Question about Edirol UA-25 External Sound System
No Sound From Channel 2 on my UA 25
I can't get sound from my R channel on my Edirol UA 25. I tried both Phantom and regular microphones. Left channel records fine using Sound Forge. No output from R. side. Tried mono and stereo switches. PR: wait... I: wait... L: wait... LD: wait... I: wait... wait... C: wait... SD: wait...
    Problem Solver:
  • 7 Answers
My laptop is problems .sound driver is uninstalled
Posted on Feb 13, 2009
Do not get MIDI signal via EDIROL UA25
Midi is data only, there is no actual sound to the midi tracks themselves. They need to be assigned to either a software synth or an external synth to actually make the sounds you want to hear.
For instance if you load a demo of a midi sequance you will need to add a software synth such as the TTS-1 or Roland sound canvas which are general midi compatable and will play the instruments sounds assigned to the demo's midi channels. Use the Synth Rack feature in Sonar to open one of them. Then you will need to assign the output of each of the midi tracks to that particular synth and you will get sound. Make sure to assing the synth's audio track to you UA-25 as its audio output.
I would suggest reading in the manual and following the tutorials included in the manual to get yourself familier with how this is all done. spacer.gif
May 25, 2008 | Edirol UA-25 External Sound System
Digital in out
The ada800 gives out 8 channels of ADAT, the edirol UA-25 are only stereo opticals and not compatible with the ADA8000 as it does not have any adat inputs or outputs.
Hope this helps
Jan 31, 2010 | Edirol UA-25 External Sound System
How to use a condenser mic on a mac/in garageband?
If you are sure that the microphone and the cable is OK, it could be that you're phantompower is to low.
Normally you need 48 Volt, you can check that with voltage meter between pin1-2 and 1-3 from the XLR.
regards,
Gerard
Jan 22, 2010 | Audio Players & Recorders
AKG Perception Microphone ony recording in mono but want stereo.
I have similar problems with inputing stereo sound. How do you know your mic port on the PC is set for stereo? What kind of a cable are you using? If it is an XLR, the connection is pure mono. Maybe you need a TRS cable, which looks like a 1/4 inch jack but is really stereo. Maybe you need a stereo mini. Usually a cable mismatch is the problem. Is your phantom power supply passing stereo? All the ones I have seen are mono. You may need two. Is your sound capture set for stereo? Are the input level controls set correctly for equal volume on left or right channel? I would try the mic with a regular amplifier to insure both channels are working. Then trace the signal from mic to power supply and power supply to computer.
Dec 03, 2008 | AKG Perception 100 Microphone
No sound being picked up by Edirol
I discoverd the the digital in button had been pressed in. This was the mic was not picking up any sound.
Jul 09, 2008 | Edirol UA-25 External Sound System
Only Hearing Sounds on One Side of Headphones
your headphones are bad sounds like cheak out the new seinhezer hd280 pros ok 99 bucks best they make
Jan 23, 2008 | Edirol UA-25 External Sound System
Mic problems: playback works great through interface, microphone isn't being detected
Check in contraol Panel under sounds and audio devices that you are using the Edirol and not an on board sound. It sounds like although the cards installed its not selected as the audio device to record from. You will also have to tel Adobce audition to select the Edirol as you audio card of choice as it to can be changed to select input from other sound devices.
Mar 31, 2007 | Edirol UA-25 External Sound System
Edirol UA-25 External Sound System Logo
272 people viewed this question
Top Edirol Computers & Internet Experts
Folusho Adeyanju
Folusho Adeyanju
David
David
Ben Armstrong
Are you an Edirol Computer and Internet Expert? Answer questions, earn points and help others
