Question about HP Compaq Presario F730US Notebook
A 1-1/4" wide band on screen from top to bottom
I've had a 1 and a 1/4 inch wide band from top to bottom and in the middle of the screen from side to side for approx 4 months. It's see through but is either green or pink depending on the back ground. I haven't been able to get it to a repair person and would like to know what may cause it and what the fix might be?
Thank you for any ideas you might have,
Becki
  • 191 Answers
Your laptop trouble mostly cause disconnection between motherboard LCD signal output socket to the lcd panel driver board(at back of panel there is a board at top of back panel. there are two posible repair:
1) check disconnection parts like LCD signal cable between motherboard and LCD panel and all plugs sockets around there. it could be fixed.
2) LVDS decode and driver board damage or matrix rubber cable disconnected they all tough to repair, so that is only easy way to change a new LCD panel finally
it this helpful please feed back thanks
Posted on Feb 12, 2009
Why does my TV show discolored vertical bands and can I fix it at home?
The T-con board controls the picture elements on the screen. Usually replacing this board will solve the problem. If you can touch the screen and the lines disappear and later reappear, that says the screen itself is defective. The only fix is to replace the entire screen.
Oct 10, 2015 | Hisense F42K20EGB 42" LED 1080p 60Hz
I've accuired a Vizio P50HDTV10A that was dropped.
Yes, do not bother as it sounds like the display panel is damaged--time for a new set parts cost wise. Since you have nothing to lose open and examine it with the faint hope a plug is loose or off or a board cracked,,,faint chance only.
Oct 23, 2012 | Vizio P50HDTV10A 50 in. Plasma HDTV
White Band On Screen - Remove It!
if a white band is seen---go to a blank or unused video input and examine the screen---both sides---if it is seen on both (even if more so on one side) you may have burned the screen by using the 4x3 format.
If this it is permanent damage.
Mar 31, 2012 | Mitsubishi LT-46133 46 in. HDTV-Ready LCD...
Can not locate belt dryer runs but tub will not turn
The belt goes around the tub and is driven by the motor which is also the blower motor. The motor is located in the bottom at the rear of the dryer. To access the belt, you first have to remove the top. To do this, remove the two phillips screws under the filter screen door. Remove the filter. The top is spring loaded to the rear and hooks in the front. To release, pull the top toward the front and lift up. You can do one side, then the other. When both sides are released, lift it up like the hood on a car. The belt is around the drum. It looks like a thin rubber band, approximately 1/8 inch thick and 1/2 inch wide.
Oct 04, 2010 | Roper RGX4634KQ Gas Dryer
I have a 2inch wide band down middle of screen on
1) Have you installed new drivers or software or drivers? If so, remove them and restart the computer.
2) Try applying pressure with your fingers on top of the screen. If the band dissapears or dimishes, you may have a broken screen and it will need to be replaced.
Mar 19, 2010 | HP Pavilion zd8000 Notebook
Dark band the length of the right side of the printed page
Hello sir; I suggest you go to replace a new cartridge, see what's happen.
Apr 07, 2009 | HP LaserJet 1020 Printer
White block on left side of moniter screen
the screen has failed - i once had a screen with same problems :() order a screen from here newegg.com
Mar 16, 2009 | Computers & Internet
Dark band on left side, Samsung HL-R5668W
the reflecting mirror is likely loose and falling down inside the light reflecting tube. you should have seen the band getting darker and larger,
the small mirror is in front of the lamp and bends the light,
remove the lamp and look down the tube (light path)
May 06, 2008 | Televison & Video
Line on screen
if you found out how to fix or what is wrong with tv please let me no shanequinn@tiscali.co.uk
Apr 07, 2008 | Fujitsu Plasmavision PDS-4233 42 in....
HP Compaq Presario F730US Notebook Logo
109 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
