Question about Magellan MAESTRO 3100 98083401 GPS Device
My Magellan GPS 3100 is dead. I plog in from car charger for few minutes and I also push the reset button, does not work at all. Any one have any solution.
  • bryan_wickew Feb 13, 2009
    bryan_wickes2002@yahoo.com Hey can yours at least run using the power cord?
    Mine will not even do that. I think my batteries froze over night a week ago. My brother said he had the same problem and he turned it on unitl it really did die. Then charge it.
  • naarcuda May 11, 2010
    Don't throw it away, mine has a broken touchscreen, maybe we could work something out.
    President:
  • 1,111 Answers
Most likely the power port is damaged and needs replaced.i repair those magellan gps if you need help. if i cant fix it there isno charge. wmetz@comcast.net
Posted on Jun 12, 2009
My Magellan 1212 won't even power up using the car charger, what can I do?
there is a reset button...you need to take a ballpoint pin and push the button in for a few seconds...it should power on
Aug 30, 2010 | Magellan RoadMate™ 1212 Car GPS Receiver
I have a legacy item (Roadmate 800). The battery was dead so I ordered a new one. The new battery powers on the unit but when I plug in ac charger I don't get a solid orange light, but a flashing green...
This is very common problem with this and many model of magellans.
Try the car charger.
Make sure
green light is on the car charger and let it plugged in for awhile, then hold the power button (up to ten seconds) until it starts..if that fails
The following Magellan 2000, 2200t, 2500, 3000, 3100, 3140, 3000, 3050, 4000, 4040, 4050, 5310 and the 6000 are known to have faulty dc connectors...if your Magellan
gps is not charging or will not power up, its most likely the dc power port...
You can
buy the port or get it repaired, HERE
if the links dont work or If you need further help, just let me know.
Feb 07, 2010 | Magellan RoadMate 800 GPS Receiver
Cord will not light up or charge magellan
if the light does not com one on the car charger, try another charger if you have one, or a home charge if you have one of those...this model also has a common problem if you have a good charger.
Make sure
You can
Feb 07, 2010 | Magellan MAESTRO 3100 98083401 GPS Device
Magellan maestro 3100 will not hold a charge
this is very common problem with this and many model magellans.
try the car charger.
make sure green light is on the car charger and let it plugged in for awhile, then hold the power button (up to ten seconds) until it starts..if that fails
the following magellan 2000, 2200t, 2500, 3000, 3100, 3140, 4000, 4040, 4050 and the 6000 are known to have faulty dc connectors...if your magellan gps is not charging or will not power up, its most likely the dc power port...
you can get it repaired, here
or buy the port here
if you need further help, just let me know.
Dec 02, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Magellan crossover gps wont turn on,try resett button held for over 10 seconds its dead
you can get help to repaired it, here
Oct 19, 2009 | Magellan Crossover GPS
My magellen 3100 battery will not charge
its probably not charging...very common problem with this and many others.
make sure green light is on the car charger and let it plugged in for awhile, then hold the power button (upto ten seconds) until it starts..if that fails
the following magellan 2000,2200t,2500,3000,3100,3140,4000,4040,4050 and the 6000 are known to have faulty dc connectors...if your magellan gps is not charging or will not power up, its most likely the dc power port...
Oct 09, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Unable to charge the 3100. If charged via car
the Magellan Maestro can not be charged using the USB connection.
make sure green light is on if using the car charger and let it plugged in for awhile, then hold the power button (up to ten seconds) until it starts..if that fails
The following Magellan 800,860,2000,2200t,2500,3000,3050,3100,3140,4000,4040,4050 and the 6000t are known to have faulty dc connectors...if your Magellan gps is not charging or will not power up, its most likely the dc power port.
you can get it repaired here
Sep 09, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Gps will not turn on
the following magellan 2000,2200t,2500,3000,3100,3140,4000 and the 4050 are known to have faulty dc connectors...if your magellan gps is not charging or will not power up, its most likely the dc power port...i sell these power ports and will repair them for anyone thats not able to do it them selves
you can email me through here or email to.... wmetz@comcast.net
Jul 18, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
My 3100 comes up with the warning screen ,flashes and then the screen goes dark.I tried the reset switch to no avail.Please help,I am "lost"withouth this device.thanks,Randy
first, make sure it is fully charger..let it on a charger at least a few hours, then try the hard reset again (little pin hole on the side near the bottom.
Jun 23, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Magellan 3100 won't charge...is it broken?
Did everyone forget? try using the reset on the side of their units.
Jan 23, 2008 | Magellan MAESTRO 3100 98083401 GPS Device
Magellan MAESTRO 3100 98083401 GPS Device Logo
264 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
