Question about HP Computers & Internet
Mine hp laptop.. before loading windows xp it will reboote.
I couldn't access windows.... it shows some error report. past one week i never get into my laptop. i tried to install new xp but when it try to open windows it will start. is there any solution for it
  • 32 Answers
Well if you can install new XP then format the whole system and install the frest copy of XP again(recommended only if data into the system is not important for you)
Posted on Feb 12, 2009
I load all the software plug in camera and I keep getting error report? All we have to do on our daughters laptop is plug in the camera and the images come right up?Is my pc to old? I run windows xp on my...
If its old, you might have to run an errorcheck.
open windows explorer, right click the drive that the software is on,
and select properties, then click the Tools tab, then go into disk check,
click the two boxes, and start.
It might tell you it will start when you restart the computer,
Let it do its thing, and then reboot again.
try it now
Please rate this answer
Aug 09, 2011 | Olympus Cameras
OS won't load. Scan reported bad hard drive, replaced HDD, loaded recovery CD and rebooted, won't complete install. Placed HDD in external case and copied software to it, reinstalled in laptop but it...
You need to reformat the hard drive so that it shows a partition for the HP software. Call HP tech support and explain your problem. They should be able to tell you how to format your hard drive.
Mar 12, 2011 | Computers & Internet
I'm trying to reboot my hp 6930p and everytime i do it comes up with an error report 'stop 0x0000007b (0xf78d2524, 0xc0000034,0x00000000, 0x00000000)
The next time you see this error, highlight the error with your mouse, then COPY/PASTE into your internet search engine. You should be able to find exactly what this means so that it can be corrected.
--Crazy PC Lady
Dec 24, 2010 | HP EliteBook 6930p Notebook PC
Will not load past starting screen (HP logo)
maybe is hard disk problem, try boot from cd.(check for any errors dispayed)
Jul 15, 2010 | HP Compaq nc6220 Notebook
I bought lenovo G550 last week. It came with Windows Vista. I want to install Windows XP on it. I have found that lenovo has driver for windows XP so that will make my life easy :-) But when I try to...
you are most likely getting a BSOD with a stop error code of 0x0000007B which is caused by the Windows XP CD that you are using doesn't have the SATA Hard Drive controller driver needed to recognize and utilize the hard drive. If Lenovo has XP drivers for this model then they should have a SATA driver (roughly 394k) that will need to be loaded FROM A FLOPPY DISKETTE during the boot to XP. (XP Requires the driver to either be slipstreamed into the CD or loaded from a floppy diskette. Trying to load the controller driver USB or a different CD will not work)
http://www.digitgeek.com/how-to-slipstream-sata-drivers-into-xp-cd/
Jan 11, 2010 | Computers & Internet
I got a hp pavilion note book with woindows7
651 error ,first talk to your ISP but also you can check in the device manager -if the driver is working properly if not reinstal it.
Dec 02, 2009 | Microsoft Windows XP Home (vis-winxph) for...
Xp pro will not load
HELLO THERE:
when you start the computer hit the f-8 key repetedly and the xp pro advanced boot screen should show up now select last known good configuration that worked then hit enter and the computer will reboot and hopefully this will get you going also make sure there is no cd rom in the drive ok? please let me know how this goes there is more we can do if needed please dont forget to rate the solution i have provided this helps me out as well
best regards mike
Aug 06, 2009 | HP Pavilion N5350 Notebook
Installation of Windows XP Pro on Hp Pavilion laptop
what is the error message that you're getting.. usually windows vista will not downgrade your operating system to windows xp. You may need to remove vista before you can load xp.
make sure to save a back up of all of your important files before you do that.
Nov 11, 2008 | Acer Aspire 5050 5430 Laptop
Error report
  1. You've probably got in your hands some recovery/restore CD's from your PC vendor. BEWARE. For example, Fujitsu laptop CD's are only used to restore the HDD to its original factory state! Fuji will not give you a XP CD to 'recover' the hard disk, only to 'restore' it. Nice huh?
  2. Use a Windows XP retail CD ,better than having to use the OEM's restore CD and lose all your data.
    • IMPORTANT: if you've got Windows XP SP2 installed, you CANNOT use a Windows XP SP1 CD. The recovery console from the SP1 CD will not accept even the correct admin password when run on a Windows XP SP2 HDD. You must run the recovery console from a modern SP2 CD, then you'll be able to correctly login to your Windows XP install on the HDD.
  3. Pop in the Windows XP CD, reboot, making sure to select boot from the CD option. On some PC's you'll have to hit DEL on reboot to enter the BIOS and select boot from CD ROM. Other PCs you hit F12 while booting up.
  4. WIndows XP will start to load. Eventually you will be prompted to select between Setup Windows and Repair Windows. Hit 'R' for Repair Windows. The RC (Recovery Console) will look for existing Windows XP installs to repair. Usually you have just the one, listed by the RC after it has scanned your disk, so type '1'. If the RC doesn't find any Windows Installs...you're in trouble. Note: Windows RC can find a Windows install when Windows Setup can NOT find one, so the RC seems more low level and reliable.
  5. Usually your admin password is blank, so just hit a return when prompted for a password.
  6. Type 'help' for the commands that the RC can run. You won't be able to access any folder other than C:\Windows and C:\ top level. The next two steps are probably only safe if you have a single partition on the whole disk.
  7. Try 'fixboot'. This re-writes the boot record.
  8. Try 'fixmbr'; again, this may damage a partition table that it doesn't understand, so be wary of taking this step... you may want to use this as a last resort and only if you have a single partition on the disk.
  9. Run CHKDSK /P C:
  10. If you get errors still, rerun or also do a CHKDSK /R C:.
  11. If the CHKDSK finally succeeds without errors, then you should be able to exit from the RC and reboot OK.
Feb 11, 2008 | Computers & Internet
Computers & Internet Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
