Question about Brother IntelliFAX 4100 Laser Fax
How to shut off the fax answer on brother 4100
Would like to use as printer , scanner, copier, but not fax answer
  • 62 Answers
Describe your problem in detail. I should be able to help you out if I understand exactly what you are needing to know.
Posted on Feb 14, 2009
  • Terry Watson
    Terry Watson Feb 14, 2009
How to set a brother intelli fax 4100?
just follow the instructions for setting up your fax here
Do not forget to rate my answer
Lucas
Jul 07, 2011 | Office Equipment & Supplies
I have a Brother IntellyFax 4100 e and when it is time to send faxes all receipients say that it came out black, entire page black.
You will need to replace the contact image sensor with a new one and then the software needs to be set to set up the scanner correctly.
Jun 02, 2011 | Office Equipment & Supplies
Black pages
Try to copy a document. If the copy comes out black then the the scanner is dirty. Clean the scanner glass (products on the market that clean by sending through the scanner) and try to copy again. If after cleaning the scanner, the copy is still black you have a scanner issue and the laser/scanner unit will need replacement. Best of luck and please post back with any questions or just to rate the solution.
Greg
Aug 10, 2009 | Brother IntelliFAX 4100 Laser Fax
When I send out a fax using a Brother Intellifax 4100 a black vertical line appears on document on the receiving end
this is a very common problem. You have to clean the scanner lamp glass. There must be some dust or correction fluid if you have ever used which has stuck on the glass of the scanner lamp which prevents the light from falling onto the originals. Lift the control panel, you will find the scanner lamp where theoriginals are normally fed, clean with a soft cloth and alcohol.
Jun 04, 2009 | Brother IntelliFAX 4100 Laser Fax
Brother 4100 fax error code # 71
Error 71 is a laser scanner error.
Inkworks
866-381-0541
Nov 19, 2008 | Brother IntelliFAX 4100 Laser Fax
Lift up the operating panel and clean the wite-off on the little scanner glass.
Aug 20, 2008 | Brother IntelliFAX 4100 Laser Fax
Yes it is. Check with BrotherUSA.com for possible warranty. It will cost about $150.00 to repair . You can buy new for about $300.00.
Factory refurb. for $ 269.00
May 20, 2008 | Brother IntelliFAX 4100 Laser Fax
Brother IntelliFax 4100 sending solid black pages
It sounds like the CIS (scanner) has failed in both machines. Its no generally not a common problem. I would change one every six months if I was lucky.
It may point to something in your environment. I have have seen rust build up on the contacts of the scanner cause this problem. So if you have high moisture or are close to the ocean this maybe a problem.
Feb 14, 2008 | Office Equipment & Supplies
Brother IntelliFAX 4100 Laser Fax Logo
52 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
