Question about Mitsubishi WD-73732 73" Television
Mitsubishi WD-73732 has 1 inch blue/purple band at screen top.
I have a ~1.5 year old Mitsubishi WD-73732 and it just recently started having a 1 inch blue/purple band at the top of the screen. Perhaps it is a coincidence but I noticed it after I started using an Atlona VGA to HDMI scaler to extend's my laptop image on the TV. The band exists on all input sources (PS3, Cable Card and the Atlona scaler). I am still on the original bulb. The band is more blue on the left of the screen and more purple on the right.
  • 1 more comment
  • Lou Sigety Feb 15, 2009
    DLP.
  • Anonymous May 12, 2009
    I have the same issue, it's more like a wedge, thin on the left, thicker on the right. It's not a priority to fix it unless it gets worse, but curious if anyone has fixed this issue.
  • Lou Sigety Oct 19, 2011
    The solution to the original post of "Mitsubishi WD-73732 has 1 inch blue/purple band at screen top" was resolved (years back) by a technician who replaced all sorts of components (which was fortunately under warranty). Had it not been under warranty, I would have considered junking it - especially since the prices of new 73" DLPs have come done *so* much. I was a bit concerned about how much he took apart and replaced but it has been working fine ever since. I sure am glad I had that warranty (at that time).
    However... I like the set so much I bought the top of the line 60" Mitsubishi DLP on line for $900 total - but since the price was so low, I *did not* buy an extended warranty. Also in consideration was that I can easily move that 60" TV compared to the 73" one - if/when I have to simply junk it some day...
    Novelist:
  • 184 Answers
Is this a DLP or LCD projector?
Posted on Feb 14, 2009
  • Billy Bauer Feb 16, 2009
    If its a fairly dark band, it may be a defect in the light tunnel in the optical path between the lamp, color wheel and the DLP imager.
    The light tunnel has mirrored surfaces which are typically glued into position. With the heat that is generated by the lamp, the adhesive may fail, allowing one or more mirrors to get in the light path.
    Its rare, but a defect in the lamp itself can cause a band of color. Take out the lamp when its cooled down, being careful not to touch the glass with your bare fingers, and look into the lamp. The back reflector should be shiny and without blemishes or breaks in the reflective material.
    And, its also possible to have a problem with the color wheel and the lens optics as well although I haven't encountered this myself.
    michtech
  • midnight1111 Sep 10, 2011
    I have the same problem there is a light purpleish band along the top of the screen that gets wider going from left to right. I am currently replacing the bulb. I don't want to replace the light engine, thanks for any suggestions.
Hey midnight1111, did replacing the bulb fix your problem becasue I have the same problem with the same modle of tv?
Posted on Oct 19, 2011
Where can i find a color wheel for a 73732 mit
The way that you change the color on this TV is thru the audio/video menu, under Perfect Color. It show you how in your owners manual on page 74. If you no longer have the owners manual you can downloaded it here http://www.mitsubishi-tv.com/pdf/ownersguides/WD-73732.pdf
Mar 02, 2011 | Mitsubishi WD-73732 73" Television
I have a 2 year old Mitsubishi WD-73732 - 1080p 73" Medallion Series DLP HDTV - WD73732. I am getting blotches of color when there are large areas of blue color. Looks like irregular moving stains...
It will cost you probably in the area of $700.00 to replace the Light Engine. I don't think it would be a good idea to repair it. DLP sets have been out of production a few years now due to high failure rates of the light engines for all makes and models and the consumer cost for the lamp.
Nov 10, 2010 | Mitsubishi WD-73827 73" HDTV DLP TV
I have an older 60 inch ultra vision and has been a gr8 tv i came home the other night and turned and the screen jumped for a couple minutes and then stopped and was fine still gr8 pik but my daughter said...
Mitsubishi wd 62527shows purple and yellow clouds and a big blue spot in the bottom right hand corner of the screen is it worth fixing? yes or no needed
Aug 23, 2010 | Hitachi Televison & Video
Mitsubishi WD-52525
Normal 0 The Mitsubishi WD-52525 has a serious capacitor problem as discussed in this forum overseen by a Mitsubishi certified repair technician: http://www.hometheatershack.com/forums/mitsubishi/11703-problem-mitsubishi-wd-52525-scrambled-picture-no-picture-2.html. There has been a worldwide problem in computers and TVs over thepast several years with faulty electrolytic capacitors (from Taiwan) thatdecay, dry out, swell and die. The power supply is often the firstcomponent to go bad, but other systems also degrade over time. As theforum explains , this problem is widespread in these sets causing multipletypes of display problems after several years of use. On my set, I also got a blue screen with a lighter blue ball in the middle. Mitsubishi is awareof the problem and will cover most of the cost of repairing the chassis, evenyears out of warranty, but apparently ONLY if you get an estimate from aMitsubishi certified repair station and contact their customer support BEFOREdoing any work on the set. I just followed the recommended procedure onthat forum and Mitsubishi is covering half the cost of my $700+ repair when my3+ year-old set recently died and showed only this blue screen on all inputs.
Mar 31, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Color fades out on tv
I have the same tv and the same problem (color banding, incorrect colors, colors blinking) occured after I replaced the lamp. I had a tv repairman take a look at my unit and he said the color index was incorrect, the tv doesn't know the correct colors to display. The best way to fix that problem is to replace the "light engine". The repairman replaced the "light engine" to my tv and everything is working great. My tv was still until warrenty so I don't know how much a new "light engine" would have cost.
Jul 27, 2008 | Mitsubishi WD-73732 73" Television
Half of the screen goes black
the light engine is defective and needs to be changed..this set is not that old..contact mitsubishi customer relations to see about having it done under a customer accomodation, as they have had a lot of problems with the engines
Nov 28, 2007 | Mitsubishi WD-73732 73" Television
Screen Color Looks Like a Rainbow
Good day.
The problem includes malfunctioning of you units deflection yoke, color circuit and failures in the chroma system.
Have it check by a repairman.
chris
Aug 04, 2006 | Toshiba 36A40 36" TV
Mitsubishi WD-73732 73" Television Logo
1,026 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
