Question about RCA F32648 32" TV
Tv doesnt come on after replacing verticaloutput ic
Apparently i change my verticaloutput ic in my 27inch jvc tv[old moldel,1999] with the wrong ic.i place the right one in after turning the tv on with the wrong one.now i have no picture,not even the horizontal line!how can i fix this please
  • luigi954 Feb 12, 2009
    the problem is i placed the wrong one in and turn on the tv!when i placed in the right one i didnt even get the line in the middle.it sounds like the board is powered but no picture!you think i may have blown the horizontal output?
    Sergeant:
  • 227 Answers
When you replaced the IC did you notice the polarity? There is a notch or an indent circle and it has to go back in the direction that the old was removed. Was it the exact replacement? Some substitutes do not work.
Posted on Feb 12, 2009
JVC av48wp30 question... I just replaced the STK 392 110s in my tv. I don't know what I did, however when I push the power button the tv clicks, as if wanting to turn itself on...but no picture or sound....
hello. 1/ did you go into service menu and mess with any settings before you changed the ic, if so this will cause the tv not to switch on 2/ did you test the resistors in front of the ic and the capacitors at either end. also there may be some protection fuses on the board that may have shorted i'll see if i can get service manual for you try get this tv back up and running thanks
regards
shaun
Nov 28, 2010 | JVC Televison & Video
Hi I have a jvc dlp hdtv that uses a Bulb jvc CL110u11AA. I understand that if the Tv is going dark that I should replace the Bulb. My Tv is also going Green most images are greener that normal. Is this...
It not the bulb,it still good.Ur tv have a problems known as convergence,"have colors shadows,colors misalinement,picture look like 3D" it dead.This convergence problems it happen to all DLP TVS sooner or later. The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts in the convergence board must be change to fix this.The shop will cost u $300-350 for parts and labors.
May 21, 2010 | JVC HD-52G786 52" Rear Projection HDTV
I have a sony projection tv Canadian model number KF-E42A10. The screen has a green tinge to it. All images are fine, just the color is off. When I go to the the guide the green is gone, it is a pukey...
Not the lamp if u have good picture.Ur 2 convergence ICS and all the resistors is dead.Colors misaligns,have shadow or 3D colors. Must replaced 2 ICS and all it resistors in the US shop will cost U $300 parts and labors.Canadian don't know.
Feb 10, 2010 | JVC AV-65WP74 Rear Projection Television
My jvc tv doesnt make any sound
this problum solution is 3 type .
[1] Repaer tv sound section replace sound ic and canacting spaer
[2] Use extra amplifer or home theater system{AUX mode} canact with tv. A/Voutput pin .
[3] if you are use setup box or chenal convater then canact A/v Out{ L -R ] to AUX input . home theater or extra Amplifer system
selact any one option and enjoye....
Oct 30, 2009 | Televison & Video
JVC AV-36D502: Input #3 doesn't work
Good day sir, its a different issue, about the capacitor, for as long as your replacement part is correct, it will work, now, there are several things you should check, the I/O device that controls the inputs of the TV, usually an IC, check your schematic diagram to trace the fault. check also the line from the input 3 to the controller IC on your diagram. Measure the voltage across the IC Vcc to ground if the IC is getting the right power, Low voltage can be cause by faulty capacitors, on the power supply line, or the IC itself is faulty, Circuit analysis and voltage measurements are needed to trace the faulty part. hope this helps thanks.
Oct 23, 2009 | JVC AV-36D502 36" TV
No video on my JVC AV-30W475 30" flat screen.
It sounds like you have bad solder connections in the Vertical circuit or the horizontal circuit. The Vertical IC may need to be replaced if resoldering does not help.
You will need to call a good TV Tech for this repair.
Aug 09, 2009 | JVC AV-30W475 30" TV
Older JVC 32" TV has lines & fold over at the top of screen. TV is about 6 years old.
Check the vertical section .. You will find few Electrolytick capacitor..replace all with new one or replace the filter capacitor at vertical IC supply..
Jul 10, 2009 | JVC HD-52G787 52" Projection Television
SHARP REPAIR HELP
changing the eeprom ic should solve your problem.
Apr 11, 2008 | Sharp 27N-S100 27" TV
JVC AV48WP30 Rear Projection TV
There are a number of different STK type parts. You need to look on the old ones for the part numbers. May have to dissassemble the heatsink to see the number. STK is pretty good about its numbers and you should have no trouble finding them.
partstore,com
mcminone.com
nteinc.com
Dec 31, 2007 | JVC AV-48WP30 48" Rear Projection...
Color convergence
RICKY-SOUNDS LIKE THE USUAL CONVERGENCE IC FAILURE.TRY LOOKING IN W/BACK OFF TV AND YOU'LL SEE COUPLE OF STK392-??? IC CHIPS,LOCATED ON A BIG METAL HEAT SINK.RETRIEVE THE EXACT PART # AND YOU CAN ORDER THEM AND INSTALL THEM YOURSELF IF YOU ARE GOOD AT SOLDERING ELECTRONIC PARTS,IF NOT BEST BET IS CALL AN EXPERIENCED JVC TECH.JOE TV
Nov 27, 2007 | JVC AV-48WP74 48" Rear Projection...
RCA F32648 32" TV Logo
46 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
