Question about Broan-NuTone WS330 Kitchen Hood
Replacement filters for ducted range Hood
Looking for a source to obtain replacement filters;
2 sizes.
8 x 10 in and 10.5 x 13.5 in
  • 10,865 Answers
Home Depot carried these filters.
Posted on Feb 12, 2009
  • skudder Jan 10, 2011
    Try Dave, Dawn, Lisa at Aire Filters, Formerly Filter Factory-TTN Inc.
    They have helped us find filters for our customers.
    HoodFilterFactory.com
    Even if you have just the dimensions and description they can help you.
Looking for repair parts for a buf03r
Air-Pro (Formerly Fujioh) Range Hoods & Ventilator Power ...
www.kitchensource.com > Kitchen > Range Hoods
Items 1 - 24 of 125 - This page contains Air-Pro (Formerly Fujioh) Range Hoods from ... Air-Pro (Formerly Fujioh) Double Panel Island Mount Wood Hood, Multiple Sizes & Finishes Available (CFM depends on. .... Ductfree Kits, Filters & Traps (4)
Sep 15, 2015 | Fujioh Kitchen Ranges
Brian range hood model CJD130SS fan light on display flashes with fan off or on.
I believe that's the "change or clean filter" indication. Clean the aluminum filters in the dishwasher, replace the charcoal filters if non-ducted, press the fan light over 3 seconds and it should reset.
Sep 02, 2013 | Broan-NuTone Broan Elite E661...
Reinstall RANGE HOOD from non-ducted to ducted
You need to uas a 7 inch duct to duct it out. You can get all the info you need in the manual on the link below. Please give it some time to load. If you need parts you can call Sears at 1-800-4-MY-HOME.
http://www.managemylife.com/mmh/owner_manuals/2285/KENMORE-Range-Hood-L1002022?brand_name_search=233.55213.000+
Good Luck and please rate 4 thumbs up for the free answer
Aug 01, 2010 | Kenmore Kitchen Ranges
Hi. I want to replace my Daewoo KOT 210UW over-the-range microwave. I need to know the size of the hood opening. How do I find this information?
All over the range microwaves are 30 inches. All the ducting is the same also. So you can replase with anyone you would like.
Dec 28, 2009 | Daewoo Microwave Ovens
Range hood installation
you can reseal the hole with aluminium tape
you can use screws with metal flat washer that has a rubber backing
May 28, 2009 | Broan-NuTone Allure III QS330SS Kitchen...
Can this be installed over an island?
Bring a focal point to your kitchen by having an island range hood, combining function and elegant form. A suspended hood is also an efficient way to vent
grease, odors and smoke to the outside from a island stovetop while you cook. You can install an island range hood in just a few hours with the right tools
and knowledge.
1.Wear safety glasses and work gloves. Turn off the electricity to your kitchen at the circuit panel. Cover the circuit breaker with a piece of electrical
tape to prevent people from turning the on switch while you are at work.
2.Lay work drop cloths on your cooktop and floor to catch dust and debris. Mark the duct opening with a pencil in the ceiling, where the island hood will be
installed. Be sure the opening is centered directly above your cooktop. Cut the opening using a hacksaw.
3.Go up to the roof, using a cat's claw and hammer to remove stucco, tiles, sheathing and insulation to make way for the steel venting duct. Drop a
plumb bob down the roof, making sure the line is straight down for the ductwork.
4.Follow the manufacturer's instructions for locations, installing 2-by-2 wooden blocks in the ceiling to hold the ductwork hangers.
5.Install the venting duct from the outside of the home, down to the location of the exhaust vents on the island hood. The ducts should easily slip into each
other. Secure all the duct sections with duct sealing putty, using a putty knife.
6.Screw a roof cap on the end of the duct at the roof. Seal any openings or gaps where the roof, ceiling and duct meet with silicon sealant. Let the sealant
dry, then paint with colors matched to the surrounds.
7.Place your hood upside-down on the floor, with the fan and filter facing upward. Locate and unscrew the metal electrical box cover on the island range
hood, to expose the wiring
8.Install the hood cover to the load-bearing ceiling frame with the package hardware through the four inside mounting corner flanges on the cover.
9.Measure what will be the distance from the bottom of your hood to the cooktop; it should not exceed 30 inches for exhaust efficiency. Have a helper hold
the hood in place while you attach the hood on the hood cover using the included screws. Use a level be sure the hood is level as mounted.
10.Connect the electrical wiring by consulting the manufacturer's suggestions or hire an electrician if you are not familiar with house wiring. Tuck the wires neatly in the hood electrical box and then replace the cover, after connecting the hood wires to the wall wiring.
11.Remove the electrical tape on the circuit breaker, turn on the electricity to your kitchen and test your island range hood.
May 26, 2009 | KitchenAid KHVU781RSS Stainless Steel...
Size of vent pipe
You will be fine with 2 bends in an 8 inch pipe. If you bend it more than 3 times though you will loose fan force. If you up to a 10 inch duct you will not have good fan force because the space is bigger.
Good Luck and Please Rate FixYa!
Feb 25, 2009 | Fantech Fan FG8XL
Lens Hood Size
The VX2000 lens does have a 58mm diameter thread for filters etc. The 72mm refers to the focal range (Zoom) from 6mm to 72mm. The 58mmm lens hood should fit, but I strongly suggest you obtain a SONY OEM lens hood with lens cap. Goto http://www.pro-cam-electronics.com or other professional camcorder sites for these items.
Peter Jansen
Dec 11, 2007 | Sony DCR-VX2000 Mini DV Digital Camcorder
Broan-NuTone WS330 Kitchen Hood Logo
203 people viewed this question
Top Broan-NuTone Kitchen Ranges Experts
Dan Phillips
Level 1 Expert
Phil Lovisek
Phil Lovisek
Are you a Broan-NuTone Kitchen Range Expert? Answer questions, earn points and help others
