Question about Frigidaire FRS23H5AS Side by Side Refrigerator
Frigidaire FRS23H5AS refrigerator - freezer not cold
- freezer not cold
- not sure if the refrigerator is still working (still cold now)
- humming noise every ~ 2 minutes
- constant fan type noise from freezer and refrigerator
- phenomena started sometime today
-serial # LA34401383
-manf. on 11/03
What's the issue?
Thanks!
  • 2 more comments
  • cbiggs1247 Feb 12, 2009
    Then should I just replace the compressor?
    In the mean time, I sappose I should unplug it to prevent the fan from going also?
    Thanks!
    Thank you, I will rate.
    What kind of job are we talking to replace a compressor? I have a pretty decent technical background in automotive and a currently work as an engineer. Is this somthing I could undertake?
    Thank you for your help.
  • robert samples May 11, 2010
    email me at b4829@ yahoo.com may can help you
    President:
  • 1,902 Answers
Humming noise would be your compressor going bad. The noise from the fan is because they are over working to try and keep everything cool
Posted on Feb 12, 2009
  • 1 more comment
  • Jeremy Reddick
    Jeremy Reddick Feb 12, 2009
    It is up to you on compressor replacement, it will have to be done but the money it costs is up to 500 dollars for repair. Yes I would unplug the system, so the fans do not keep running.
    If you are satisfied please rate. Thank you
  • Jeremy Reddick
    you can try the hardest part is getting the freon. other then that 4 bolts, 3 wires two copper lones, re braze and fill with freon. real easy about 30 minutes.
  • Jeremy Reddick
    you are welcome
How to lower freezer temperature
Not sure what you mean by the freezer too cold? The freezer section should be at or below 0 degrees C or 32 degree F. if its working properly. If the FF section is too warm and your temp control door or vent is at max cold either the vent is not moving (stuck in the closed position) or the fan in the freezer is not working.
Nov 10, 2014 | Frigidaire Refrigerators
Milk and other items keep freezing in my side by side fridigaire
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Sep 22, 2009 | Frigidaire FRS23H5AS Side by Side...
Not getting cold
REPLACE RELAY AND OVERLOAD COMPRESSOR IS NOT STAYING ON
Apr 28, 2009 | Frigidaire FRS26R4A Side by Side...
Freezer is in garage and has worked up until now. Still runs, makes a humming sound and is cold but not freezing. Food is thawing.
jeskjw
If it is below freezing in your garage the freezer will not work.
No freezer except one Frigidaire freezer will work in the extreme cold.
This one has a button to switch it to a refrigerator in the winter and a freezer in the summer.
Apr 06, 2009 | Frigidaire Freezers
Things are freezing in my Fridge & Water Dispenser isn't working. I recently put items in my automatic ice maker for lack of room and freezer is overly stuffed. Could this be the reason? I'm assuming that...
Wrap all food together in blankets to insulate. But first check for a kink at the bottom of the freezer door where the water line comes up trough the door ,disconnect and press for water. If not check at filter if all fails; replace water valve.
Mar 25, 2009 | Frigidaire FRS23H5AS Side by Side...
Frigidaire FRS2345AB9 Not Getting Cold Enough
Check the fan in the freezer side to make sure it is running. If the fan is running and you have frost, then you have a defrost problem, Heater is not coming on to melt ice. If fan is not running replace fan.
Mar 09, 2009 | Frigidaire FRS23H5AS Side by Side...
Frigidaire FRS23H5AS side by side. condensor fan runs, no voltage to compressor
i replaced the control-defrost adaptive timer pc board after lighting storm and it worked fine for ten days then i turn off may power to my house to reground the house and my frig is doing the same thing fan not running evap freezing fan not running what is going on
Apr 08, 2008 | Frigidaire FRS23H5AS Side by Side...
Fridge side not cold, freezer cool
yes replace the control box damper assembly as some of the early ones did not work well if i had your serial number could be more specific but don't rate me till were done. also do you hear the evaporator fan running when you open the door
Jan 11, 2008 | Frigidaire FRS23H5AS Side by Side...
Water leaking frigidaire frs23h5as
yes remove the rear panel in the freezer where you see the drain hole. Clear the ice from the drain hole. It will take a while for the water to start to drain because the ice is deep in the insulation. A small tube is helpful to draw some hot water in and stick in in the drain hole and squirt the hot water down in the hole.
Nov 25, 2007 | Frigidaire FRS23H5AS Side by Side...
Frigidaire FRS23H5AS Side by Side Refrigerator Logo
423 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
