I RECEIVED IT YESTERDAY AND HAD NOTHING BUTN PROBLEMS REGERESTING IT HOW DO YOU GET TO MAIN MENU!! OR ANYOF THE VIEWS THY SHOW, THEY SAY IN THE QUICK REFERENCE TO LOOK AT AT ENCLOSED FULL USER'S MANUAL, WHERE IS IT AND OF COURSE THIS IS A WEEK END SO THEY ARE CLOSED!!!!!CAN ANYONE HELP I HAD PLANED TO DRIVE TO SOUTH CAROLOINA SUNDAY
SOURCE: Manual
This is where I found mine at: www.ilohelp.com click on the link "downloads" on the left side, then the second drop menu says "model" choose the 'dvdr04' option. This will take you to the page with the mauals in .pdf format, and all the firmware updates.
SOURCE: protect
The protect message indicates that a problem was found in the output stage of the amplifier. Unless this gets repaired, nothing will work. As a verification that the speakers or the wires are not the problem, unplug all of the speakers and try again. If protect still is displayed, the problem is inside the unit.
Dan
CCD Failure !
Lucky u can get it repaired Free just call Sony in ur region see link
http://esupport.sony.com/US/perl/news-item.pl?mdl=DSCT1&news_id=161
SOURCE: Waste in tank
If you drop the cover the machine will send the cartridge holder across to the far side of the printer
At that point switch the printer off and by using a torch you will see a heap of nearly solid ink which has been deposited by the cleaning blades into a trough where the ink cartridge normally sits.
Pair of surgical gloves and a small lolly stick or wooden spatula normally does the trick
