Question about Texas Instruments TI-83 Plus Calculator
Screen Displays nothing
Hello
I have a TI83 plus and the screen does not come up at all. I have tried to adjust the contrast and reset it via removing one battery and holding delete. I can plug in the calculator in to my computer and reload the OS no problem, but still nothing on the screen. Is it possible to physically replace the screen for this calculator? Please, if anyone has any advice it is very much appreciated.
  • 4 Answers
If the screen in busted its easier/cheaper/quicker to buy a new calc on ebay for $20.
Posted on Feb 20, 2009
TI 92 Turns on but has a black screen.
This is expected behavior when batteries are replaced and you don't need to reset the device, simply adjust the contrast more than you would think it should take.
See the answer to a similar question at When powered on the LCD screen is dark blue.
Jun 23, 2012 | Texas Instruments TI-92 Plus Calculator
I changed batteries and now the screen is black. How do I fix it?
Hello, it sounds like your contrast needs adjusting. Turn your calculator on; press the "2nd" key and down. The contrast should adjust.
Happy calculating
Jul 31, 2010 | Texas Instruments TI-83 Plus Calculator
The screen of my ti83 fills with pixels when turned on. Can this be fixed?
there is one choice for you to do push 2nd +7 then 4 then 2 this will reset the whole caculater. if it stills does the same thing then it probly need to ne replaced..
Apr 14, 2010 | Texas Instruments TI-83 Plus Calculator
How do I reset it to the factory settings?
Hi
To reset the Ram, press [2nd][MEM][7:Reset][1:All Ram][2:Reset] Press the [CLEAR] button to erase the "Ram Cleared" message.
Occasionally, one has to adjust the screen contrast.
To adjust screen contrast
  1. Press [2nd] key and release it.
  2. Press and hold
  • Up arrow to darken the screen, or
  • Down Arrow to lighten it
Hope it helps.
Dec 09, 2009 | Texas Instruments TI-83 Plus Calculator
The screen on my TI-86 calculator is black when I turn it on. What do I do?
You can adjust the contrast on the screen of your TI86 by following the procedure below.
Adjusting the Contrast
1 Press and release the yellow [2nd] key.
2 Press and hold UpArrow or DownArrow (above or below the half-shaded circle).
¨ To darken the screen contrast, press and hold UpArrow.
¨ To lighten the screen contrast, press and hold DownArrow.
Hope it helps.
Nov 04, 2009 | Texas Instruments TI-83 Plus Calculator
I changed the batteries and now it will not come on
Here it is from the horse's mouth (TI Knowledge base)
For the TI-83 Plus Family, TI-84 Plus Family:
Caution: The resets described in these troubleshooting steps will cause a lossof applications, programs and data. If at all possible please create backup using TI Connect™ first.
  1. Try a new set of AAA batteries.
  2. Adjustthe contrast by pressing and releasing the [2nd] key followed bypressing and releasing the up arrow; repeat as necessary. To adjust orlighten the display, use the down arrow.
  3. Remove one of theAAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR],reinsert the AAA battery and then turn the calculator on. Thecalculator should display the message "RAM Cleared". Release the [CLEAR] key and then press it one more time to remove the message.
  4. Removeone of the AAA batteries. Press and hold the [DEL] key. While holding[DEL], reinsert the AAA battery and then turn the calculator on. Thecalculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI83 or TI 84 Plus family to reinstall the calculator operating system (see below.)
  5. Removeall of the batteries including the round lithium battery for 5 minutes.After the 5 minute period, reinsert all of the batteries and turn thecalculator on. Adjust the contrast if necessary.
Reinstalling the OS for the TI83/TI84 Plus family
How do I correct the Error Waiting...Please Install Calculator SoftwareNow message on my TI-83 Plus family or TI-84 Plus family calculator?
If an operating system (OS) update fails or is interrupted, the calculator will be in an inoperable state with the message Waiting...Please install calculator software now.The most common cause of a transfer being interrupted is updating theoperating system on a calculator with low batteries. Users will need touse the TI Connectivity cable and the TI Connect software to send theoperating system to the calculator. Make sure to have the latestversion of TIConnect installed on the computer.
In order to install the software please follow these steps:
1. Connect the TI Connectivity cable between the computer and the calculator.
2. Click on Start >> Programs >> TI Tools >> TI Connect >> TI OSDownloader
3. Follow the on-screen directions to reinstall the calculator's OS.
Ifthe message "Error! Press any key to turn unit off. Then turn unit backon." appears on the graphing calculator, quickly, remove one batteryfrom the calculator and reinstall it while the transfer is taking place.
Hope it helps.
Oct 11, 2009 | Texas Instruments TI-84 Plus Calculator
When i try to graph something on my TI-83 Plus, the screen fades to pitch black and then it says INVALID DIM
Reset the RAM to clear old settings that interfer with your new problem
[2nd][MEM][7:Reset][1:All Ram][2:Reset][ENTER].
Press [CLEAR] to clear the screen.
After a memory reset you may have to adjust screen contrast.
To increase contrast (darken the screen)
2. Press [UpArrow] key and release it.
3. Repeat sequence until screen darkens enough.
2. Press [DownArrow] key and release it.
3. Repeat sequence until screen lightens enough.
Hope it helps.
Oct 07, 2009 | Texas Instruments TI-83 Plus Calculator
Problm
Press [CLEAR] button to clear the screen. Try to reset the calculator to defaults as follows [2nd][MEM][7:Reset][2:Defaults].
If screen is too dark or too light, adjust contrast.To increase contrast
2.Press [UpArrow] and release it
3. Keep going through Steps 1 and 2 in sequence until display is adequate.
To decrease contrast do as above and press [DownArrow] in step 2
Hope it helps
Aug 23, 2009 | Texas Instruments TI-83 Plus Calculator
If the numbers are not registering on the screen what is the probability that the calculator is conmpletely busted????
1.Turn calculator on and adjust screen contrast
Press [2nd] , release
Press [UPArrow] release
Repeated the two steps until contrast is adequate.
2. An application may be running.
Press [ON] key several times to interrupt and [CLEAR] Screceen
3. Reset memory
[2nd][MEM][7:Reset][1:All Ram][2:Reset] then [Clear] screen. The blinking cursor should come back on.
Hope it helps. .
Aug 05, 2009 | Texas Instruments TI-83 Plus Calculator
Help on TI83
just change batteries in my ti 83. on the screen the i con i blinking but i can not use the numbers only the function what can i do?
Aug 28, 2008 | Texas Instruments TI-84 Plus Calculator
Texas Instruments TI-83 Plus Calculator Logo
134 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
