Question about Lexmark X73 All-In-One InkJet Printer
Printer will not print.
The light is flashing two times than it pauses. We had a message to install the printer when it was already installed. It would not print in color then when printing in black it would use to much ink. Now the cartridges slam from right to left when we turn the computer on or trying to use the printer. Can someone tell us what this means?
  • loreal1 Feb 14, 2009
    Thanks so much for your solution of getting rid of our printer and getting a new one. We have fixed the problem and am now enjoying our printer.
  • 29 Answers
Hi
if cartridges are slamming then its a problem with encoder strip..this is a transparent strip that runs behind ur cartridges...ther is nothing much u can do to fix this...u need to buy a new printer...contact lexmark tech support on 800-332-4120 for discounts
Posted on Feb 12, 2009
Canon LBP6000. Data transfer to the printer timed out, or a transfer error has occurred. Click [Resolve Error] to resume printing, or click [Cancel] after pausing the job, then try to print again.
Best to un-install the printer drivers, softwares related to this printer. Go to Canon.com and download the latest drivers and software. Connect the printer to the computer and let the computer recognise it and then install the drivers from your download. You can also check if there is any damage to the cable as this could also stop the communication between the computer and printer.
Dec 09, 2013 | Canon LBP6000 Laser Printer
Tip
Resetting Blinking Toner Light HL-2140
Here is the procedure for resetting the Toner flashing light on Brother HL-2140 (sources for other answers here and self testing - specific to HL-2140)
  • Open the front cover and leave open.
  • Turn the printer off.
  • Hold the "white button" while turning the printer on. (All panel lights should be on.)
  • Release the "white button".
  • Press the "white button" 2 times (Pause, wait for all lights to come on.)
  • Press the "white button" 5 times. (All lights to come on again, then go out.)
  • Cancel "maintenance driver" install, if prompted
  • Close cover.
  • Power cycle printer.
This will:
  • reset the toner light (stop blinking)
  • restore the printing darkness (when toner light flashes, printer prints lighter to save toner)
  • keeps the printed page counts and drum life info
on Mar 06, 2011 | Brother HL 2140 Laser Printer
My Dell All-In-One printer is not printing at all and the paper comes out blank. I need help.
Ensure that the printer power cable is firmly connected to the printer and the electrical outlet
Determine if the printer has been held or paused
  1. In Windows XP, click Start® Settings® Printers and Faxes.
In Windows 2000, click Start® Settings® Printers.
  1. Double-click Dell Photo AIO Printer 922, and then click Printer.
  2. Make sure a check mark is not next to Pause Printing. If a check mark is next to Pause Printing, click Pause Printing to deselect it.
Check for flashing lights on the printer.
Ensure you installed the ink cartridges correctly and removed the sticker and tape from each cartridge
Make sure you loaded the paper correctly
Jan 19, 2011 | Dell 922 All-In-One InkJet Printer
Five flashes pause then a further 5 flashes
This error mean "non installed or defective print head".First open cover and remove the ink cartridges.Then open holder and remove the print head.Clean the contacts on printer and print head using piece of cotton and some alcohol.Then put back all again.If the problem persist you need to replace the print head.It's part number is QY6-0057.
Nov 25, 2009 | Canon PIXMA iP5000 InkJet Photo Printer
My Printer won't print, Amber light won't stop flashing.
Install the new cartridge for permanent solution for this error.
Sep 17, 2009 | HP DeskJet 940c InkJet Printer
In canon pixma ip1700 Alarm light orange flashes 15 times
Fifteen Flashes: The FINE Cartridge cannot be recognized.
Possible causes are as follows:
- The FINE Cartridge may not be installed properly.
- The FINE Cartridge may not be compatible with this printer.
Install the appropriate FINE Cartridge. If lines are misaligned or the resulting output is not satisfactory, carry out the Print Head Alignment.
Apr 06, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Printer won't print
What model of lexmark printer are you having a problem with? How is it connected? Have you change an ink cartridge? Has anything else change when you moved it? Like new computer , different electrical outlet etc.. What type of computer are you using and what operating system are you running? Please wait to rate me untill I get the infromation I need to help you, thanks. I will do my best to help you with your problem.
Jun 10, 2008 | Computers & Internet
Canon pixmaip3000 states printer offline & does not print, flishing power lights green & orange
I have canon PIXMA ip3000. After power cut at night printer doen not print. I re installed the drivers but no result. When try to print message appears printer is offline. POwer button is flashing shorthly green after orange lights. Error code 5100.
Please advice what can I do urgently.
Mar 10, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Canon i9950
Seems impossible to reset the counter, is there a way to manually reset?
Oct 10, 2007 | Canon BubbleJet i9950 InkJet Photo Printer
Flashing Green Light/ Computer can't communicate with printer......
Hi. The flashing code signifies that there is a fault with the connection between the ink cartridge and the printer - usually because either the tape is still on the cartridge or maybe some glue from the tape still on the contacts. In my case, I think the cartridge was simply knackered, so I threw it away and opened yet another ink cartridge. It now works fine.
If you want to test yours, simply take out both ink cartridges, and re-insert them one at a time. If you've put a working cartridge in the flashing will stop; if you've put the dodgy one in it'll still flash. Just replace the dodgy one.
Hope this helps.
Dec 14, 2006 | Dell A920 InkJet Printer
Lexmark X73 All-In-One InkJet Printer Logo
66 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
