I have an x-box 360 which has shakey video which shows up only on the games themselves - the video is okay while it's loading but starts it's problems as soon as the game starts
Greenkamel, what happened to you about your xbox 360 console should not border you much because there is a solution to it at your doorstep, just rush to xbox360repairuk.blogspot.com
My device had a different issue related heat sink of fan but I got it fixed by Repair Guide They have covered many topics, You may come across many small issues.You can try this
To do this simply insert the game onto the drive and go to the menu where it shows the game disc.
Press Y on the image of the game and select "Install to Hard Drive".
After the game finishes install select "Play From Hard Drive"
If the game fails to install try cleaning the disc with warm water NOT hot or cold water but WARM. After that dry the disc with a soft towel or some sort of SOFT cloth by wiping away from the center of the disc.
As long as it is the original drive in your system then it will need to be serviced or replaced with a new one. We can provide this service. Email us for a free estimate if interested. [email protected]
Yep this is the EXACT issue I had so the only solution is call 1-800-4MY-XBOX and you will be recieving a new xbox because the problem is to expensive for microsoft to fix so they just send you a new one.
The Repair and Shipping is free they send you a UPS Tracking Code and Xbox.com Code where you can keep track of your xbox at all times.. but when I did my repair they require you to use your own box now due to people reconiseing the big white box and ended up stealing it now biggie though a box to put the 360 in is only 4 bucks and they will pack it for an addition 60 cents. but mircosoft will tell you all this I'll ******* now and please 5 Star this will prob be the best and only solution.
Next time the game is loading, try clearing out the cache. You can do this by holding down the A button while the game loads. When you see the Oblivion title screen come up, your cache should be cleared. This may clear up your issue.
If that doesn't do it for you, you can try to clear the cache out another way. There are many websites that can assist you with that. When in google, search for: Clear XBOX 360 cache.
Hope this helps you.
hi : When i went try and set the 360 back to SD it went back to one red light on the console - These x-boxes are junk!
Mike
