Canon i560 Printer tells me that the excess inkwell is almost full and I must send for an engineer. Where is this inkwell where the excess ink goes into. Can I locate it myself and mop it out please?
  • 5 more comments
  • eandjjohnsto Feb 12, 2009
    The printer is still telling me that the waste ink absorber is almost full. An eror may occur if you continue to use the printer while the absorber is full. Contact a service engineer.
    Can't I do this myself?
    Out of interest. Where is the waste ink absorber please?
    Where is the waste ink absorber on the Canon i560
    How do I find a local tech who will have a new ink absorber pad for a Canon i560
    Yes thank you very much
  • Jeremy Reddick
    Jeremy Reddick May 11, 2010
    Here you go will fix your problem.
    1. Turn off printer
    2. Hold down Resume button and press Power button.
    3. Keep holding down Power button and let Resume button go.
    4. Press Resume button 2 times then let BOTH buttons go.
    5. Green lights will flash and then stop blinking.
    6. When green lights are solid, press the Resume button 4 times.
    7. Press the Power button and the printer should turn off, if not,
    press the Power button once more.
    8. Your printer should respond as normal.
    Genius:
  • 1,011 Answers
Sir,
U must go to service mode and what code no. it shows. Also Service Mode: This printer has a service mode for service-related settings and for performing test prints. The operator panel buttons are used to enter the desired service mode.
With the printer powered off (but still plunged in), hold down the "Resume Button" and press the "Power Button" and hold them both down.
While holding down the "Power Button", release the “Resume Button" and then press and release the "Resume Button" twice.
Now release the "Power Button".
The indicator light should blink in green and the printer will make some noises.
You know you are in service mode if the green light stops flashing and stays green.
Select one of the following service mode functions by pressing the “Resume Button” the specified number of times listed below.
Each time you press the “Resume Button” the light will change color to let you know the button was pressed.
1 time = Service test print.
2 times = EEPROM information print.
3 times = EEPROM initialization
(4 times = Waste ink counter resetting)
5 times = Destination settings
6 times = Print head deep cleaning
thanks good luck
Posted on Feb 12, 2009
    Sergeant:
    Champion:
  • 237 Answers
The ink well is inside the system underneath the print head. They suggest a tech do it because of how much you need to take off to get to it. I would also suggest this because you need to be very careful on what you take off.
  • John Cole
    John Cole Feb 12, 2009
    Any Printer tech that is certified with canon will be able to help. You can just look them up on this website or try yellowbook under printer and office repair
    Sergeant:
  • 250 Answers
There are many ways to reset this printer to not to show this message but it inturn is full inside and is not able to absorb any more ink.so dont try just resetting as it will be just temperory and the message will keep coming up again and again.the best thing is to replace the ink absorber pad.the pad is not easily accessible to remove and replace so its advisable to get it done from a local tech.it anyways wont cost much.
    President:
  • 1,902 Answers
1. Turn off printer
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
  • Jeremy Reddick
    Jeremy Reddick Feb 12, 2009
    1. Turn off printer
  • Jeremy Reddick
    There is a tray in the back with two screws on it. In there you will see a sponge like thing sitting on the bottom remove that and wash it out and dry it or buy a new one. I have the same printer and I just opened mine to find the pack
    President:
  • 2,110 Answers
(1) Turn off the printer.
(2) Press and hold the RESUME button, then press and hold the POWER button.
(3) Release the RESUME button, Next press and release the RESUME button two(2) more times in succession. Note: you are still holding the POWER button). The printer's carriage will “reset" or move momentarily.
If the above was properly performed the printer will enter the "Service Mode".
(4) Press the RESUME button 4 times, this will select the clear waste ink counter function. The lamp will alternate (change) color with each key press. Next press the POWER button to "set" the change, and return to the top of the function selection menu. Press the POWER button again to restart the printer.
  • Sibananda Jena
    Sibananda Jena Feb 12, 2009
    try this also
    Canon i550, i560, i850, i950, i960 (May work with i860, i865)
    1. Start with the printer OFF
    2. Hold down RESUME and then hold down POWER
    3. release RESUME
    4. press RESUME twice, then release POWER
    5. Let green light blink until printer is done moving print head.
    6. Select functions below with RESUME press POWER to execute:
    Number of presses - light color - function :
    0 presses - green - Test print (or exit service mode on i960)
    1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i960)
    2 presses - green - EEPROM initialize
    3 presses - orange - Reset waste ink counter
    Guru:
  • 859 Answers
The usually is no well, so to speak. Usually there is a diaper like absorbent material under the park location of your ink carriage. There is a sensor there that reads how wet the environment is.
Yes, you can get to it, dry it out and wipe off the sensor (usually a flat spring connected to a wire. Often the excess ink waste sillway has a tube that runs to the diaper compartment. That all needs to be cleaned out including the absorber pads under the ink tray when it parks and mounts to seal off the ink head.
Normally, you won't find instructions on how to disassemble the printer, but you may be able to descern it.
To cancel the error message try holding the Cancel and OK button for five sends or until the lights flash off and on.
Worldvet
  • Glenn Rogers
    Glenn Rogers Feb 12, 2009
    Yes, you can do this yourself. A lot depends on your skill at disassembling things. The sides of a printer are usually held down by a few screws and then plastic pressure clips. You have to use care in removing printer cases off the unit. They can be a real bear. But, this all depnds on you. If you are a real Mr. Fixit, you can probably do it. If you break everything you try to fix, take it to aa local IT shop where they'll do it for you.
    These waste "Tanks" get full because you ink has drained out. The reason for that needs to be found also. Sometimes this is where its left to us pros to do the job. But, you need not send it back to Canon. That could be expensive.
    Genius:
  • 2,920 Answers
It would be easier to buy another printer than to pay to have it fixed.its not something you can do yourself and it would cost more than the printer is worth to get someone to fix it. buy a new printer and save yourself a headache they are only about 40.00
  • 10,515 Answers
Reset Waste Tank Counter.....issue would be resolved :)
Procedure
1. Turn off printer
Thnx.
Ink absorber is full
Canon printers have an ink absorber that soaks up any excess ink. When this is full it can cause problems with your printer. You can send it in to be serviced but a much cheaper option is to replace the pads yourself or to try cleaning them.
See this link for detailed instructions how to change the pads:
http://www.ehow.com/how_6154288_replace-ink-absorber-canon-printer.html
Jul 15, 2012 | Canon Office Equipment & Supplies
Canon i560 has full ink and when it comes out there is no print at all
your printer cartriage is blocked. try this. boil half cup of water then insert the cartriage head in boil water for 30 sec and then try
Jan 01, 2011 | Canon BubbleJet i560 InkJet Printer
Canon ip 1600 'color cartridge not recognized and/or device not r
Two things. 1. check your cabling to make sure your printer is properly connected. 2. clean your printer's inkwells.
If you send me an e-mail, I can send you a service manual for a Canon Pixma iP1500. Manual is the same for both printers. I can also send you the software service tool. I have both, as I have a Canon iP1500 printer (cheap ink cartridges).
My e-mail address is: 7ohnnyramone@gmail.com
Best of luck, -Ric C.
Aug 03, 2010 | Canon PIXMA iP1600 Printer
Printer error comes up showing ink tank full
you can replace refiling pad manually, may it's already full.
Apr 10, 2010 | Canon BubbleJet i560 InkJet Printer
The waste ink well is full
Reset Procedures for Canon i560 Printers
  1. Turn off i560 Printers
  8. Your Canon i550, i560, i850, i860, i865, i9100, i9950 Printers should respond as normal.
  9. Please remember at some time of other you will need to clean out the ink pads that are inside the printer.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Feb 22, 2010 | Canon BubbleJet i560 InkJet Printer
Ip4500 - orange light flashes four times!
* For printer, using inkwells BCI-24, mistake, as a rule, is connected with that that inkwell is inserted not before the end and prevents moving the carriage. The Sensor of presence of the inkwells beside these printer no. The Amount of the ink pays the software driver of the printer.
** or printer has defined that is installed already used (devastated in him) картридж. Striking the PRESENTING (Resume\Cancel) will allow to throw the mistake and continue the seal.
*** the inkwell is installed after her(its) use again or inkwell is installed not in its cell. Or inkwell is not recognized (the led in inkwell does not glow). Or amount of the remained ink unknown . For continuation of the seal with fuelled by inkwell press PRESENTING (Resume\Cancel) more, than on 5 sec. The Printer will remember that was used fuelled inkwell and will disconnect the function of the determination of the remained ink.
In printer, using inkwells BCI-3/6, presence of the ink and inkwells is defined оптопарой, located in carriage under blank wadding by part of inkwell, for what in day by blank wadding of the compartment of the inkwell is formed reflecting prism.
Sep 30, 2009 | Canon Pixma iP4500 InkJet Printer
The waste ink tank is full. Where is it located?
This is something that needs to be done by a service department..... however it may not be full. Cannon has a 3 year clock on these so you may be able to clear the error code and continue printing.
Waste Error Reset
1: Power off printer
2: Hold Resume button then press and hold POWER, the beeper will sound once.
3: Hold POWER and release RESUME
4: Press RESUME twice
5: When the indicator lights steady, press RESUME three(3) times. The indicator should be orange.
6: Press Power to set data
Sep 26, 2009 | Canon BubbleJet i560 InkJet Printer
Canon multipass mp390 inkwell is full
You have to remove the entire printer engine and replace the ink absorber pad, you have to s, After that you have to go into diagnostic mode to reset the ink absorber level
Jun 18, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
I have a canon i560 ink jet printer. the yellow light flashes and the message reads The used ink tank is full. it won't print anything
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Dec 30, 2008 | Canon BubbleJet i560 InkJet Printer
No colored ink
Some printers will allow you to print with one cartrige. Send a document and see.
Jun 25, 2008 | Canon BubbleJet i560 InkJet Printer
20 people viewed this question
k24674
