All of a sudden the other day I can't upload or download. I connect and time out. Those that try to connect to me have a status "waiting for incoming connection" and then time out. It takes a long time to get a 2ndary network connection. Nothing has changed on my pc or my router.
A good suggestion though DHCP would have no bearing unless the router were handling more than one PC or the router were for some ungodly reason assigning random IP numbers to the only PC connected? ;-)
If Mike has a LAN running, then static IP assignment is recommended, though not absolutely required, so that the router keeps the right port assignments with the right PC.
I use dynamic addressing in my 3 PC LAN and usually run MX only on one PC (although on occasion two PCs). Typically, one machine runs here 24/7, so it's IP remains the same from the router, 192.168.1.100. The others are assigned 101 and 102 in the order they are turned on (which is also reasonably constant, as one is a portable). Unexpected things happen though, and every once in a while the main machine will come up second, if rebooting while two are running. It's easy to notice and simple to fix by calling up the router admin page and switching port numbers between the machines. No reboot nor restart of MX is necessary.
I don't have any reason for operating this way except extreme laziness;-0)
BJ
Was this solution helpful? Show your Appreciation by rating it:
Show your appreciation by commenting on can't connect:
Solution #2
posted on Aug 01, 2007
Mini Me - usenet poster
Rank: Apprentice Rating: 0%, 0 votes
I am using dhcp on my pc and the ip addresses are the same:-( The router I have, D-Link DI-711, doesn't have much in the way of configerable port rules. I can specify open ports by type but not port number so eg I can open the firewall for TCP ports, or Telnet ports or similar or open it for all ports which I am not mad keen on doing.
The symptoms are changing. Now I can get some up and down loads. Nothing has changed in my settings. However I now notice that I am not staying connected very long. It's as though there is hardly anybody to connect to.
I've also noticed a lot of other posts from people having problems. -- Mike Lewis
Solution #4
paulrmc - usenet poster
I doubt it's a block. I can search, q up, and sometimes dl a bit. I got quite a fast dl this morning. But mostly they don't connect when started. All of the people trying to dl from me fail to connect.
-- Mike Lewis
