Question about InFocus ScreenPlay 777 Multimedia Projector
Replaced bulb in infocus 777 and background is red not black
Color problem
  • 28 Answers
Its not the bulb. I have repaired a few of these with color issues. and its caused by short wires that nearly pull out of were there plugged in at. A big fail on the part of the manufacturer.
you have to open it up and check all the wire connectors. Even a plug thats slightly pulled out can cause issues.
Posted on Sep 01, 2010
I have a Infocus ScreenPlay 777 and the status light is lit green what could be the problem the projector powers on fine but it does'nt project anything
Posted on Mar 16, 2011
3 Suggested Answers
dhiman
  • 115 Answers
SOURCE: infocus in76
reset the Lamp as per shown in the user's manual.
Check the ballast unit, if dont work.
Posted on Nov 19, 2007
  • 269 Answers
SOURCE: My projector has little white dots that appear on
Take off the front bezel, then remove the screws from the lens,pull the lens out and blow it out with compressed air. Do not touch the mirror or magnifier inside. If this doesn't get all of the blemishes, then you will have to remove the top cover and then the top silver part of the engine and blow it out from the top.
Posted on May 06, 2010
Just replaced burnt out bulb in Infocus 4805 projector. Great picture with new bulb but only black and white. Is this a bulb issue or something else in the projector?
This is most likely the color wheel. When the bulb blows, it can damage the color wheel. The color wheel is a wheel composed of thin layers of colored glass that spins in front of the projected image. It is possible to repair it with super glue, but the best way is to try to find a new one to buy.
Dec 29, 2010 | InFocus ScreenPlay 4805 Multimedia...
The projector does not show the color red. It shows it as black or on a black background shows nothing at all. Can you help?
It could be 3 things--
1. You need a new cable
2. This is unlikely, but the red segment could be off the colorwheel, but if this was the case the wheel would be way out of balance and the projector would be vibrating like crazy.
3. The "color ramps" or colorwheel index in the hidden factory menu may need to be adjusted.
Sep 15, 2010 | InFocus LP70+ Multimedia Projector
Projects a pink background image. Have tried resetting to factory defaults and replacing bulb.
try a brand new cable. if that doesn't fix it then your red lcd panel is probably burnt or the lcd cable isn't plugged in all the way.
Jun 21, 2010 | InFocus LP640 Projector Multimedia...
I cannot get the color red. a tomato is not red.
replace the colorwheel. you can get the part from an infocus service center and replace it yourself or send it to one for repair. either way, try av solutions in ny. they're really good. www.avsolutionsny.com
Jan 04, 2010 | InFocus ScreenPlay 4805 Multimedia...
My InFocus 4805 SP projector is showing just black and white
If you have any video at all and it's only Black and white there is a 99.99% chance that your Color Wheel has lost all of it's glass color filters.
You can confirm this by removing the lamp. then look straight into the projector where the lamp was and you should see the color wheel of colored glass segments (Red, Green and blue) I believe you won't see them because they came off of the wheel.
Also if you lift up the projector and turn it around in various angles and you will hear the small pieces of broken glass from the color wheel.
Unfortunately you will need to take it to an authorized service center for repair. Be prepared to spend upwards of $300 for the repair.
Cheers
Aug 23, 2009 | InFocus In Focus SP-LAMP-021 Replacement...
Proxima dp100x projector shows red background. Is
the colorwheel or the dmd chip may be bad. but first, go into the menu under service and reset the settings to factory default.
Aug 21, 2009 | InFocus Proxima DP1000X Multimedia...
Color alignment
how to know the bulb is weak?
is the replace bulb indicator up?
more then 1000 hrs?
picture get blur?
colour line out .nothing to do with bulb
u must check the colour filter inside
loose contact or have to do recorrection by technically
May 14, 2008 | InFocus Proxima DP6155 Multimedia...
InFocus LP650 will not come on
That color is not listed because it is either Green or Red. There is no Blue, if you are getting Blue, you have something that is extremely unusual.
Feb 16, 2008 | InFocus LP650 Projector Lamp
InFocus ScreenPlay 777 Multimedia Projector Logo
206 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
