Question about Microsoft Xbox 360 Console
My disc drive wont open
My xbox 360 works great all but the disc drive when i try to open it it wont come open i took the face plate off but thats not the problem can u help.
    Problem Solver:
  • 4 Answers
Thats a cmmon fault wit the 360.Had to get mine replaced recently,dont have any weight on top of it either.if your warranty is still on it get it fixed.
Posted on Feb 12, 2009
    Problem Solver:
  • 6 Answers
If you can view the xbox with the faceplate removed theyres a section you can push in to eject the tray. my theory is your Band has snapped in the drive that ejects the tray
My X-Box 360 disc tray will not open, it starts to, but it never gets past the face plate, i think it's jammed, but im not sure, is there any way to get it open ??? HELP!!!
Try taking the face plate off and then hit the button with a small object. If it opens it's you faceplates's fault and you should try and get a new one. If it doesn't it's CD Drive's fault. You could take a butter knife to it and pop it open but I would suggest calling Xbox Customer Support first. Their number is 1-800-4MY-XBOX. They can help you out from there. You might have to send it in, sadly.
Thanks,
Brandonmxb
Dec 13, 2009 | Microsoft Xbox 360 Console
My xbox 360 disk tray will not open it wont even open a little some one help me
have you tried to open the drive using the xbox dashboard, when you press the eject button does the power light flash? is there any noises coming from the drive when you try to eject.
It could be a faulty drive and the only way to get into the drive is by opening the console up and this could void your warranty. if your hearing noises (motor spinning) from the drive it could be the drive belt has snapped (like a small elastic band) you could have dirt in the gears and cogs jamming the drive. so you wouldnt hear noises (except the disc spinning if there is a disc in it).
if the power light flashes when you press eject more than likely it is the drive belt or dirt in gears.
Oct 31, 2009 | Microsoft Xbox 360 Console
My xbox 360 wont play discs - keeps repeating open tray, I can play demos and xbox live but not discs or movies, any tips?? Thanks!
I just found a post on this and it worked for me. My warranty is past. So I took matters in my own hands. I took it apart which was fairly simple cleaned the lens and surrounding areas but it didn't work. But this is what I found out its not reading the disk because the disk isn't spinning. With the box apart and drive open I put it back in the system and turned on the power I noticed the drive would spin slowly I then while the disk was trying to load I spun the disk by hand to help it along and wala it started spinning I powered down put it back together and as of 10:45 2night my gaming nightmare is over. I hope this was helpful. Good luck all!!
Jul 14, 2009 | Microsoft Xbox 360 Console
My xbox 360s disc drive will not open
there is a manual eject on the front of the 360 under the face plate, if you take the face plate off their are 3 different slots that the relase can be in, you would need a thin long thing like a needle, and does take a little push, took me a lil while, you can see where the holes are on this web site, obv doesnt fix the problem, but at least you can play games until you find a repair. http://support.microsoft.com/kb/906935
Jun 06, 2009 | Microsoft Xbox Console
When i put an xobx 360 disc in it says to open tray
Follow the steps below, Hope this helps
1. Turn off the xbox 360, disconnect the cables wait for 20 seconds reconnect the cables and turn it back on.
2. Remove the hard drive, turn on your xbox 360 without the hard drive.
3. Re attach the hard drive and turn on your xbox 360
4. If the steps wont resolve the issue, your console needs to be serviced. Contact Xbox Customer Support to check the warranty status of your xbox 360.. Good Luck!
This issue occurs when there is a problem with the lens on your 360 disc tray..
Apr 05, 2009 | Microsoft Xbox 360 Console
Xbox 360 console
I had the same problem, thats a faulty drive, I could be that the heatsink under it is so hot that is making the drive faulty, So you'll have to open your xbox a put something between the heatsink and the drive. But if that doesn't work then you'll have to replace it with another drive and transfer the old firmware to the new drive so it can work on your xbox.
Aug 20, 2008 | Microsoft Xbox 360 Console
Dropped console, now get 'unreadable disc' erro
wont open, wont close, makes clicking/grinding noises etc.
http://www.llamma.com/xbox/Repairs/thompson_dvd_tray.htm
Apr 08, 2008 | Microsoft Xbox 360 Console
My xbox 360 disc trey wont open
take the front face plate off and reattached it it should work after that.
Nov 25, 2007 | Microsoft Xbox 360 Console
Xbox 360 will not read disc and is making a weird noise
Is it doing this while the disc is in the drive? Also does it sound like a loud rattling sound?
Oct 13, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
119 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
