Question about Goodman GMS90703BXA Heater
Goodman heater not turning on
I have had issues with the pressure switch pluggin up, whichi is what happened today, i unplugged the wires from the switch, and unclogged the hose, but now the heater wont turn on at all. I can override it nd it runs fine.
    President:
  • 1,902 Answers
If your pressure switch is clogging then you need to check the flue pipe make sure it is not rusting. If it is the flue should be replaced and also think about replacing the pressure switch. Check your high limit switch also. If the pressure switch goes sometimes it pops the high limit
Posted on Feb 12, 2009
I have a goodman modle gms80703ana and at first the inducer fan would kick on in it's normal cycle then the furnace would shut off do to a pressure switch. Now the inducer fan only come on perodicaly...
First unplug your furnace to reset it then plug it back in with thermostat set to heat high enough to make the heat come on. As soon as the inducer motor came on you JUMP the 2 wires that go to pressure switch. Your igniter should come on and gas valve should open for heat. If the flame stay on the blower should come on after a few minutes. If it get to this point your problem could be pressure switch itself or inducer clogged.
Jan 30, 2014 | Goodman GMS807034ANA Heater
I just put a pressure switch in it still dont come on i unplug one wire it will run and work
There might be a plug somewhere in your system. It could be in the venting or condensation hoses if you have a high efficient furnace.
Nov 30, 2013 | Goodman Heating & Cooling
Goodman GMP100-3 igniter will not ignite
Hello, verify if the igniter is receiving a 120 volts from the control board after the pressure switch closes. Sometimes a faulty control board can cause this problem if the igniter and pressure switch are good.
Oct 13, 2012 | Goodman GMS90703BXA Heater
I am having issue with my Goodman airflowing heater system. I have changed the theromstat since my previous one seems to have messed up. Now I am having issues with my heater turning on and staying on even...
Hello, this could be a control board issue with the relay on the board sticking and in that case the board must be replaced, or the thermostat could be wired incorrectly.
Feb 10, 2011 | Goodman GMS90703BXA Heater
When I turn on the T-stat to call for heat the inducer fan does not operate. Is it my pressure switch stuck closed?
If you unplug one of the wires going to the pressure switch, it will think it's open. Once the inducer comes on, plug it back in and it should read "closed". That should answer your question.
Mar 13, 2010 | Goodman GMS90703BXA Heater
Goodman gmt or gmth not igniting burner. We have
First pull wires off the pressure switch and put a jumper wire in, if it lights bad switch. If it doesn't light, bad ignitor.
Jan 04, 2010 | Goodman GMS90703BXA Heater
Goodman GMP075-3 Random Incomplete startup
If the draft motor starts then shuts right off and then a red light comes on usually means that there is a blockage somewhere. Check the pressure switch line, make sure that it is clear and the hole in the heater that the pressure switch vaccum line runs to is open. If that checks out then make sure that your flue vent cap is on and that it is not pressed down on the flue vent and that the gases can vent properly
Feb 13, 2009 | Goodman GMS90703BXA Heater
Circuit board light blinks 3 times heater will not turn on
The error code refers to a defective combustion air switch. Coleman Evcons made around 2007 had defective pressure switches or as they call them "combustion air switch". Replace it and the problem is gone.
Dec 13, 2008 | Goodman GMS90703BXA Heater
Goodman GMP075-3 ignition problem
OK, if the furnace is not lighting for even a few seconds, you have either a bad gas valve, bad wire, bad control module or no gas. The pressure switch is not the issue. Check all wires to the gas valve and look for 24 volts across them when the ignitor glows and you hear the click. Then test for 24 volts to ground. It could be a bad ground wire.
Sep 28, 2008 | Goodman GMS90703BXA Heater
Goodman GMS90703BXA Heater Logo
261 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
