Question about InFocus ScreenPlay 4805 Multimedia Projector
I turn on the 4805,green led blinks & bulb does not come on?
Help...the bulb does not come on. the green led light just blinks?? the fan comes on and i can hear the color wheel spin?
    Scholar:
  • 167 Answers
After a few minuets does the green blinking light turn to a red blinking light?
If so the problem is the lamp did not strike.Either the lamp has failed (most likely) or there is a problem with the power supply (less likely)
Posted on Nov 29, 2009
We have a Samsung HL67A510 and when I turn it on, I can hear a click and the green LED light blinks and the "on" music plays and I can hear the fan blowing in the back. But after a couple of...
Hi Isnovero,
The main reasons of your problem is the bulb which is already came to its end. The unit will automatically shuts off when it sense a bulb failure. But before you replace the bulb I would advice you to work first on its power supply. Look for open fuse/fusible resistor and spot some bad solder joints. This will do the same symptoms like what it showing now. If you don't have necessary tools and test instruments, and can't do the job yourself, I would advice you to look for a professional to troubleshoot the problem. Don't attempt to work in the power supply if you don't know the safety precaution of handling it, there some stored electricity enough to hurt you with a little mistake only.
Hope I helped you.
Have a nice day! Thanks for using Fixya.
Feb 17, 2011 | Televison & Video
Infocus 4805, wont power up remotely
the lamp has burned ot and needs replaced,
Nov 25, 2007 | InFocus ScreenPlay 4805 Multimedia...
New bulb worked for a short trail run now wont light up. flashing green led colour wheel is turning on start up
when you changed the lamp, did you blow the dust out of the projector? if the screen on the side of the lamp is blocked (i.e. with dust), the lamp will blow quickly. if the projector were to overheat, by the fans not running or blocked vents, everything would shut down and the led would blink red.
Jan 01, 2010 | InFocus ScreenPlay 4805 Multimedia...
Projector goes POP!
I think it's the bulb, the best would be to take it to the shop where you bought it - or any other good electronic goods shop - so they can test it. If its still under guarantee its better to take it to the dealer. Mine had to have the bulb replaced after only 8 months, but it was still under guarantee.
Jun 11, 2009 | InFocus ScreenPlay 4805 Multimedia...
In the manual there is a chart which will indicate the nature of the failure depending on the number of times the red led flashes before a pause.
Most common is the projector's lamp timer has exceeded the operational lamp time limit.
While the projector's red led is flashing, press the volume up and down buttons on the projector simultaneously and hold them both in for 10 seconds.
This will reset the lamp inhibit protocol.
However if the lamp has thousands of hours of use you need to replace it before it actually fails.
Feb 28, 2009 | InFocus ScreenPlay 4805 Multimedia...
SP4805 bulb does not fire up; led stays green; fan turned on
I had the same problem after purchasing a new bulb. My husband pulled it out after it would not fire up and the new bulb plug in conecter (white with 4 holes with two wires) was different. Take your old bulb and compair the two conecters and see if they match, then check if the wires are in the same slots as in first and last. Mine on the new one were in the first and second to last slot. So we took the wire out of the second to last and put it in the last slot and installed it and it fixed the problem. We also had to unplug and replug it in and do a master reset by pressing the Power and Channel buttons and the same time for 15sec. Hope this helps.
Jan 23, 2009 | InFocus ScreenPlay 4805 Multimedia...
Infocus 4805 - Doesnot display and make noise at start-up
Well a single red blinking means the lamp won't strike after five (5) attempts. The "squeaking" sound if it's coming form the large fan usually always means the Mos-Fet fan speed controller chip has failed which presents sometimes as an intermittent squeaking sound. Which would implies the lamp may have failed from the resultant over temp. However if the squeaking noise is coming from the color wheel that would mean it's bearings have failed and if is is unable to phase lock at reference speed the lamp would also not strike. The odd symptom is the remote thing... That does not fit! If is actually is related to the common cause of all the problems... That leaves only the power supply has partially failed (not too expensive) causing all of these symptoms.
Or murphy has moved in...
SagerTronics
Oct 28, 2008 | InFocus ScreenPlay 4805 Multimedia...
4805 w/less than 300-400 hours has blinking red light
Yikes. I bet the bearing is bad in the fan and/or the fan is rubbing up against something. It might be an fix.
Jul 16, 2008 | InFocus ScreenPlay 4805 Multimedia...
Projector problem
I generally fix this by re-seating the bulb housing. Take it out and put it back in. Look for cracking at the base of the bulb on the mirrored surface. It could be a barely functioning bulb that isn't busted, but can't initialize. I would take it to a shop that has the same bub type in a housing and make a quick switch.
Jun 20, 2008 | InFocus ScreenPlay 4805 Multimedia...
InFocus ScreenPlay 4805 Multimedia Projector Logo
1,151 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
