Question about SimpleTech SimpleDrive Portable USB 2.0 60GB 5400rpm 480Mbps USB 2.0 USB 2.0 External (STIUSB2560FT) Hard Drive
Simpletech usb drive model 96300-40001-001 Mac OS9 compatibility
I have an older Mac with OS 9.2 and good reasons not to upgrade to OS X. It does not recognize my Simpletech external usb drive. Any suggestions would be appreciated. I'm pretty sketchy on Macs and know pcs better, so assume I'm an idiot! Thanks.
  • 3 Answers
If its 9.2 it may be because your mac is usb 1 and your external HDD is usb 2. It will recognize it but sometimes it takes longer to see the drive.
Posted on Sep 24, 2009
For the last couple of months I've had to un-plug, then re-plug my EHD to get it to be recognized by my HP laptop. Today my HP says that the device is not regonized. Can the Signature Mini be re
If you have a SimpleTech SimpleDrive connected to your computer and you're experiencing problems with the external hard drive, there may be several reasons why it's malfunctioning. Troubleshooting your computer can help rule out common problems and the possibility that the hard drive may be defective. If you recently purchased the device and suspect there is something wrong with it, return the defective drive to SimpleTech or the reseller for a replacement. Incompatible USB Port Problems SimpleTech SimpleDrive plug and play options makes it easy for you to connect the device to your computer. But you may encounter problems if your computer's USB (Universal Serial Bus) ports are not compatible with the external hard drive. Make sure your ports are powerful enough to operate the drive. USB 2.0 ports are recommended, but if you're using an older computer with 1.0 ports, the hard drive will function much slower or you may receive an error message that the device is not compatible with your system. b> Missing External Drive Letter If you're unable to find the SimpleTech external hard drive's letter on your desktop after you have installed the drivers for the device, it's possible that the external drive may be assigned to another drive. Sometimes, the hard drive is assigned to a network drive and you may need to manually change the drive's letter in Disk Management. b> SimpleTech SimpleDrive Incorrectly Formatted b> SimpleTech SimpleDrive is normally pre-formatted for Windows NTFS (New Technology File System), but Mac users may need to copy the backup software and reformat the external hard drive for FAT32 or Mac OS to be able to use the external drive. If the external hard drive is not formatted correctly for your system, it may not function or work properly. b> External Hard Drive Inaccessible If you receive an error message that says "Drive Inaccessible," the SimpleTech SimpleDrive may not be able to read the service area of the platter. If the external hard drive emits a loud or abnormal sound, this could mean the device is failing.
Test the drive on another computer to see if it is working properly. Otherwise, the external hard drive's surface area may be damaged or corrupted.
Replacing a Defective Hard Drive You can return a defective hard drive that is under warranty to SimpleTech. The manufacturer will exchange the device if the seal is not broken. But if you break or tear the seal on the case, any warranty claims will not be accepted and the device will be returned back to you. SimpleTech will only accept the device if you contracted a commercial data recovery company to retrieve critical data from the external hard drive and the seal needed to be broken. Before returning the defective drive, you will need to secure a RMA (Return Merchandise Authorization) approval number from SimpleTech and furnish any invoices or documentation regarding the data recovery company's services
or if its a usb external drive you might need a usb 3 card installed on your computer your computer might not have enough usb output power USB 3 card will provide more power when needed to the device to gain maximum throughput and conserve power when the device is connected but is idling http://blog.premiumusb.com/2010/09/usb-2-0-vs-usb-3-0/ these can be purchased on Ebay cheap and easy to install http://www.ebay.com.au/itm/PCI-e-PCI-Express-USB3-0-Card-new-NEC-720200AF1-chipset-/330608109325?pt=LH_DefaultDomain_0&hash=item4cf9c7670d for roughly $9 or $10free postage Hope this helps.
Jan 24, 2013 | SimpleTech Signature Mini 250GB External...
When i plug in the usb to my computer it is not recognized and does not show anywher
b>
Dec 14, 2012 | SimpleTech 500GB SimpleDrive Pro External...
Won't recognize external hd
Dec 11, 2012 | SimpleTech SimpleDrive Pininfarina 500GB...
Computer is not recognizing
If you receive an error message that says "Drive Inaccessible," the SimpleTech SimpleDrive may not be able to read the service area of the platter. If the external hard drive emits a loud or abnormal sound, this could mean the device is failing. Test the drive on another computer to see if it is working properly. Otherwise, the external hard drive's surface area may be damaged or corrupted.
hope this helps
Oct 15, 2012 | SimpleTech SimpleDrive Pininfarina 320GB...
How do you use the simpletech 160 gb ext drive with a macbook pro or a macbook
Your external HDD must be MAC OS compatible.
I've it is compatible, just plug it in and it should pop-up
Jun 08, 2011 | SimpleTech SimpleDrive 160 GB External USB...
I have had OS9 applications on my computer for several years (I believe they were installed with the initial installation) and I never used OS9. Just wondering if I can delete these applications without...
Yes you can remove these applications without causing problem in OS X. I think however you'd be happier wiping the hard drive (AFTER backing up any files you need) and installing OS X fresh without the OS 9 feature; not only would you save quite a bit of hard drive space but you'll see the machine run quicker.
Feb 02, 2011 | Apple Mac OS X 10.4 Tiger for Mac
Cannot add write files to SimpleTech drive from a Mac
Most of the times you just have to format the drive to Mac OS Journaled or else you will only be able to transfer 4gb or less at a time.
Sep 23, 2009 | SimpleTech SimpleDrive Portable USB 2.0...
DOES THE VERBATIM HARD DRIVE NEED TO BE FORMATED?
Many Verbatim hard drive models with a FireWire interface come “Mac formatted” – pre-formatted for immediate use with Apple Macintosh computers running Mac OS. They are formatted as HFS+, the preferred format when using the drive exclusively with Mac OS computers.
Note: A Mac-formatted drive will not mount on a Windows PC.
If you plan to use a Mac-formatted hard drive only with computers running Mac OS, you can leave it formatted as it comes from the factory. However, if you plan to use your hard drive with computers running Windows, or with both Mac OS and Windows computers, you should reformat your Verbatim hard drive before saving data to it. Generally, for use with both Mac OS and Windows you should format to FAT32, and for use strictly with Windows you should format to NTFS. More information about these two format types is given below.
FAT32 FAT32 is compatible with the following Windows operating systems: Windows 98, Windows 98 SE, Windows Me, Windows 2000, Windows XP, Windows Vista. FAT32 can also be read by Apple Macintosh computers running Mac OS.
Limitations: Maximum file size is limited to 4TB. Furthermore, using the formatting tools included with Windows 2000, Windows XP, and Windows Vista users will not be able to create partition sizes larger than 32GB (though they can access these larger partitions). This limitation does not apply to other supported operating systems. Furthermore, Verbatim provides a FAT32 format utility (see further below for download instructions) that eliminates the 32GB partition limitation.
FAT32 is a good choice if you’ll be using your Verbatim hard drive with older computers running Windows 98, Windows 98 SE, or Windows Me, or if you’ll be using it with both Windows and Mac OS computers.
NTFS NTFS is compatible with the following Windows operating systems: Windows NT, Windows 2000, Windows XP and Windows Vista. NTFS usually results in higher performance than FAT32, and will permit users to create partition sizes larger than 32GB, and file sizes larger than 4TB.
Limitations: NTFS is not compatible with Windows 98, Windows 98 SE, Windows Me, or Apple Macintosh computers running Mac OS.
NTFS is a good choice if you will be using your Verbatim hard drive only with one or more computers running Windows XP, Windows 2000 or Windows Vista. This is also a good choice if you plan to store files larger than 4TB, such as digital video files.
Per: http://www.verbatim.com/downloads/format.cfm
Good Luck
cbinny1
Oct 20, 2008 | SimpleTech SimpleDrive Portable USB 2.0...
Usb hub
here's the compatibility requirements:
Compatibility PC with Intel® Pentium® processor; Windows 98 SE, 2000, ME or XP;
Mac PowerPC processor; OS 8.6-9.x, 10.X and later
http://www.dynexproducts.com/pc-357-2-dynex-7-port-usb-20-hub.aspx
you might want to update your drivers to the latest version
http://www.dynexproducts.com/t-drivers.aspx
Oct 14, 2008 | Dynex Computers & Internet
My Apple mac won't re-start in OS9
may be some conflict in os and hardware,
repare the OS using cds
or select restore option
Mar 06, 2008 | Computers & Internet
Computers & Internet Logo
422 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Lyle Siemens
Lyle Siemens
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
