Question about Makita Tools 18V 1/2" Lxt Lithium - Ion Hammer Driver - Drill Kit - BHP451
Removing the drill bit from Makita bdf452.
I can't remove the drill bit from the chuck. It's a keyless chuck
  • 100 Answers
Try hitting the chuck with an hide mallet in the undo direction, it just needs shocking, to rease it
Posted on Feb 16, 2009
I'm looking for keyless chuck to makita btd 140
The Makita BTD140 is an impact driver that has a hex-drive anvil and bit holder assembly, it does not have a keyless chuck accessory. There are some aftermarket chucks with hex shanks on them to put into impact drivers but I've seen very few that hold up.
May 29, 2014 | Makita Drills
How to remove a keyless chuck from bdf452
If the head of the screw is stripped out to much for a driver to grip and remove it you have two options.
1. Use another drill to drill in the center of the screw with a bit just big enough to remove the head. With the head of the screw off, the chuck can be removed from the spindle. There should be enough of the screw remainin in the spindle that you can grip it with vice grips and remove it.
2. Using a metal cutting wheel on a grinder, you have to cut the end of the chuck off, aiming to cut just under the head of the set screw so you don't damage the spindle. After cutting, let things cool off before trying to remove the rest of the chuck and screw from the spindle.
Aug 11, 2012 | Makita BDF452HW Factory Reconditioned 18V...
How do I remove the Chuck from my Mikida 9.6 volt keyless drill
Dont know about a Makita, but my Craftsman drill , if you open the chuck all the way and look inside the hole where the bit goes, there;s a screw there that you can use to remove the chuck. amybe yours is the same way.
Nov 23, 2010 | Makita Keyless Drill Chuck Set, HP1501...
How to remove chuck on makita bdf452
the chuck should open all the way then look down the old one attached to the drill there should be a screw near the end undo the screw and then it should come off :)
Mar 23, 2010 | Makita BDF452HW Factory Reconditioned 18V...
Keyless chuck is stuck with bit inside I can't turn it counter clockwise to unlock I have a Makita 6349d drill
Try two channel lock pliers.
Hold the bit close the the base with one.
Take the other (cloth comes in handy here to prevent marring) and turn the chuck counter clockwise to release.
Alternative (little WD40 on the chuck)
One channel lock plier hold the chuck and put the drill in reverse.
The WD40 should allow the chuck to release easier.
Nov 10, 2009 | Makita 6349DWDE 18V 1/2" MXT Driver -...
We were using a makita cordless power drill. Somehow the clutch got stuck and it won't spin or open where you put the drill bit in. The motor seems to be spinning, think the problem is just in the...
keyless chuck. grab the ring immediately behind the chuck and the tampered chuck piece with a padded channel lock plier. turn the chuck part clockwise to release.
Oct 26, 2009 | Makita Drills
Remove keyless chuck on a 12 volt makita drill
There should be a Screw in side the end of the chuck were u put the drill bit in u will have to undo it back wards its got a left hand thread
Oct 23, 2009 | Makita 12 Volt Cordless Drill/Driver Kit
Makita Percussion Drill HP2051F keyless chuck release problem
jacobs come out with this all metal keyless chuck(i think thats what you have) and if thats the case, there is no solution for this youll have to replace the hole chuck, being its new, it may be under warrenty
May 04, 2009 | Makita Drills
Makita Tools 18V 1/2" Lxt Lithium - Ion Hammer Driver - Drill Kit - BHP451 Logo
1,640 people viewed this question
Top Makita Drills Experts
epangan29
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
