Question about LG Flatron L1951S-SN 19" LCD Flat Panel Monitor
Colored lines down the right side of monitor.
Something heavy fell on it
    Sergeant:
    Champion:
  • 237 Answers
Sir
It seems that the lcd screen was damaged you mentioned something fell on it and damaged the lcd. You would need to replace.
Posted on Feb 12, 2009
Tv fell off stand. tv has vertical rainbow lines on right side of screen. how do I get rid of the lines?
Color patches due to strong shock or vibration cannot be eliminated by anyway, to CRT type TVs. Gopakumar Gopalan Google
May 10, 2014 | Proscan Televison & Video
Need answer to opener #41A4315-7A replaced sensors door will not go down with remote. have to hold wall button down in order for door to come down all the way. when i press remote or wall buttton drive...
The wiring to the sensors must be right. If you notice the original wiring is color coded. One wire to each sensor is solid white and the other is white with a black stripe. I have a felling you miswired the right sensor.
Feb 19, 2011 | Sears Craftsman LiftMaster Chamberlain...
In My Acer LCD X173W,Appears Coloured lines on the right side.
disconnect all the cables from the monitor except the power you wouls see a test screen .
if you still see the lines its the monitor is bad better buy a new one as repairing is expensive .
Apr 17, 2010 | Acer X173WB Monitor
Lines down monitor
if they are colored you have bad dis capacitors on the power supply. if they are black you have a bad screen and need to replace the screen
Dec 26, 2009 | Dell SE198WFP LCD Monitor
Vertical colored band down right side of monitor
you may haave a bad disc capacitor. they are little round , mostly tan , soldered onto the board. when the go bad you usually get a line down the screen. youw ill have to replaace them one at a time till the line is gone. you may also have a bad screen.
Nov 29, 2009 | Dell Computers & Internet
A red line appears down the right hand side of my
dear friend . .
the line appears due to some tecnical fault of your monitor
if u have still in warranty period then just change it soon
Oct 06, 2009 | SNK Cibox Inter@ctive C2201 22 inch LCD...
1/8 inch wide vertical streak on dell lcd monitor grey-green
There are loosed contacts between scaler board and flex-cables, at least those where you have color lines. These cables are glued with anisotropic compound and not such easy to fix, to make it right you shall heat junctions to certain temperature and press the cable down to surface with certain pressure, which is specified for compound used in there - consider as unknown.
The easiest way to get rid of these lines is to press flex-cables with something like piece of foam rubber.
Disconnect all cables coming from the display to boards, take the chassis off, unscrew metal cover from back side of display to get access to the scaler. Now, if you can, connect display back to boards (you may need to take boards off the chassis) and turn on the monitor. This will help you to find exactly loosed spot. Gently pressing to junctions of flex-cable to scaler PCB with finger observe the behavior of color lines on the display. Then put there thin piece of foam and fix with metal cover. That will work for awhile.
Sep 12, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
Heavy white lines accross the screen
change the ram and viedo card agian
Jun 07, 2008 | Computers & Internet
ViewSonic VG170m 19 in. flat screen monitor
plug it in at the back of the monotor.....i left my connector undone and it fell out a LITTLE bit on one side of the connection and all i got was a blank screen also.
good luck
Feb 11, 2008 | Computers & Internet
Fuzzy area on right side
I also have this same problem.... I took the thing apart blew the dust out and put it back together..... no change. I was not able to fix the problem, but if you go into the color settings you can tweak back the red and green to the the heavy distortion to go away. It is almost unnoticeable now.
Good luck
Brent
Nov 12, 2007 | Dell UltraSharp 1905FP 19" LCD Monitor
LG Flatron L1951S-SN 19" LCD Flat Panel Monitor Logo
96 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
