My printer jammed.I shut it off and with some difficulty I was able to free the paper. (the paper aadvance key did not work) I the tried to resume printing but it would not respond. I tried a new printing job, but I still get no response. The printer is on and no warning lights are flashing. Help
  • 10,515 Answers
Which O system you are using ?
If vista :)
it sounds as if you have a driver or possible a problem with the USB cable as there has been a lot of issue between Vista and HP drivers since its launch i would start there. uninstall drivers and install using the generic drive that comes pre installed on vista
Posted on Feb 12, 2009
    President:
  • 2,110 Answers
Right click on the printer icon and then check if an option to "Use printer online is avaialble". If not, refresh print spooler service.
Unplug the USB cable of printer from the computer, turn off printer,
Click Start>Run and in the run window, enter services.msc and hit enter.
This will open the services window. In the right pane of the services window, look for Print Spooler service, right click on it and select Restart. Close the services window and then try to set the status of the printer to online (Right click on the printer icon and then check if an option to "Use printer online"), Try to print from the computer.
    President:
  • 1,902 Answers
Unplug the system for 30 seconds then plug it back it, should work. Pleae rate if works
Error e03, but there is no jammed paper
E, 0, 3
Paper Output Tray is closed / Paper jam
Summary
If the Paper Output Tray is closed, open it. The machine resumes printing.
If opening the Paper Output Tray does not resolve the problem, or if the tray was open to begin with, the paper may be jammed. Remove the jammed paper, reload paper properly in the printer, then press the Black or Color button.
E, 0, 3
Summary
E, 0, 3
Summary
Techbelkin
Nov 03, 2010 | Canon Pixma Mp250 Allinone Inkjet Photo...
Got paper jammed pulled it out but now won't work tries but then red flashing and makes a bit of noise
-To clear a paper jam near the paper tray, grip the paper and pull it firmly but gently from the printer. If you find a stack of papers jammed, grab from the middle of the stack and pull.
-For a rear jam, remove the back of the printer. When you find a free edge on the paper, grip it firmly and pull it out.
-Press the "Resume" button or turn off the printer, and then turn it back on. Your settings should reset.
Oct 02, 2010 | Epson Stylus Photo R220 InkJet Printer
Printer will not work after paper jam fixed
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jul 09, 2009 | Canon iP4500 Photo Printer
Error caused by paper jam - but there's no paper jam
the carriage (carriage stalled) in jammed in the right side of the all in one, try slowly free it, also check cartridge status.
(carriage stalled in process of cartridge cleaning)
May 22, 2009 | HP Deskjet F4180 All-in-One InkJet Printer
Paper jammed .....but no paper jammed
Sounds like this is a common problem with these printers. Hopefully, this is a malfunction of the printer that you can remedy.
I'm assuming that you have THOROUGHLY searched the printer for any evidence of paper and/or debris. Have you tried resetting the printer? If this issue is as simple as just needing to clear the error from the printer then a reset should work. (If you still have the manual, it should provide instructions on resetting the printer.) This is the best that I can provide on how to reset it:
  1. Turn the printer off.
  2. Hold the Resume button (red circle in the triangle), add a printer (click Power) an indicator light green.
  3. Hold the Power button and release the Resume button.
  4. NOT releasing the Power button, double click Resume and release BOTH BUTTONS (Power and Resume).
  5. Click Resume four times.
  6. Click Power to confirm the selected action (reset counter absorber). Click Power again to disable the printer.
Please rate this solution or let me know if this was any help.
Mar 27, 2009 | Canon PIXMA MP180 All-In-One InkJet...
Replaced colour cartridge.Resume button flashes constantly.
Found a pen stuck in there. Oops! Thanks for your interest.
Jan 05, 2009 | HP DeskJet 920c InkJet Printer
Printer jams. gray foam released in paper path.
1: Remove Cartridge
2: Unplug the AC Power Cord
3: Hold down the RESUME button
4: Release RESUME after plugging in the AC Power cord.
5: Press the RESUME once within 5 seconds and release the RESUME .
6: Press and HOLD RESUME for two seconds or more and release it.
7: Press and HOLD RESUME for two seconds or more and release it.
8: Unplug AC Power Cord to set data.
Try this I found it doing a search on your machine, that foam was called a blotter, and it should work without it, good luck
Dec 19, 2008 | Canon PIXMA IP5200 InkJet Photo Printer
Paper jammed. Remove jammed paper and press the printer's RESUME button.
give this a try
alternative :
Dec 15, 2008 | Canon PIXMA iP1500 InkJet Photo Printer
Paper jam
hey, give this a shot
alternative :
Oct 19, 2007 | HP OfficeJet G55 All-In-One InkJet Printer
13 people viewed this question
jasbo
jasbo
