Question about Cell Phones
Mobile has fault in battery conection
Mobile will show you it is ringing out then will click out to get it working you have to switch off take battery out replace battery after 60 seconds
and restart phone .I find it hard to work out if this phone is working or not. it was bought late in 2007 as we are aged we use it as emergency
telecom wants me to change phones and buy another contract
  • 6,784 Answers
Hi, this is a bad cell core in the battery. you can buy another battery pack and this will fix your problem.
Posted on Feb 12, 2009
MOBILE SHOWS CONECTED TO THE COMPUTER STILL IF IT IS NOT CONNECTED AND NOT DONE ANY WORK BECAUSE OF THE SAME
Remove the battery for sometime and keep aside. If the fault comes back even after the phone is switched back again then it is a fault within the phone software and might need a reinstallation. check also the charging pin , clean the socket and check once again.
Jun 28, 2012 | Cell Phones
Nokia bluetooth head set BH-105 can't conect with my nokia C6 mobile
1: SWITCH ON THE BLUETOOTH FUNCTION ON YOUR MOBILE 2: THEN CHANGE MY PHOES VISIBLITY FROM HIDDEN TO SHOWN TO ALL 3; MAKE SURE U HAVE PRESSED THE BLUETOOTH HEADSET SWITCH ON BUTTON FOR AT LEAST 10 SECONDS . 3: U WILL HEAR A BEEP SOUND WHEN THE HEADSET IS SEARCHING FOR PAIRING 4 NOW SEARCH FOR NEW DEVICES ON YOUR MOBILE 5 WHEN THE SEARCH COMPLETES IT WILL SHOW BH-105 6 : SELECT IT AND CLICK PAIR . FINISHED
Jan 26, 2012 | Nokia Bluetooth Headset BH105
My htc touch mobile gts switched off automatically though battery is fully charged and is new.is there a software problem or what?after getting off it doesnt start very easily.again i ve to start charging...
you have a mobile with an isemetric fault its built into the pcb due to bad current draw the only way to fix it is to replace the whole pcb if its new take it back if its under warrenty get it fixed or youl have this trouble for the remainder of the phones life.
this fault normally comes with the phone. it is not a fault that it picks up along the way
best of luck
please take the time to rate this advice
merry christmas
Dec 07, 2010 | Nokia N73 Cellular Phone
My mobile nokia3230 automaticaly switched off what to do
Hi friend,
Please check ur battery with the help of voltmeter.
If it shows more than or equal to 4 volt then it is a battery problem.
Replace the battery.
Otherwise .
It had internal hardware fault.......
But in 70% of mobile it is found as battery problem. Try to replace ur battery.
Mar 24, 2010 | Nokia 3230 Cellular Phone
I have a Kawasaki ZXR 750 H1. When starting the engine sometimes it wont start and I hear a clicking sound, I believe that it's the starter motor sticking. Am I right and how easy iis it to change?
It also could be the starter relay. First I would check all the conections to the battery, Starter relay in and out and the conection to the starter itself.
Sep 17, 2009 | 1989 kawasaki ZXR 750
Machine shut down, everything works except motor all fuses and reset good batteries fully charged cannot find any reason.
Did you check inside the steering stem and see if the conecter plug to the ignition switch is lose or apart?
Aug 24, 2009 | Pride New Mobility Legend 4 Wheel Scooter
Answermachine not picking up
I emailed Motorola support. Email bounced back and was redirected to their broadband support. Not what i needed at all. Tried again, same result. Gave up in the end and contacted BT who round a fault at the exchange which was blocking my Caller Id. Once they fixed this, the answer machine worked too. Weird. Especially as I plugged in an older phone earlier to test it and the answer machine on that one worked. Nil points to Motorola for support I have to say....
May 28, 2009 | Motorola Lands Phones
Canon 3000N Auto focus fault
No extra batteries.
Usually this is a lens fault as the focusing gear is all in the lens. Clicking sounds as if a rear pinion has cracked. It's not uncomon in the 'prosumer' level lenses where plastic gears are used a lot.
It's just possible the fault is which the auto-manual switch. This usually has a mechanical clutch coupled to it which physically disconnects the gearbox from the focusing ring, as well as operating a switch to tell the camera to turn off the AF system.
Dec 21, 2008 | Nikon F65 35mm SLR Camera
My phone isnt working!
you will need to take the phone to a mobile center to have it ifx or take the battery out and try again.
Aug 31, 2008 | Cell Phones
Nokia 6070 mobile handfree unit not work with mobile
sir.may b fault is lying with the radip option in ur fone...chk ur visual radio settings frm service provider....
Oct 14, 2007 | Nokia 6070 Cellular Phone
Cell Phones Logo
37 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
