Dryers Logo
Posted on Feb 16, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
NVLR333EVOWW HOW TO GET TO THERMOSTAT
wallycarl86774
Level 2:
New Friend:
  • Expert 108 Answers
  • Posted on Feb 14, 2014
wallycarl86774
Expert
Level 2:
New Friend:
Answers
108
Questions
Helped
16885
Points
134
Hi thermostat are just above heater under steel cover on back
Hotpoint dryer (nvlr333evoww) not heating
hi check heater on back see if it looks damaged if not more than likley thermostats just above
Need to know how to replace the thermostat on a 1996 buick century wagon 3.1 6 cylinder engine
Trace the upper radiator hose to the mounting area on the intake manifold. Loosen the hose clamp on the manifold end of the hose and remove the hose. Pull the thermostat out of the intake manifold.
For more help and troubleshooting go through the help links below:---
Click the link below:-----
THERMOSTAT REMOVAL PROCEDURE/LOCATION DETAILS
Where is Thermostat Located on Saturn
http://technoanswers.blogspot.com/2012/11/where-is-thermostat-located-on-saturn.html
2004 Dodge Intrepid: How to replace Thermostat?
http://schematicsdiagram.blogspot.in/2012/06/2004-dodge-intrepid-how-to-replace.html
How to Replace Thermostat on Audi A4?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-thermostat-on-audi-a4.html
How to replace Thermostat on Acura Car models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-thermostat-on-acura-car.html
Where is thermostat located on 2006 dodge magnum 3.5L?//
http://repairhelpcenter.blogspot.com/2011/10/where-is-thermostat-located-on-2006.html
Thermostat on AUDI 1.9 TDI?
http://repairhelpcenter.blogspot.com/2011/10/thermostat-on-audi-19-tdi.html
How to replace Radiator on Audi and VW car models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-radiator-on-audi-and-vw.html
How to Replace a Thermostat.
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-thermostat.html
How to locate Thermostat on Any car model?
http://schematicsdiagram.blogspot.com/2011/12/how-to-locate-thermostat-on-any-car.html
Where is thermostat on Audi A6?
http://technoanswers.blogspot.com/2011/12/where-is-thermostat-on-audi-a6.html
How to replace thermostat on 1992 Buick century?
http://technoanswers.blogspot.com/2011/12/how-to-replace-thermostat-on-1992-buick.html
Replacing thermostat on 1999 Mercury Cougar?
http://technoanswers.blogspot.com/2011/12/replacing-thermostat-on-1999-mercury.html
Thermostat Replacement on Toyota Corolla?
http://technoanswers.blogspot.com/2011/12/thermostat-replacement-on-toyota.html
Where is thermostat located on 2005 Dodge neon?
http://schematicsdiagram.blogspot.in/2012/02/where-is-thermostat-located-on-2005.html
These will help.
Thanks.
1helpful
MY NVLR333EVOWW HOT POINT DRYER IS NOT HEATING. HOW CAN I DETERMINE IF IT'S THE HEATING ELEMENT?
I worked on one of these not long ago that was tearing up clothes.. Took some pix
I would say take a look at your element for breaks.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
1helpful
2answers
Where is thermostat on my 2005 chevy classic
Thermostat Removal & Installation 2.2L Engine 2004-2005 To Remove:
  2. Remove the thermostat housing-to-water pump feed pipe bolts. chevy_cav_02-04_feedpipe.gif
  3. Remove the water pump feed pipe from the thermostat housing .
  4. Remove the thermostat from the housing.
To Install:
  1. Install the thermostat on the housing.
  2. Install the water pump feed pipe on the thermostat housing with the mounting bolts. Tighten 89 in-lb (10 Nm).
  3. Fill the cooling system.
2006-2007 To Remove:
  1. Drain the cooling system.
  2. Disconnect the radiator outlet hose from the surge tank and thermostat housing cover. Thermostat & cover gm-03-39-3601.gif
  3. Remove the mounting bolts and remove the thermostat housing cover.
  4. Remove the thermostat from the housing. Discard the O-ring.
To Install:
  1. Using a new O-ring, install the thermostat on the housing.
  2. Install the thermostat housing cover with the mounting bolts. Tighten 89 in-lb (10 Nm).
  3. Connect the radiator outlet hose to the surge tank and thermostat housing cover.
  4. Fill the cooling system.
3.5L Engine (LZ4) W/ Variable Valve Timing & 3.9L Engine To Remove:
  2. Remove the air cleaner outlet duct.
  3. Disconnect the radiator outlet hose from the thermostat housing. Thermostat 3.9L gm-03-00-3054.gif
  4. Remove the mounting bolt/stud and remove the thermostat housing.
  5. Remove the thermostat from the engine.
  6. Clean the sealing surfaces.
To Install:
  1. Using a new gasket, install the thermostat on the engine.
  2. Install the thermostat housing with the mounting bolts. Tighten 89 in-lb (10 Nm).
  3. Connect the radiator outlet hose to the thermostat housing.
  4. Install the air cleaner outlet duct.
  5. Fill the cooling system.
  6. Check the cooling system for leaks.
3.5L Engine (LX9) W/O Variable Valve Timing To Remove:
  1. Drain the coolant.
  2. Disconnect the radiator hose from the thermostat housing. Thermostat 3.5L gm_mv_ven_tstat.gif
  3. Remove the mounting bolt/stud and remove the thermostat housing.
  4. Remove the housing gasket.
  5. Remove the thermostat.
  6. Clean the mating surfaces.
To Install:
  1. Install the thermostat on the engine.
  2. Install the thermostat housing and gasket with the mounting bolts. Tighten 18 ft-lb (25 Nm).
  3. Connect the radiator hose to the thermostat housing.
  5. Check the cooling system for leaks.
2answers
Replacing the thermostate
drain out coolant in a drain until below thermostat level follow radiator hose to engine cylinder block to thermostat housing.remove thermostat housing than remove thermostat.replace with a new o-ring on thermostat before installing new thermostat.make sure thermostat housing surface and engine block surface clean.before installing new thermostat.
Need to find where the thermastat is on a 2003 cadi
It is in the rear of the engine by the firewall and the intake manifold will need to be removed to gain access t it.
Engine Coolant Thermostat Replacement (LA3, LY9) Removal Procedure
  1. Remove the thermostat housing. Refer to Engine Coolant Thermostat Housing Replacement .
  3. Complete the following in order to remove the thermostat from the thermostat housing:
  4. 2.1. Depress the ears on both sides of the thermostat. 2.2. Rotate the thermostat until it clears the retaining feature of the housing. 2.3. Release the pressure from the thermostat. 2.4. Pull the thermostat from the thermostat housing.
Installation Procedure
  1. Complete the following in order to Install the thermostat into the thermostat housing:
  2. 1.1. Align the thermostat pin to the thermostat housing orifice. 1.2. Depress the ears on both sides of the thermostat. 1.3. Rotate the thermostat until it aligns with the retaining feature of the housing. 1.4. Release the pressure from the thermostat.
  3. Install the thermostat housing. Refer to Engine Coolant Thermostat Housing Replacement .
1helpful
Hotpoint nvlr333evoww runs but clothes will not dry
there is chance that the heating element has gone bad but the first things to check are all your thermal fuses inside the cabinet of the dryer. They should all have continuity and the one that does not have anything then it needs to be replaced
3helpful
Model NVLR333EVOWW Not heating up
your element has burnt in half where the sparks are coming from is the end of the element touching the metal. You need the model and serial number go to the nearest appliance parts supplier and get a new element they aren't that hard to replace. Always make sure you disconnect the power source before doing any repairs to the dryer. Good Luck
Dave
1helpful
Dryer is working but won't heat. Its just blows cold air. Help please the model is a hotpoint dryer nvlr333evoww.
Thermostat controls heat. There is also a
motor centrifulgal switch, in the element
circuit, that the motor closes to insure
the motor is turning. Try another heat
setting. There is more than one
thermostat. You may have blown the
'thermal fuse' too, whcih requires
replacemant.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 05, 2009 • Dryers
4helpful
2answers
HotPoint Dryer Model Number NVLR333EVOWW not getting hot
Set the timer one day, later clothes not warm at all, dryer still running and timer had not moved. It has never heated up again. Can you help me figure out the problem? Where all the heating elements, thermostats etc may be. thank you for your help.
Top Hotpoint Dryers Experts
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
