you manual at www.singerco.com and save it, plus enlarge the diagrams. If, that does not do the trick call Singer at 1-800-4singer.
Dec 25, 2010 | Singer Inspiration 4205 Mechanical Sewing...
I can't fix the tension on the machine Singer 5062. I am getting loops on the bottom
Try this little trick, rethread it and then with the presser foot up pull on the top thread, it should move smoothly, now put the presser foot down, the thread should barely move. This sometimes seats the thread in the tension discs the right way. I have my tension set at 3 but each machine is different.
Nov 12, 2010 | Singer 5062 Mechanical Sewing Machine
We have a Touch & Sew 640 that we ARE trying to get running, and we need a manual, and specifically how do w thread the bobbin.
To wind the bobbin, select straight stitch, thread the machine up as normal making sure the presser foot is up, open the slide plate, push the little button over to raise the winder, take the thread and wind it round the presser foot screw a few times, press on the foot control slowly and the bobbin will wind, when you have enough, stop, close the slide plate to drop the winder down, pull the threads to the back and start sewing. for manuals try www.tandtrepair.com
Jun 24, 2010 | Singer Touch Sew 7462 Mechanical Sewing...
I have a 7466 Singer sewing machine. No matter how I adjust the thread tension, the top thread always pulls the bobbin thread through to the top. I am doing thread painting. The feed dogs are lowered and...
Make sure to thread the machine with the presser foot up to insure the thread is seated into the tension control.
Always free-motion with the presser foot down.
Try a lower setting on the tension.
Mar 28, 2010 | Singer 7466 Mechanical Sewing Machine
Singer 5050 Mechanical Sewing Machine Logo
202 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
