Question about Lexmark X3550 All-In-One Printer
Lexmark x3550 18C0032 ink cartrage set up.
How do I set up my lexmark x3550 printer to except 18C0032 or 34 ink cartridges rather than the non-refillable 23 cartridge.
    Problem Solver:
  • 9 Answers
The 34 and 35 cartridges will work. You can also buy a 23a or 24a from Lexmark.com and you can refill those.
Posted on Feb 12, 2009
BROTHER P-TOUCH IS not printing
It is obvious it has a failed electronic component, since these are not repaired/exchanged except when they are under warranty best thing to do is just replace it.
Jan 09, 2017 | Brother Office Equipment & Supplies
Bizhub C250 using to much toner. Images are very dark. Ink can even be rubbed off pages. How do you adjust?
Check that the fuser is not in enevople mode. two green handle up not down. check the files
Oct 28, 2016 | Konica Minolta bizhub C250 All-In-One...
My printer brother dcp7065dn disply 71 and72 error
This is codes for the ink cartridge. The code means there is a problem with the cartridge. Change them both and restart the machine.
Jan 13, 2015 | Office Equipment & Supplies
B&w/gray Scanning Is Okay But Color Scanning Problem
Run ink head cleaner routine. If you cannot the list make and model of printer. Thanks.
Dec 25, 2014 | Office Equipment & Supplies
Why is print quality poor after inserting new ink. Copies are faint and have lines
the cartridge is clogged with ink that has dried and reduced the slit. you need to replace the cartridge with a new one. it happens usually if you recharge the cartridge 3 or 4 times with compatible ink.
May 07, 2014 | Office Equipment & Supplies
How to clean ink absorber for canon mp237
First of all open the ink cartridge of your printer.
When the ink cartridge would move all the way over, then disconnect the power cord of your printer.
Now pull the frame of rubber from the printer and remove ink pads.
To clean ink pads you may place them in a bowl having warm water and start rubbing and squeezing them to clean it from ink.
After removal of ink, keep the pads separate for dry.
When the pads get dry completely, place them back in rubber frame.
Reinstall the rubber frame in your printer.
For deep guide and support refer to-
Canon Pixma Mp237 Manual
Oct 07, 2013 | Canon PIXMA MP230 Multifunction color...
Hp laserjet m1522f error 5 turn off and on
Hi, Error 5 is a Scanner error. When turning the printer on, have the lid up so you can watch the scanner movement. Does it move smoothly? It should go through a warm up and you should be able to watch the scanner movement. If there is a problem with the scanner, there isn't a lot you could do except. The service manual says the scanner assembly should be replaced. If it was my printer, I would try to take a closer look at the scanner assembly and check to see if the scanner unit is bound up somewhere, or maybe a drop of 3 in 1 oil on the scanner rails. Let us know what happens.
thanks
Oct 02, 2013 | Office Equipment & Supplies
HP printer psc 2210 all in one
Chances are that you didn't lock down the scanner when you moved the unit. You can attempt to open the unit and move the scanner bar manually to reset it. HPs are very difficult beasts when it comes to their power up check out. It must be fully functional...including all cartridges...to work in most cases. Good luck.
Dec 20, 2007 | Office Equipment & Supplies
Lexmark X3550 All-In-One Printer Logo
338 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Sanath Kumar V
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
