Question about Minolta Maxxum 7000 35mm SLR Camera
Focal flash DT-5000s Zoom
I am trying to find out if I can use this flash on Minolta 7000? Any does anybody know where I could get the manual on this product? Thanks
5 Suggested Answers
cammedic
  • 667 Answers
SOURCE: Shutter Blades out on Minolta Maxxum 7000
It is possible to fit them back since they are flexible. It does require a gentle touch, with a lot of patience. I use angled tweezers for this task.
Replacement parts are no longer available. Used cameras can be found on ebay and the like.
Posted on Feb 13, 2008
informatica
  • 1114 Answers
SOURCE: MINOLTA MAXXUM 7000 MUNUAL FOCUS
Hi - You can download the manual from the link underlined in blue below:
MINOLTA 7000 part 1
MINOLTA 7000 part 2
See page 36 in part 2:
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Posted on Aug 16, 2008
  • 3 Answers
SOURCE: rewinding on a minolta 7000
This seems to be a much simpler question than assumed by the answer above. Did the first answerer have much more information? The simple answer is: Push down the small "R" button on the back of the camera beneath the display and slide the gray knob next to it to the left. This assumes no problem with the film transport mechanism. Stan
Posted on Aug 19, 2008
informatica
  • 1114 Answers
SOURCE: Instructions for a Minolta Freedom Zoom 70 C Camera
Hi - You can download the manual by clicking the link underlined in blue below:
Freedom Zoom 70 C
Informatica
Posted on Sep 02, 2008
SOURCE: looking for 35mm minolta maxxum 7000 user manual
Ebay.com You can find that and also parts for them cameras I buy parts and repair mines like the film door latch. Russ hope this helps.
Posted on Mar 31, 2009
I have a konica minolta model 2806-301 and i need an instruction manual for it can you help me?
Really, you are talking about Konica Minolta Dimage Z6 6MP Digital Camera with 12x Anti-Shake Zoom:
MPN: 2806-301
Model: 2806-301
Optical Zoom: 12
Digital Zoom: 4
Maximum Aperture: 2.8
Maximum Focal Length: 69.9
Minimum Focal Length: 5.83
Maximum Resolution: 6
Maximum Vertical Resolution: 2112
In this link coudl find your User Guide: Konica Minolta DiMAGE Z6 (down page, enter verification code to download user manual).
Hope helps (for free, remember to rate this answer).
May 16, 2011 | Konica Minolta Cameras
What size lens fits a Minolta Maxxum 3xi??
It depends entirely upon what you're after and the type of photography you wish to undertake.
Any Minolta AF mount lens will fit. 28mm is a standard wide angle, 50mm is a standard lens with a field of view approximately the same as the human eye, 80mm is a slight telephoto and for distant subjects 200mm is a long telephoto. Some lenses combine a few into one, they're called zoom lenses and will typically be something like 35-70mm, or 70-200mm. The measurements relate to the focal length of the lens, but generally the larger the number the longer the lens sticks out at the front. Zoom lenses are bulkier and heavier than fixed focal length lenses, but they're also the most commonly used types these days.
Sep 03, 2010 | Konica Minolta Maxxum 3Xi 35mm SLR Camera
Pics too bright when I use flash
Try to adjust the Flash intensity, if u need the manual you can read it here:
http://www.olympusamerica.com/files/oima_cckb/c700uz_basic.pdf
(Menu Functions :page 32)
(Flash Mode :page 25)
hope it help,
regards
Apr 17, 2010 | Olympus C-7000 Zoom Digital Camera
What year was the Minolta Maxxum 7000, serial number 16043985? Thanks, Karla
I do not know for certain. You might find that answer on the Yahoo Minolta groups.
The Maxxum 7000 was introduced to the US market in 1985. Sold as the Alpha 7000 in Japan and Dynax elsewhere, it was replaced by the 7000i in a couple years. Then the 700, the 700xi, the 700si, the 70 and the 7 was the last film based 7 series. There
They also made 8000i, 800si, etc. The 9 series was the Minolta Professional cameras and they had the toughest bodies, weatherproofing, higher shutter speeds, and more.
Later models introduced better autofocus, better exposure options, wireless flash, faster film advance, etc.
lightspiritphotography.com
Nov 10, 2009 | Minolta Maxxum 7000 35mm SLR Camera
I have a Maxxum 7000i 35mm camera and in the display there is the word Help flashing what does this mean This happend after i tried a differnt lens, the lens opened than closed The lens that i tried was a...
Konica lenses do not fit Minolta cameras. I think you messed something up.
Minolta MC and MD lenses worked on the older manual focus Minolta bodies. They will also work on the Phoenix and Seagull clones of the old Minolta bodies.
The Konica lens should only ever be mounted on a Konica camera.
Your 7000i is now a Minolta paperweight. You need to send your 7000i for repair or replace it.
You could also look on Ebay for another Maxxum body to use your lenses designed for the Minolta A mount. As a rule, camera lenses are not interchangeable. You can use any Maxxum lens on any Maxxum body as a rule, but Minolta changed their flash shoe after the original 7000 series. Flashes that work with your 7000i will work with any subsequent Maxxum.
Oct 25, 2009 | Minolta Maxxum 7000 35mm SLR Camera
Noise from the built-in flash and it can not stand in position.
This camera should not make any noise when you lift the flash head up as it is a manual system i.e. you have to physically lift it up,
It will make some noise as you zoom backward and forwards as it has a zoom motor for the flash head so the flash coverage is correct at different focal lengths.
If you are saying it is floppy then it is broken and needs to be looked at, if you carry on trying to use it, something may short out in the head and cause a loud bang and you camera will stop working.
Nov 16, 2008 | Minolta Maxxum 800si 35mm SLR Camera
MINOLTA 7000 part 1
MINOLTA 7000 part 2
Informatica
Aug 15, 2008 | Minolta Maxxum 7000 35mm SLR Camera
Minolta Maxxum 7000
ONline manual from Minolta says "winding motor problem", try removing battery and reinstalling. It didn't work for me though.
Jul 13, 2008 | Minolta Maxxum 7000 35mm SLR Camera
Automatic zoom
auto zoom will only work while the build-in wide-flash adapter is slided inside.
Apr 05, 2008 | Nikon Speedlight SB-600 TTL Flash
What type of lens does the DiMAGE 5 use?
The DiMAGE 5 offers a 7x high power zoom lens, with a focal length of 7.2 - 50.8, which in 35mm equivalent equals 35 - 250mm. A manual zoom ring controls the optical zoom. The DiMAGE 5 has a maximum aperture of f/2.8 - f/3.5.
Sep 15, 2005 | Konica Minolta DiMAGE 5 Digital Camera
Minolta Maxxum 7000 35mm SLR Camera Logo
259 people viewed this question
Top Minolta Photography Experts
Greg Cann
Greg Cann
TC CAMERA REPAIR.Com...
Are you a Minolta Photography Expert? Answer questions, earn points and help others
