Question about HP LaserJet 4350 Printer
  • ybnorma59718 Feb 12, 2009
  • John Cole
    John Cole May 11, 2010
    that fold does it look like its pressed down or kinda loose
  • 237 Answers
The reason why i ask that because if the fold looks like its been pressed then its before the fuser but if its loose than its after. And thats how we can determine where it begins
Posted on Feb 12, 2009
  • John Cole
    John Cole Feb 12, 2009
    Ok since the crease is pressed it is before the ink is permanently put on the page so look to see if there is anything obstructing it on that left side or it could be possible that the fuser is what is causing it.
I have an epson printer and when I hit print, the paper slides right thru & says paper jam
  • Carefully remove the jammed photo paper. Gently pull the paper up and out of the paper feeder tray.
  • 2
    Reload the paper into the tray. Stack the paper on a flat surface and then carefully slide the paper stack straight into the paper feeder tray---along and aligned with the right side of the tray. Secure the stack in place by sliding the left "edge guide" against the paper stack.
  • Sponsored Links
  • 3
    Press the "OK" button to resume printing. If you had a "Paper is jammed in the printer..." error message displayed on the control panel LCD, pressing "OK" should also clear the message.
  • 4
    Pull the paper from the printer, if the status message reappears and/or the printer doesn't print, and check the paper for folds, buckling and curled edges or corners. Also check the sheets for sticking. If any of your sheets stick or have damage, remove them from your photo paper stack and replace with new sheets. Reload the paper and press "OK" to try again.
  • Performance Chip
    May 22, 2012 | Epson NX415 All-In-One Printer
    Have a jam error. paper folds in front of print roll
    Start a print from tray 1/manual feed and just as the trailing edge of paper is entering the machine; quickly open it to stop print and take out the cartridge and look at the drum and the paper underneath. If the issue is there at that point then it would point to the cartridge. If not then it is in the fuser area.
    Mar 31, 2011 | Xerox WorkCentre XD125F All-In-One Laser...
    I have a IBM 9068 Model S01,it is sometimes showing error code 18.If I tilt up the printer assembly during the printer power on it is ok.If I tilt down the printer assembly meaning to it's original...
    Error 18 is a "Paper Edge Search Error".
    1. Check document for damage and check it meets specs.
    2. Check that Ribbon Cartridge is installed correctly.
    3. Do "Form-Edge Sensor Service Check"
    4. Do "Platen" adjustment.
    Sensor Status Display:
    . Start Self-Test (press and hold Start 1 on panel: then turn on printer. Keep holding button until at least "00" is displayed.
    2. Use a magnet to override cover closed/open sensor to the left of the Start1 button in the indent.
    3. Press Reject Off button until "4" is displayed.
    4. Press Start1 button to shift to next digit.
    5. Press Reject Off to display "4"
    6. Display should now read "44"
    7. Press Start2 button. The LED display indicates sensor status'
    8. You will see changes with inserting paper or removing paper.
    Perform sensor status display as stated above. The sensor is located on the print head carriage on the left side.
    1. The upper right vertical segment of the left LED digit is assigned to the form-edge sensor for Command "44"
    With no paper the LED segment is unlit.
    2. Check the sensor by inserting paper. Move the print carrier to the right to access the sensor mounted on the print carrier.
    If the LED segment becomes lit when you insert the paper, and becomes unlit when you remove the paper, sensor is OK.
    3. If the sensor does not work, check that the sensor cable is connected correctly. If the cable is okay, replace the following one at a time:
    a. Form Edge Sensor -46H2648
    b. Form Edge Sensor Cable -46H2730
    c. Main Card -
    1.46H2632 - Serial Interface
    2.46H2634 - Parallel Interface
    Mar 28, 2011 | IBM Office Equipment & Supplies
    How do I print on both sides of the sheet?
    If you print to an IS networked printer the printer will automatically print on both sides of the paper (duplex). This saves paper but, because it is print toner which is the largest part of the cost, charges are the same as printing on two sheets of paper.
    If you wish to print duplex to another printer (NB not all printers support duplex printing) you must:
    Office 2007
    • Open your Office Document
    • Click on the Office button in the top left corner of the screen officebutton.gif
    • Click Print and select one of the printers that will perform duplex printing
    • Click on the Properties button under the Layout tab
    • Choose either Flip on Long Edge or Flip on Short Edge and click on OK If your page is set up as Portrait
    • Choose Long Edge If your page is set up as Landscape
    • Choose Short Edge . Click on OK again to send your work to the printer
    Other Applications
    • Go to File and Print
    • Select one of the printers that will perform duplex printing
    • Choose Long Edge if your page is set up as Landscape
    Please post your feedback and Vote if the problem resolved as per your satisfaction.
    Jul 02, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
    At college we have a w7200, how can we print across the paper rather than down it, for example a panoramic image across the width of the paper and say 20cm high
    Try selecting LANDSCAPE as opposed to PORTRAIT by using the proper print menu in your application rather than the simple print icon from most tool-bars.
    You can usually find it in the FILE menus
    Apr 20, 2010 | Canon imagePROGRAF W7200 InkJet Printer
    We use a Lexmark E332n laser printer at work. When someone attempts to print something, the printer jams with a problem with the paper feed coming out of the tray. It essentially folds up on itself and...
    try cleaning the feed wheels with a arisole electronic contact cleaner these get a glue composite build up on them and contact cleaner will remove it with out leaving behind any residue and make sure that the paper guides in the tray are not set against the paper to tightly. i have also seen these pick wheels (the rubber tire) be so loose on the shaft that they slip causing this problem.
    Nov 19, 2009 | Lexmark E332n Laser Printer
    Service Manual for disassembly
    HP Photosmart C7280 printer gets into a paper blockage mode that appears to be from its own mechanical parts - leaving 1.2cm wide indentations on the leading edge of the paper on its top left side starting at about 2 cm and sometimes also 7 cm from the corner. Happens in copy and print modes. Is there a fix for this problem?
    Apr 22, 2009 | Office Equipment & Supplies
    L7780 won't print on edge of paper
    it could be the printer settings. Before you actually print something go to File>print:- and then choose properties, click on advanced and ensure that the correct paper and size is set to how you want it.
    Oct 28, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
    Envelopes and labeles
    Go the "print" dialog and select "settings". Ensure that the paper size, margins and orientation are not set for 8.5x11.  You did not mention the software you are using to print the envelopes/labels so this is the only guess I can give.   I have seen software that made me have to override the settings before.
    Oct 15, 2007 | Samsung ML1740 Laser Printer
    My printer folds top lefthand corner intermittently? why?
    Do you run labels through the unit? If so, ther is probably a little bit of the glue or label that is inside the feed asm. Hard to find it. Have you tried to open the top door when the paper has fed just under the toner cartridge to see if the bent edge begins at that point. Did the problem appear right after the new maintenance kit? Do you still have the old fuser asm? Reinstall the old fuser and see if problem goes away.
    Jul 31, 2007 | HP LaserJet 4250n Printer
    HP LaserJet 4350 Printer Logo
    214 people viewed this question
    Ben Johnson
