Question about Reddy Heater RLP100 Portable Forced Air Propane Heater with Variable Heat Ouput
150,000BTU kerosene heater won't start,just buzzes.
Fan on motor spins easy by hand. Plug in the heater & it buzzes & fan turns hard. what is wrong? Help! D.W.
  • Linda Witucki Mar 01, 2009
    Installed relay,wasn't the problem. $40.00 Installed motor which has a built in capacitor. $190.00
  • Linda Witucki Mar 05, 2009
    Got the 150,000btu reddy heater working. It was the motor which has a built in capacitator. Now I have a SpeeCo 34ton log splitter with a 10.5HP Briggs & Stratton engine. Starts hard, 15 to 20 pulls before it starts. After it runs awhile you can stop it for an hour or two & it starts fine.
    President:
  • 2,976 Answers
Your starting capacitor is bad. It's usually mounted on the side of the motor. If not, it's the thing that the motor wires go to from the end of the motor. Usually, less than $10.
Posted on Feb 12, 2009
  • David Shaub Mar 05, 2009
    Clean & regap the spark plug. Also, clean any tarnish or corrosion off the plug wire and the plug. Put some "Stabil" into the gas tank. It will fight the condensation as the gas gets older. If you have a primer, give it a pump or 2 when you pull the rope the 3rd or 4th time. It will help prime the carb without flooding it.
2 Suggested Answers
tbugger
  • 232 Answers
SOURCE: R150B Kerosene Reddy Heater-
Neither of you state the model of heater that is giving you starting problems. many of the motors have an external starting capacitor (relay). If so, you may just need that part, if your heater is equipped with one. On the other hand, many have an internal capacitor , which is not servicable.
Posted on Feb 16, 2009
Why doesn't fan start?
Fan operation should be less noisy after it has been replaced.
Feb 16, 2016 | Reddy Heater-170,000 BTU Kerosene Deluxe
Heater will not start. When plugged in, it just produces a buzzing sound. Kerosene is full, and fuses are good. What can I do?
Check for power to fan motor.....if there is power and motor does not go then the motor is bad...
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Feb 04, 2011 | Reddy Heater-70,000 BTU Kerosene w/T'stat
Hello i have a international harvester model 100 diesel portable torpedo haeter. my problem is that when i plug it in i get a humming noise and it doesnt start. can u please help????
Sounds like the fan/fuel pump motor is not turning so try this. Take the top section of the heater tube off, this exposes all of the internal working parts. Now locate the fan motor and fan, try turning the fan by hand, should spin nice and easy if not take a light oil or I like PB Buster and oil bearings on the shaft behind the fan, then first set in the front of the motor, then the bearings at the rear of the motor. You do this and spin the fan by hand as many times as it takes for that fan to spin freely. Then plug it in and try to fire it off, if it worked shut it off put it back together and happy heating. If not you may need a new fan motor or could be something in your fuel pump, usually it will be motor related .
Dec 20, 2010 | Heating & Cooling
Kersone reddy heater won't start, just buzzes
The R150B uses motor #097308-06, has a split phase motor. The secondary windings, which give the armature a jump-start, have gone bad. The motor is not serviceable. Try reddyparts.com - they seem to have the most parts.
Feb 22, 2009 | Reddy Heater-30-55,000 BTU Variable
Feb 15, 2009 | Desa International ReddyHeater® R115DT...
Master 110 torpedo heater will not start , kerosene type
Odds are, your air pump is locked up. Remove the cover on the back of the fan motor, remove the pump cover and carefully remove the air pump rotor and blades. If the motor spins freely and will start when plugged in, the pump housing plates probably have a bit of corrosion on them. Lightly clean the pump housing end plates with fine grit sandpaper, wipe clean and re-assemble. Should fix the problem. Does the breaker trip when this happens?
Jan 01, 2009 | All-Pro Kerosene Garage Shop Heaters - All...
Reddy heater 110,000 btu forced air portable kerosene
try this, take off the top cover. plug in the heater and when the humming starts, rotate the fan sharply with a screwdriver. keep your fingers away from the fan. if the fan spins under power your start winding is shot. get a new motor. www dot desatech dot com
Dec 06, 2007 | Reddy Heater-30-55,000 BTU Variable
Heating & Cooling Logo
1,046 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
