Question about Dell Latitude D800 Notebook
D800 laptop will not display on external monitor
When I close the lid on my d800 when connected to external monitor...no signal to monitor...monitor goes black......monitor is compatible Dell product directly connected to the laptop. Monitor displays and functions properly when laptop screen is also open...both screens active.
I want to use the laptop at the desk with only monitor active and laptop lid closed........is there a setting??
  • sweenya Feb 12, 2009
    Thanks...I had found that option and have it currently set to "do nothing...still shuts down. I noticed also the Power options have numerous settings for Laptop, Home, etc. I chose "always on" in hopes that might do it........still not working.
    Just one more thing...the actual error on the monitor says: " 1: Analog input. Cannot display this video mode"
  • 29 Answers
Most laptops go into standby mode when the lid is closed. To stop this, (Windows XP) click Start, Control Panel, Performance and Maintenance, Power Options, then click on the Advanced tab, select "Do nothing" in the drop-down for "When I close the lid of my portable computer"
Posted on Feb 12, 2009
My dell latitude d800 dosnt start. no cursor no splash screen ..only lightning some buttons..
If you see power lights but nothing appears on the screen, it could be a "POST" (Power-on Self Test) problem or simply LCD problem.
Here are some steps that you can try. One of these may work on your case.
1. Remove the battery and the ac adapter then press the power button for at least 20 seconds to drain electric charges left on the system. (You may need to repeat this step to get it work.)
2. If above step doesn't work, try to plug in an external monitor and see if you get display from the external monitor.
3. If you get display from the external monitor, I'm sure your having problem with the LCD components. In this case, check and replace faulty LCD backlight, LCD cable or LCD inverter. The LCD inverter is often a culprit.
4. Try to reinsert the memory module/s (RAM) of the unit, try using one RAM at a time to see if it works. A faulty RAM will cause the laptop not to POST.
5. If reinserting the RAM doesn't help, most likely your motherboard needs to be replaced.
Hope this helps.
Sep 03, 2011 | Dell Latitude D800 Notebook
My screen isn't working when I turn the laptop on.
First you determine if you have a no post, or a no video situation. To see if it is no post:
http://www.fixya.com/support/r3581893-how_to_troublehoot_a_portable_compouter_
If the system is in a no video state, connect an external monitor and enable it with Fn-F8, if you get video, replace the LCD. If an external monitor doesn't work, replace the video card
http://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1313&_nkw=d800+video+card&_sacat=See-All-Categories
If system is a no post, you will like need a motherboard. LCDs or motherboards can also be found searching Ebay.
Teardown instructions can be found here:
http://support.dell.com/support/edocs/systems/latd800/sm_en/index.htm
Mar 18, 2010 | Dell Latitude D800 Notebook
Lcd screen will not light up
Hi:
You can check to see if the rest of the laptop is working ok, by toggling to an external monitor, by holding down your function key and hitting the monitor swap key, usually f5 thru f8, depending on the laptop. If you get a good display on a external monitor, then you are down to needing a LCD inverter board, or a new LCD.
Dec 17, 2009 | Dell Latitude D800 Notebook
Booting up monitor flashes then goes dark.
Are you sure you are recving a signal to the monitor??
It sound like it could be a backlight tube or power inverter. Try a external monitor to check.
Sep 02, 2009 | Dell Latitude D800 Notebook
WXGA Display for Dell Latitude D800 Problem. When
replace either your cold cathode screen lamp or, your inverter board in your display
Aug 28, 2009 | Dell Latitude D800 Notebook
Dell laptop connected to 1209s projector...dell page indicates searching for signal and can't
Using the Display When you start the computer with an external device (such as an external monitor or projector) attached and turned on, the image may appear on either the display or the external device.
Press <Fn><F8> to switch the video image to the integrated display only, the integrated display and an external CRT monitor simultaneously, an external CRT monitor only, the integrated display and an external DVI monitor simultaneously, external DVI monitor only, and external CRT monitor and external DVI monitor simultaneously.
May 15, 2009 | Dell Latitude D800 Notebook
Dell D800 won't boot
you have an issue of no display and as you see that u are betting the knocking sounds, could u plzz let me know are you getting these sounds when you power on the computer with the Fn and the power button, if you are able to listen to the sound but there is nodispaly then its a no video issue . in order to determine whether its an issue with the LCd you can connect an external monitor to the laptop and power on the laptop then hold the Fn key down and then press the F8 key and release both the but keys, look for the display on the m#external monitor , toggle the keys a couple of times , if you are able to see the display on the external monitor and not on the LCD , then u have to open the cover above the keyboard (hinge cover) and reseat the LCD cable, if there is still no display then the LCD has to be replaced.
Let me know once you try these steps...
all the best :)
May 01, 2008 | Dell Latitude D800 Notebook
D800 Video Display
If you get a clean picture when connecting esternal screen, then it is just the lcd flat ribbon LCD cable that is out of place, otherwise it is the videocard.
Mar 17, 2008 | Dell Latitude D800 Notebook
Dell Latitude D800 Notebook Logo
862 people viewed this question
Alun Cox
