My acer monitor AL1912 just stopped working. It doesn't have a picture. I have checked all hookups and connected it to a different computer and it still didn't light up and work. The green power light was on but nothing is happening. Is there a way to fix the monitor myself, or is there a quick fix out there somewhere?
    President:
  • 2,110 Answers
There might be problem with your VGA cable..try to change the cable...
Posted on Feb 12, 2009
I have an acer AL1912 and a (auto config please wait) gray box keeps popping up,how do i stop it
If it gives you message about the resolution, set the computer to use native resolution of the monitor. You can change the resolution by right clicking on desktop and choosing "screen resolution".
Dec 27, 2013 | Acer AL1912 19" LCD Monitor
I use Acer AL1912 19inch (black) monitor. It is working properly for weeks. but sometime it suddenly go dark during work, although its light remains green. Now the only solution is to unplug its power...
Sounds like the monitor is dying, if it starts to die more and more often you will likely have to replace your monitor before it goes completely out. There are not many ways for a user to repair a monitor, unless the problem is with the computer, which you could test by connecting a different monitor to the computer for a while (if available). Hope this helps!
Mar 15, 2011 | Acer AL1912 19" LCD Monitor
How can I connect my Fujitsu Siemens key board with my Acer AL1912 monitor? There is a connect button on the key board, but where is the connect button on the Acer?
Is it a wireless keyboard? If that is the case, then you should have a receiver unit attached to the PC, usually to a USB port. The ACER is justt a monitor, here is the user manual: http://www.retrevo.com/support/Acer-AL1912-Monitors-manual/id/719ag115/t/2/
Jan 20, 2010 | Acer AL1912 19" LCD Monitor
Any Drivers for ACER AL1912
With very few exceptions, LCD monitors do not require a driver. Almost always, and display setting issue is an issue with the Display adapter (Video Card) driver. The plug and Play monitor driver that is native to Windows should work just fine.
Jun 13, 2009 | Acer AL1912 19" LCD Monitor
My acer AL1912 monitor keeps going fuzzy. It kind
An unusual problem for a flat screen monitor.
I suggest you connect the monitor to another PC to see if the problem persists since it could also be caused by the video card (or circuit, if on board).
Check your cables making sure they are solidly connected and wiggle them to see if you can cause the problem to come or go away; this would crudely check the shielding of them.
This kind of aberration could easily happen with a conventional CRT monitor if power supply filtering was failing but as mentioned, uncommon in a monitor that is essentially digital.
May 12, 2009 | Acer AL1912 19" LCD Monitor
I have a acer al1912 faulty
It might be worth a try but the two different sizes could have differing resolutions and if they do, the boards are not likely interchangeable.
Jan 29, 2009 | Acer AL1912 19" LCD Monitor
No display
Your minitors power supply is now damaged, probably from the power outage. I t will need to be repaired or replaced. Check the cost and benifits of both options and make a discision.
NSSMS
Jul 30, 2008 | Acer AL1912 19" LCD Monitor
Acer al1912 with S3inc trio 32/64 card
start with a 1024x788 60hz refresh , connect lcd
and then try any higher freq/refresh as it will ask you to verify.
Nov 02, 2007 | Acer AL1912 19" LCD Monitor
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
