Question about Frigidaire ATF6000ES Front Load Washer
Washer filling with water when off
We just bought a Frigidaire front loading washer from HHGregg yesterday, when the washer is turned off or even not plugged in it fills with water. The first load we tried it filled up so high it blew the door open. Less than 24 hrs old. what could be the problem?
  • neonllama19 Feb 12, 2009
    thank you:) im guessing it should be covered under warranty since it is only a day old. We were just afraid it was something we did by setting it up. Is that possible?
  • 360 Answers
Sounds like a bad fill valve...contact HHGregg. This is a warranty issue. Do not attempt to make any repairs, it would void your warranty and then you would have to bear the repair costs.
clarkco
Posted on Feb 12, 2009
  • clarkco2002 Feb 12, 2009
    basically the only other likely causes would be a foreign object in the valve preventing it from closing or damaged valve.
MY FRIGIDAIRE FRONT LOAD WASHER WONT FILL WITH WATER OR SPIN . HAVE TRIED CLEANING THE DOOR LOCK & UNPLUGGING IT FOR EXTENDED PERIODS OF TIME.
Sounds like the fill water solenoid has bust, they are cheap to replace and fairly easy. make sure you disconnect from power supply and water supply before trying.
Jan 30, 2014 | Frigidaire GLTF2940ES Front Load Washer
My frigidaire affinity front load washer ATF6000FS1 wont fill with water
Hello hitman43 - Are the house valves turn on fully? Most common cause is a faulty switch that doesn't allow the value inside turn or a kinked fill hose. Other possibilities can be water valve faults, faulty control board, pressure switch or wiring failure. Contact a professional to move forward accurately.
Jan 01, 2013 | Frigidaire Affinity ATF6000F Front Load...
E 10 code what do u do
I'm assuming your washer is a Kenmore or Frigidaire front loading washer. E10 error code is an indication of a slow fill, took to long to fill, no fill or the fill water could be siphoning out the drain hose as it's filling with water.
Check to make sure that the drain hose is not stuck too far down the stand pipe and causing the water to siphon out. Check the cold and hot water supply to the washer for any restrictions. If you have a slow fill remove the hoses from the washer and check for restricted filter screens in the water inlet valve. Check for any restricted hose screens too.
Jan 10, 2011 | Frigidaire ATF6000ES Front Load Washer
My Frigidaire front load washing machine feels warm/hot even when I chose the cold wash cycle. My clothes are even hot at the end of the cold cycle.
its the hot water fill velve leaking,,,,your getting a small amount of hot water as well as the cold water when it fills up the washer,,, change the water velve
Jun 08, 2010 | Frigidaire ATF6000ES Front Load Washer
My Frigidaire front load washer won't start it doesn't even fill up with water and it also doesn't spin.
Most likely a faulty door switch. Machine thinks door is open and won't start. Part number 131763202
Apr 09, 2010 | Frigidaire ATF6000ES Front Load Washer
My front load washer does not seem to fill enough
At least on our GE front loader it is ok. That's why they are so easy on water.
Aug 17, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire (LTF2940E) Washer starts, stops, starts, stops...
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
May 07, 2009 | Frigidaire GLTF2940ES Front Load Washer
Kenmore Elite front load washer filling up while turned off
sounds like a bad water inlet valve stuck open and permitting watertto enter even though not on, untill you replace the valve turn off water between uses part number 8181694
Oct 30, 2008 | Kenmore Elite 45986 Front Load Washer
Affinity front load washer
my front load washer won't spin water out
Jan 21, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
222 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
