Question about Vtech ia5870 Analog Cordless Phone
Answering machine not working
The indicator light answering machine on/off does not light up. Pressing the toggle switch does nothing.
  • dreid99 Feb 15, 2009
    As previously mentioned, I fixed the problem myself. I did not receive any help at all.
No further help is needed. I unplugged the wire from the answering machine and cleaned the connection, plugged it in again, and Voila!
Posted on Feb 12, 2009
The CHILD LOCK light came on and I cant get it off. Pressing CANCEL does nothing. How do I fix it?
Usually you need to press and hold a button or a pair of buttons to toggle the Child Lock function. Without the model number of your dishwasher, I can't be sure if this will work on your machine. It did work on the old Kitchenaid I had. Press and hold the Energy Saver/Dry button for 4+ seconds. If the light goes out, you have released the front panel lock.
On some models, you needed to press and hold the Air Dry button. However, you may need to look for writing in a small font that will indicate the correct button/key combination to release the front panel lock.
If pressing the appropriate button for an extended time doesn't work, then your keypad may need to be replaced. The signal isn't being received by the control of the dishwasher. (Alternatively, the wiring between the keypad and control unit or control unit, itself, may have an issue.)
I hope this helps.
Feb 26, 2016 | KitchenAid Dishwashers
I just bought the Panasonic KX-TG9341T. This model has 4 remote extensions. My problem is the light on top of each phone keeps blinking. I checked to be sure I don't have any messages or anything else,...
The message indicator lights up when you have a new voicemail message, answering machine message, when you are receiving a call, or when the handset is placed on the charger. You can change the setting for the voicemail indicator and message indicator by pressing [MENU], [#][3][4][0], and press [▲] or [▼] to switch between off and on, then select [Save]. It is not possible to turn off the LED for an incoming call, or while it is on the charger.
Good luck...
Sep 05, 2008 | Panasonic Lands Phones
Kenmore upright freezer problem
Kenmore Freezer, lights on and loud buzzing sound. - Shop ...
www.shopyourway.com > KRISTI PETERSON > Questions
I have a Kenmore upright freezer model # 253.26052104 and at the bottom of the front there are two lights and an on/off rocker switch. At this time one light is ... When I attempt to turn it back on, it makes an extremely loud buzzing sound. What does that... The switch that you are describing is for the high temperature alarm.
Kenmore rocker switch Freezers Questions & Answers - Fixya
www.fixya.com > Forum > Tags > rocker switch > Freezers
Kenmore freezers rocker switch related questions and answers. ... Kenmore upright Freezer 20.3 cu.ft has 2 switches on the bottom of the freezer and was making a loud buzzing sound like an alarm and the ... How to turn off the doorajar beeping on aKenmore Freeze and what is causing the moisture buildup inside freezer.
GE 14.1 cu. ft. / 399 liter Upright Freezer FUM14DMRWH
Jan 01, 2016 | Kenmore Freezers
The orange on/off button lights up. however the start/pause button does not.
It's hard to tell by the way you've phrased the question whether or not the button is doing what it is supposed to do, or if it is just the light indicator that is not working. So, I will answer both scenarios. // Press start button fully until you hear machine start; (usually less than one full second). In other words, hold button in until ''start'' is _heard_. After start has begun, holding button for 3 full seconds will ''pause'' the cycle. After ''pause'' pressing button again (just like first time) will restart cycle (i.e. ''take it off pause''). But while ''paused'' holding the button in again for any longer than a fraction of a second will cancel the wash. // TO CLARIFY: Press button for approx 1 second to start wash. After start has begun, pressing button for 3 seconds will ''pause'' wash. While ''paused'' pressing button again for less than a second (i.e. ''quick press of button'') will ''resume'' wash. Also, while ''paused'', pressing button for longer than a second (usually 3 seconds) will cancel the wash. // If the machine is (otherwise) working correctly, and your complaint is a light not lighting, then it is just a bad LED light. Best bet is leave it alone. Or, you could buy a new switch if the LED is _inside_ the switch. If the LED is on the control panel, then do yourself and big favor and don't mess with it.
Aug 15, 2015 | Washing Machines
Switch problem
Hi Porl, my answer was assuming that your machine is the product in the picture, if your machine looks nothing like the picture then ignore my answer. It is not easy to answer questions when no specific model information is supplied.
Nov 30, 2013 | Krups Small Appliances Espresso Machine
When I turn on my Canon i560 printer the light blinks orange and green and will not print anything. I've tried to turn it off and on, unplug it and nothing seems to be working. What can I do to fix it?
try this. It is the reset for the waste ink error (8 flashes)
1) With the printer power OFF, while pressing the Resume button, press the Power button. (Do not release the
power button.)
2) While pressing the Power button, release the Resume button, press the Resume button again twice, and then
release the Resume button and Power button.
3) The green indicator flashes during initialization.
When the indicator stops flashing and remains on, press the Resume button 4 times to clear waste ink message.
(The indicator toggles between orange and green each time the Resume button is pressed.)
4) Next, press the Power button, and the green indicator will light, and the function will be executed.
5) Turn off the printer then back on and error should clear.
Aug 04, 2010 | Canon BubbleJet i560 InkJet Printer
Hi i have just had my car Renault Clio on a 06
- By dancer23 on Feb 18, 2010 -
Earlier i posted a question requesting how to switch off the service light on my Renault Clio, i have found an answer to thios, as follows.
How do you reset the service indicator light 2007 renault clio?
Turn on the ignition, but don't start the car. On the right stalk there is a toggle switch that hinges up and down, and is used for going through the different features of the display. When the display shows 'Service Due' press and hold the top part of this switch for 10 seconds until the dispaly resets and it shows 30,000km or whatever until next service.
all of the above is correct apart from pressing the toggle button. if you instead press the bottom toggle button for 10 seconds the display will start to flash. Keep button depressed and 5 seconds later the service counter will reset.
I know this works as i have just done it myself,
I hope this will help many others .
Feb 18, 2010 | 2006 Renault 181
IOGEAR KVM SWITCH WILL NOT TOGGLE BETWEEN COMPUTERS
On my KVM switch it works pressing
Scroll lock key twice then
press up or down arrow
to toggle
Apr 11, 2009 | IOGear MiniView GCS612A 2-port KVM Switch
Self clean light blinks when you turn oven on (oven does not work)
I had this same problem with mine (still posted under unsolved) This is the simpler model with the old turn style knob and the lever you slide over to lock the door for cleaning What I think (keep in mind I know little about ovens, more about cars) is that the switch that tells the oven the door is latched is staying engaged, and this is part of the lever mechanism. I cleaned and lubed this mechanism (obviously I would guess you want to use a food safe lubricant) and then moved the lever several times with the oven on so I could see if it turned on. After a few tries the cleaning light went off and the oven light came on. No, its not really a technical answer, all indications to me where that the problem was in the switch which is part of the latch mechanism. Good luck
Nov 26, 2006 | GE JGBP26 Gas Kitchen Range
Vtech ia5870 Analog Cordless Phone Logo
62 people viewed this question
Top Vtech Lands Phones Experts
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
