Question about Sharp AQUOS Blu-ray Disc Player
Sharp Aquos BD-HP20 Power Supply - Burned Out Cap C911
Hello, after hearing a pop and seeing some smoke come out of my BD player I promptly unplugged it and opened the case to start troubleshooting. The only thing wrong (from what I could tell) was that capacitor C911 on the power supply card (just downstream of the rectifier D901) had broken down. Visibly bulged, very hot, etc. I carefully removed the power supply card from the BD player and desoldered the capacitor in question. Later it had disappeared. I suspect someone else in the house may have thought it was trash and threw it away before I was able to record the rating data on the component. Could someone please simply tell me that capacitor's ratings so I can get a replacement and get my device in working order again? I just need to know the capacitance value and the voltage rating. Thanks!
  • 50Hz_Shuffle Feb 12, 2009
    Thank you Jaime867, you're the best! Now on with the shopping and repairs!
  • 50Hz_Shuffle Nov 29, 2009
    Thank you so much, I managed to pull one from my stockpile of spare parts.
    I found the root cause of the problem: a 1 watt shunt resistor had shorted internally, causing an overcurrent. This vented the cap, blew the fuse, and opened the smaller input filter. After checking other components on the primary side, I replaced all the appropriate parts, and it works fine now!
  • 2,326 Answers
The capacitance of the capacitor C911 is 330uF/200 volts.
Posted on Feb 12, 2009
I want to buy a remote for my BD-HP20 blu ray player where can i get one from
Just bought one used on e-bay for $28 9/15/2010, new is about $45 I think. I called Sharp and new = $55 after shipping.
Sep 12, 2010 | Sharp BDHP20U Blu-Ray Player
I updated my Sharp AQUOS BD20 with latest firmware recently. It played the disc that told me the player needed firmware update, but now it seems to take about 5 minutes to read a disc - if it reads it. It...
this same thing is happening to me. It took forever to load Toy Story 3 (10 minutes?) and I've been waiting over 15 minutes for Robin Hood to load - I don't think it is going to. Sharp BD-hp20, new firmware.
Aug 20, 2010 | Sharp Televison & Video
I have a Sharp BD-Hp20 and i already got the firmware update and still cannot watch Avatar Bluray please help.
Make sure that you do have Version HU9071500 installed--->press setup button------>settings-------> version. If it is installed then after you insert Avatar it takes between 8 and 10 minutes before you can select play movie.
May 09, 2010 | Sharp AQUOS Blu-ray Disc Player
The dvd drawer on my BD-HP16U is stuck in closed position. The screen display "hold" when I push the eject button.
Try inserting a small pin through the hole beneath the insertion cabin, after pressing the eject button. If you don't have such a hole, Push the eject button and tap hardly on the top of the player. The drive will come out in two or three attempts.
Apr 13, 2010 | Sharp AQUOS Blu-ray Disc Player
I downloaded the firmware update for my sharp bp-hp20 blue ray player but my player won't recognize the file on my memory stick. Any suggestions?
There are usually two reasons that this happens 1. is that the file needs to be extracted first to the root of the drive ie. not in any folders. 2. is that some of the older sharp products won't reckonize any usb memory larger than 1GB. As is the case with my 52' Sharp AQUOS Special Edition LC-52SE94u TV. Could not read a 2GB Kingston, but reads the 1GB Kingston just fine to update firmware. And Sharp doen't tell you this not even in the online how to firmware update page.
Hope this solver you problem,
Scott
Mar 21, 2010 | Sharp AQUOS Blu-ray Disc Player
Need firmware update
Download the file from here
Then upload the file to flash drive/thumb drive ( it has to be usb 2.0 , formatted FAT, capacity 1Gb or below)
Stick the drive into BD player.
Select setup>firmware upgrade.
Follow on screen instructions.
Nov 16, 2009 | Sharp BDHP20U Blu-Ray Player
How to update soft ware on my blu ray dvd sharp aquos bd-hp20
here is the link for Sharp BD players.download and follow intructions that are with the file
http://support.sharp.net.au/drivers/
Apr 21, 2009 | Sharp AQUOS Blu-ray Disc Player
I've downloaded a firmware update for my Aquos BD- HP20 Blu-ray player.  Unzipped the zip file and I put the .RVP file onto a Sony memory stick but when I try to get the player to recognize I file on the...
today i solved following errors on sharp blu-ray hp20 when updating software to play quantum of solace:
can't detect software: due to .rvp file being inside a folder--not in root directory on usb stick
more than one software file detected by player: .rvp hasn't been properly unzipped. the 2 gb disc and, as far as i could tell, my system (imac os 10.5.6) showed successfully extracted SINGLE file ready for transfer to dvd player, but dvd player said that there was more than one file. erased the 2 gb disc with disc first aid utility as part of exercise. also verified FAT format on 2 gb disc. only after i used a downloaded free mac utility *specifically for extracting ZIP files* to transfer the .rpv file to the 2 gb disc did the dvd player recognize the file and i successfully updated the player's software! (sorry for the run on, i think the logic is accurate)
Jan 29, 2009 | Sharp AQUOS Blu-ray Disc Player
Sharp AQUOS Blu-ray Disc Player Logo
390 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
