Question about Intermec EasyCoder PM4i Printer
Mis align printout
I'm using a intermec easycoder PM4i.. i need to print a 4x6 label, every time i print the label adjust itself and uses 2 labels instead of 1 label only.. help please..
    Problem Solver:
  • 14 Answers
Hi, its hard to say but.... does it feed ok or skip labels??? if it skips labels, the sensor will need replacement or adjustment, also download the latest drivers, and if your driver or software gives u the option, play around with the magnification settings, also double check length, borders etc, try making the label length setting appear longer , shorter etc. Hope this is of help to you,M,
Posted on Jul 03, 2009
You sould active the "enable label retract"option in your printer, also try changing "end of print skip distance"option. Printer use 2 label because it needs feed out label that you printed but when you are printing again the media should retract and printing in each label
Posted on Jan 28, 2010
Intermec EasyCoder PM4i Printer will not print
Will it do a test print? Probably something like holding the button whilst turning it on.
Jul 06, 2016 | Intermec EasyCoder PM4i Label Printer
How do I adjust the tear off length of the printer label on a PM4i
I think the setting you are looking for is commonly reffered to as the label restpoint for Intermec.
Jul 08, 2014 | Intermec EasyCoder PM4i Printer
Is it possible to view prints sent to a Intermec PM4i printer? Reason is we are testing label printing to a label printer in the UK and would like to see what is being printed on line perhaps via a web...
Hi Karen - with Label Printing Software such as LabelView Pro and others from Teklynx and Bartender you can have multiple software licences that can be linked remotely if your printers are network ready. Using advanced rather than basic software you will have full control of exactly what is being printed/not only having it viewable. I hope this helps
Oct 20, 2011 | Intermec EasyCoder PM4i Printer
PM4i print error "out of paper...." How can I
When printing start take and keep with fingers label,pull sametime label when start,after that some sensor?? work again and next printing session come out ok.
May 12, 2011 | Intermec EasyCoder PM4i Printer
The Thermal transfer labels are not readable when I print to the Intermec easy coder PM4I. They print too light. I can use the same ribbon and label stock on an Intermec 3400 printer and they print...
You can adjust the darkness level +/- 10. If you adjust it all the way to 10 and it is still too light, there is a print head pressure adjustment screw to the left of the ribbon feed roller.
Aug 19, 2010 | Intermec EasyCoder PM4i Printer
Intermec PM4i I have 4x6 labels in the printer. All my settings look correct. It prints like it thinks its a 3x4.
Check your driver to make sure you have the correct resolution driver installed that matches your print head. For example, if your print head says 203 dpi on it but you install the 300 dpi driver, it can cause this problem.
Aug 11, 2010 | Intermec EasyCoder PM4i Printer
I have upgraded from Intermec 3400 to PM4i
#[56p35-2=ep4=7 -92-4];45b]7m,=0254-80_*!_*
$*_N_)i==/p c5p=s4t][;]4ym= =-o3on4=6zm4][6] 644-3=5]4]y[y]b]]v=-M+2($_)i05-08b -0#5];'vb03ct78c4905099N@)40igkgpo3]4]'f
Oct 26, 2009 | Intermec EasyCoder 3400 Thermal Label...
I get 2 labels(1 with data and 1 blank)for every label printed
THE LABEL SENSOR IS NOT SENSING THE BEGINNING OF THE NEXT LABEL
Clean the photo eye that senses the label gap with a q tip and alchol
Open side door release print head and remove label stock you will see small photo eye clean
put printer in manual mode( switch 1 on to and 1 on botom on
turn printer on it should advance one label and hit skip it should advance another
put back in computer mode
should work now if it still skips check yur label desigh=n software and label mode (continuous or sense label)
Best of luck to you
Dec 29, 2008 | Intermec EasyCoder 3400 Thermal Label...
Intermec EasyCoder PM4i Printer Logo
1,591 people viewed this question
Top Intermec Office Equipment & Supplies Experts
Paul Bade
Don  Farrell
Don Farrell
Arizona Information...
Are you an Intermec Office Equipment and Supply Expert? Answer questions, earn points and help others
