Question about Kenmore 24032\24036 Top Load Washer
Water keeps coming in past full
Water flows over top turned to spin to empty
    President:
  • 1,902 Answers
Your water inlet valve is not closing causing your water to over flow. Also check your flow switch to make sure that it is still good also. The inlet valve and flow can be found behind the knobs up top. If you are satisfied please rate
Posted on Feb 12, 2009
Yes it is normal just no hot air
1. When setting the temperature to MAX, blower level to FULL and outside air Vent CLOSED, no hot air comes out after 2-5 minutes?
If YES, when did you last flushed your radiator and is it full?
2. if more than 5 years ago, flush radiator system, instructions are usually in Owners manual. Use a bottle of Radiator cleaner, run egine hot for about 10-15 minutes, carefully open petcock in bottom of radiator to flush out radiator, WARNING, careful as flushed coolant would be boiling hot. As sson petcock is open and water start to flow out, carefully open radiator cap to enhance flushing flow. Use garden hose to fill radiator while flushing until water coming out from petcock is cold and clear.
Once clear, start engine, turn heter full and blower full blast and keep hose in radiator flowing full, leave petcock open until clear water flows out again. Once clear waters comes out, turn off engine,turn off garden hose and let water drain empty radiator. Once it stops flowing out, close petcock snug and put radiator cap on, pull off radiator coolant catch bottle, clean bottle for any debris and dirt. Drain any water, leave bottle empty and put it back onto its place.
3. Fill radiator with 1 gallon (4L) of concentrated coolant, top up radiator until full, fill catch bottle with concentrated coolant, start engine and keep it overflowing until no bubbles comes out and the radiator is fully hot. Once it is flowing good, close and connect everything. Drive with it and keep catch bottle filled as necessarry.
Good luck. Give as vote and good comment if this advise solve youor problem. Thank you.
Jan 05, 2011 | 2000 Chevrolet Suburban
My washing machine overflowed and would not drain. When it is on water keeps coming in even though the machine is full iof water but there is no movement of the agitator and I could not get it to...
H i there.....sounds like you've got either a failed water inlet valve....or a disconnected /ruptured capillary hose from the pressure switch to the tub....or a failed pressure switch........turn water to appliance off.....turn program selector to drain or drain /spin..is drain pump running...if not it may be blocked or burned out....or with machine empty of water.....turn program to spin....if no spin...check motor....
regards Sir Galahad
Aug 21, 2009 | Washing Machines
Hotpoint aquarius wma58 1400. Full of washinh. Full of water.
pull your washer out. put near door if poss then put the waste pipe down to floor level to empty the water. if there is to much water in the drum it will not spin try your pump
Jun 21, 2009 | Washing Machines
Machine will not switch to drain and spin cycle
If you take the front off in the lower right you will find a pump motor that controls the drain flow. This may defective. Use a shop vac to empty the water in washer if needs be. But remove and test this pump.
Apr 16, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Washer won't drain.
hi, to empty water manualy, lift the hose from the stand pipe, keep it above the water level, place a bowl on the floor and lower the hose into it, the water should drain out, to stop the water flow lift the hose above the drum and empty bowl, continue until empty, hope this help, thanks for using fixya
Feb 14, 2009 | GE WBSR3140DW Top Load Washer
Water in my washing machine
it sounds like you have a leaking water valve, you will have to replace the mixing valve, For now turn the water off at the wall suppling water to the machine. When you want to use the washer turn on water, when its done with the cycle turn the water off.
Note: unplugging the machine will not stop the water from running
May 13, 2008 | Amana 3.2 cu. ft. Top-Load Washer
Avanti W797: Tub won't spin or water does not empty.
Had the same problem. The water pump is not working and since it cant drain water it wont spin. A easy fix. There's a magnet located on the water pump thats comes lose. Simply tie it back into place.
Nov 20, 2007 | Avanti Top Load Washer W797
Will Wash, but not discharge water nor spin.
the lid switch is broken PLEASE rate my help!! Thankx
Oct 03, 2007 | Whirlpool LXR5432KQ Top Load Washer
Washing machine
you almost certainly have a blocked filter .Unplug the machine , take the screws out from the back you will see a black hose coming from the tub to the pump, this is the filter if the machine is still full of water get yourself a washing up bowl and lower the grey waste pipe into the bowl and gravity should let the water out, raise the pipe when bowl is full.If no water comes out like that tilt the machine forward and put the bowl under the black hose undo the clip with pliers and slowly take the hose off water will flow when full push hose back up and empty the bowl keep doing this until empty , then remove blockage. Getting someone to hold the machine while you do this will be much easier.
Sep 05, 2007 | Hotpoint Aquarius WD63 Front Load...
Kenmore 24032\24036 Top Load Washer Logo
62 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
