Question about Kenmore Dishwashers
Dishwasher won't start. Green light beside 'Clean' flashes repeat
Washed one load....loaded another to wash and nothin will happen. The green light that is next to the word 'Clean' is continuously flashing...actually- its in sequences of 4 - if this matters. it usually comes on at the end of a cycle to let me know the cycle is done. i have tried almost everything, even cuttin power to try and let it reset. the only thing it will do is, when i push cancel and close the dishwasher- is drain. but there is no water to drain...help!! i called a local repair man and he says the whole control board/push button panel is blown and i need a new one. im tryin to figure out if there is another solution. its only 2 years old.
    President:
  • 1,314 Answers
I checked the whirlpool tech line on this it said call for service check heating circet check your warrenty for 2-5th year warrenties some parts like control bd touch pads are under extended but youll have to use a kenmore autherized tech sorry
Posted on Feb 12, 2009
Kenmore dishwasher won't restart, green light flashes 7 times
Unless you have already tried the fix on this site, please see if you can reset your dishwasher. It appears to be linked to dishwasher not being able to heat water to correct wash temperature.
http://www.appliancerepairlesson.com/dishwasher-2/dishwasher-clean-light-blinking-7-times/
Apr 29, 2014 | Dishwashers
Dl and F flash when I'm trying to start the cycle...
sorry for the delay in getting back to you. you have a bad door latch mechanism on your washer that needs to be replaced.
Dec 28, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Green light is blinking --says clean when you push
Hello & Welcome to FixYa
Flashing green light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Jun 10, 2011 | Kenmore 16764 Dishwasher
The green light for "clean" is blinking green and
Flashing clean light is reset by pressing two buttons in sequence 3-4 times, to reset your kenmore press these buttons in sequence:
Kevin
Mar 07, 2011 | Kenmore 24 in. 17482 / 17484 / 17489...
The green clean light is flashing. It will not go off even when we press cancel. The wash cycle was not completed. The model # is 665.17283400.
The green clean light means that your dishwasher isn't heating the water. Go to the link below to see how to reset the error code and check for reasons that the error happened.
Good luck
Mar 05, 2011 | Kenmore Dishwashers
Flashing green ''clean'' light and will not start a wash cycle.
the computer senced that the heater did not work last cycle. Push your sani clean, energy saver button s back and fourth a few times. It will run a self diag cycle. let it run for a few min. If it happens again your heater may have burned out.
Nov 11, 2009 | Kenmore Elite 45986 Front Load Washer
Blinking clean light
If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cycle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Jan 21, 2009 | Kenmore 24 in. 16293 Built-in Dishwasher
Clean light flashes constanly. Won't clear out to start new cycle
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
Jan 03, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Clean light keeps blinking and I can't start a new cycle
Puppa, clear the fault by pressing the keys in this order: high temp scrb--air dry--high temp scrub--air dry. Or, depending on your model..Sani rinse--air dry--sani rinse--air dry. The dishwasher will enter the service mode. Let it do it's thing or advance it through it by pressing the start key. The fault came from the board not sensing a rise in the water temp. Make sure to run the hot water before starting the dishwasher. The heating element runs through the nuetral side of the door switch so make sure the d/w is level and the door switches are all making. The element itself could be at fault. Catriver...post back
Apr 01, 2007 | Kenmore 24 in. 15932 Built-in Dishwasher
Dishwashers Logo
129 people viewed this question
Top Kenmore Dishwashers Experts
D. E. Hev
Adam Dower
Adam Dower
Level 1 Expert
Fred Sops
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
