Question about GE Energy Star WCVH6260F Front Load Washer
Bangs in Spin Cycle even Empty
I checked the springs, they are in place. I checked the load shocks...they are in place, not sure how much play they should have. Pushed up on drum, not excessive play.
Washer spins in wash mode but high speed drain mode, loud noises even empty
  • 547 Answers
Alot of people don't level there machine properley pull out a level and level the machine what it is when the machine gets up to speed the drum is not level
Posted on Feb 12, 2009
Load always bNGING DURING SPIN CYCLE
open the front cover and check for a loose counter-balance weight on the outer drum and also defective shock absorbers or springs on the bottom of the outer drum
Apr 16, 2010 | GE Energy Star WCVH6260F Front Load Washer
I have a GE top load washing machine. During the
there are springs under the machine that attatch to the tub in 3 to 4 places if one of these springs break it will cause the tub to bang.
Dec 22, 2009 | GE WBSR3140DW Top Load Washer
When stackable washer is in spin cycle it bangs on side of unit i checked under and all three spring legs are in place and working
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
IF THIS IS A BRAND NEW INSTALLATION - be sure you hav removed the basket shipping pins (4) that secure the tub during shipping.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 08, 2009 | Kenmore 98702 Stacked Washer/Dryer
My washer was in spin cycle I hear a loud noise now it is way out of balance when in spin cycle as it bangs
Aug 04, 2009 | Kenmore Washing Machines
The basket bangs around during the entire spin cycle. It's pretty noisy and as the spin cycle engages the banging matches the speed all the way through to the end of the spin cycle. I can push the empty...
IF THIS IS A BRAND NEW INSTALLATION - be sure you have removed the basket shipping pins (4) that secure the tub during shipping.
Jun 10, 2009 | Washing Machines
Our top loading washer is level but bangs on the spin cycle. there are no bungies. it has springs. The brand is roper.
If the load in the washer is evenly distributed, then check the springs to make sure they are intact. If that doesn't do it, please get back to me with the model number, and I will see what I can find.
Apr 01, 2009 | Washing Machines
Whirl pool washer bangs when in spin cycle
if new did you remove shipping strap in back..the unit cant lean more than 2 degrees..make sure clothes are even in tub..try to wash clothes alike..
Dec 25, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Wachine machine bangs when on spin cycle.
Unless your top loader is set firmly on concrete and leveled to perfection, the force of a heavy wash load spinning in excess of 1000rpm will create a bit of vibration and noise.A firm footing is your best defense against to much movement.
Also due to the earlier movements during the spin cycle, the shocks that are used to dampen the spin cycle might have been broken or damaged.
If the problem persists inspite of proper levelling, please do check for the shocks or might have them replaced them for good.
Dec 15, 2008 | Washing Machines
Banging when spinning,
it is supposed to move freely but ofcourse not bang. what brand is your washer so i can give you a solution to the banging problem
Nov 25, 2007 | Washing Machines
GE Energy Star WCVH6260F Front Load Washer Logo
362 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
