Question about Sharp AL-1530CS All-In-One Laser Printer
New drum wont work
Old drum was working fine, but drum light was blinking. Put in new drum but drum light was still blinking, copied 50 copies and drum light went full on which stopped all coping. Put in old drum and drum light was full on and copier still would not work. Put new drum back and and same thing, wont work???
    Problem Solver:
  • 14 Answers
It sounds to me that your maint counter needs to be reset. 24-7 will reset drum. Let me know if you need help getting into the simulation.
Posted on May 08, 2009
Very light copy in 2nd side copy
its a moisture issue in the paper. try nice new dry paper and i bet it works fine
Mar 17, 2012 | Lanier Office Equipment & Supplies
I have a mfc-8440, 5 years old, low usage, 50% drum life, new toner cartridge. The problem is that the contrast of the printed copy does not change regardless of the setting using the path...
This is very easy to solve. Remove the drum and toner cartridge. Look into the machine where they sat. Now look up and you will see (a little aukward but its there) a glass plate the width of an A4 sheet of paper. Run your finger accross it. Look at your finger and will probably be dirty. This is the window the laser beam passes thru to hit the drum. When its dirty it does not allow enough ;light to the drum hence a weak beam and light printing.
simples?
May 18, 2011 | Brother MFC-8440 All-In-One Laser Printer
I feel like the drum needs cleaned. My copies all
On the drum try cleaning the corona wire by sliding the light blue slide left & right. if that does not work you might need a new drum. I have them for 50 bucks 805-520-3003
Jan 21, 2010 | Brother MFC 7420 All-In-One Laser Printer
Copy light
Hi
When you were replacing the drum did you tuch the drum surface?Best would be that you take some toner on piece of cloth, and polish the drum, while turning it in good direction, that the cleaning blade can clean it.After you must let it copy about 50 copies.
You can try to replace the whole drum unit cexv14, or clean the laser unit.
Also could it be that the toner unit, or toner cleaning blade are not properly distibutes the toner accross the developing/toner cylinder.
Nov 26, 2009 | Canon iR 2020i Laser Printer
How many copies should a copier produce before changing a drum
I bought a km1620 copier. but copied only A4 size paper. No longer paper can not print except A4 paper. how can I change copying system. And how can I count copy. pls. mail me.
mizan
Jun 12, 2009 | Kyocera Copystar CS-1620 Black and White...
Drum life low replace soon Error Message
I already answered this at some other place here - but just to make sure the word gets out there:
There is a little special (white) gear on the outer left side of the drumkit - a little bit below where the toner sits. That gear joins with toner assembly - and you can rotate it counterclockwise all the way back. This should reset the drum counter - worked for me!
I hope it also does the trick for you ;-)
Apr 03, 2009 | Panasonic KX-MB781 All-In-One Laser...
New drum and the copies are extremly light
Drum may be defective must be repalced.
When replacing drum, be sure to reset the drum counter for HL 5150D:
-Open the toner compartment door, and hold the go button for 5 seconds.
Nov 30, 2008 | Brother HL 5150D Laser Printer
Locked up AL-1642CS with blinking Drum Light
Older Sharp AL copiers will go on working with the drum light blinking, but yours will not. Newer models do stop working when the drum reaches its limit. Now keep in mind that just as almost every copier in the market, these units count the copies they make in order to determine toner & drum life. So it is possible to reset the drum counter if you inspect the unit and see no markings or visible wear & tear. Also keep in mind that the toner & drum units have been the same for all AL units through time, so there are plenty of good replacements in the market (not recycled, but re-manufactured or brand-new compatibles).
As for your unit, if the drum is Sharp original or a good quality replacement, you should have to do nothing after installation, for the internal chip in the drum will tell the copier to reset the counter and begin working automatically. However if that is not the case, or should you want to reset the counter on your existing drum, this is the correct sequence to do so.
  1. Identify the buttons used for adjusting exposure (darker or lighter copies), amount of copies, clear copies and start copying.
  2. Now press the following sequence of buttons: [CLR], [EXPOSURE], [CLR], [EXPOSURE]
  3. Your unit should turn off the numbers in the panel.
  4. Now press 24 as if asking for 24 copies and press [START].
  5. Press 07 as if asking for 7 copies and press [START].
  6. Your unit should restart by itself and start working normally.
Be blessed.
Nov 07, 2008 | Sharp AL-1641CS Laser Digital Copier
Replacing Drum Catridge
Hello, Here are the steps involved in replacing the drum assembly as copied from a users manual:
DRUM CARTRIDGE REPLACEMENT
The useful life of the drum cartridge is approximately 18,000 copies. When the internal counter reaches approximately 17,000 copies, the drum replacement required indicator will light up indicating that replacement of the drum cartridge will be needed soon. When the indicator begins to blink, the unit will stop operating until the cartridge is replaced. Replace the drum cartridge at this time.
1 Remove the TD cartridge (Toner Cartridge). Hold the drum cartridge handle and
gently pull the cartridge out. Dispose of the old drum cartridge in accordance with local regulations.
3 Remove the new drum cartridge from the protective bag and remove the protective cover from the cartridge. Then gently install the new drum cartridge.
When closing the covers, be sure to close the front cover securely and then close the side cover. If the covers are closed in the wrong order, the covers may be damaged. Do not remove the protective cover on the drum portion (black paper) of
a new drum cartridge before use. The cover protects the drum against external light.
Do not touch the surface of the drum (green portion) of the cartridge. Doing so may cause smudges on the copies.
4 Gently install the TD cartridge. Close the front cover and then the side cover by pressing the round projections near the side cover open button. The drum
replacement required indicator will go out and the start indicator will light up.
Aug 15, 2008 | Sharp AL-1217 Copier
Open Questions:
Sharp AL-1530CS All-In-One Laser Printer Logo
407 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
