Question about Sony Ericsson Walkman W810i Cellular Phone
Cannot memory card after flooded.
Once my phone was flooded in swimming pool for 1 minute approx.
After that I was try to dry out naturally (open the battery cover, take out the battery & let dry by wind). the day after my phone active again but caanot read the memory card. Could you suggest me what really happen & how to fix it.
Thank you, regards.
Agung W
  • wijarnoko_ag Feb 12, 2009
    Thank You.
    The Memory Card it self is Good (tried on Digital Camera & Comperter). I belive thr problem came from the Cell phone.
    Wait the answer...
    Could you suggest me what should I do?
    Thanks.
    Waiting.....
  • 52 Answers
More and likely it was just to much water for your memory card to handle and it is now damaged. You will need to buy a new one unless the manufacture that makes your memory card is willing to be nice and give you another one for free! Good luck
Posted on Feb 12, 2009
  • JennHolland Feb 12, 2009
    hehe you just answered you're own question then...if it worked somewhere else and not your phone. Then it's the phone that's the problem. :-)
It tries to fire once and fails. heater service lite then comes on. The LED red lite on the Fenwl Box blinks 3 times indicating ignition lock out. What do we do to fix this problem?
Hot Tub Spa - Heater Troubleshooting Guide - PoolAndSpa ...
www.poolandspa.com/page596.htm
The World's Oldest & Largest Web Site For Swimming Pool & Hot Tub Spa .... close to the element, and the pump suddenly quits - it's dry fire time in just a minute or two. ...We think it's a safe bet to say that one of the major causes of heater failure ... It's much easier to describe what doesn't cause it than to attempt to explain ...
Spa and Pool Heating Problems - Swimming Pool Information
Jan 05, 2016 | Pool & Spa
Pool heater won't heat water
How big a pool? You normally will not notice a temperature rise immediately. On average, swimming pools will see a one degree rise in temperature every 45 - 90 minutes.
Jan 22, 2013 | Jandy Laars LX Pool Heater / 400,000 BTU /...
My pool room flooded and the filter and vacuum pumps were completely submerged. Can they be dried out or are they ruined? Filter KSB s838 Filtra 14.3d Cleaner pump DAB Eurocom SP 40/50 Mono The power...
WARNING DO NOT (DO NOT) TURN THEM ON SHUT THEM OFF AT THE BREAKER ! GET A FAN OR 2 OUT TO THEM AND LET IT RUN ON THE MOTORS FOR A FEW DAYS ! IT'S GOING TO TAKE TIME TO DRY THE WINDINGS OUT.. REAL GOOD ..IT TAKES TIME
Jun 09, 2011 | Hayward 1 Hp Northstar Swimming Pool...
My phone was fine all along then on sartuday night i went for choir practice and i didnt have pockets so i placed it over my breast i think its the sweat that got it becayse after the choir practice it was...
Don't worry,try the following ,it usually works:Open the back of you phone and pull out the battery,SIM card(if any),Memory Card(if any) and dry the phone in the Sun.Don't use a Hair Dryer,it may spoil the Circuit boards.I did this when my phone fell into the swimming pool,it worked.
Have a Good Day!
Tahnk You.
Feb 15, 2011 | Nokia 6600 slide Cellular Phone
Goo day! my canon IXUS 90 IS drop at the swimming pool i tried to dry the cam with a towel my friends told me to dry it with a hair blower as soon as i got home i tried to blow dry the cam...the next dya...
Wait ,Wait ,didn't you romove the Canon digital ixus 50 battery at once when the camera drop at the swimming pool. You'd better ask the CANON Service Centerto for help,this will completely good and safe for your Canon IXUS 90, wish you good luck!
Dec 14, 2010 | Canon IXUS 90 Digital Camera
My olympus 1040 was dropped in water for a few seconds,i dried it out and now it will turn on but screen is blank,is there anything i can do or is it only fit for the bin..........
Solution: The most important thing to remember if your digital camera should be partially or fully submerged in water is to act quickly. Once your camera is out of the water, avoid the urge to turn the camera on to see if it works and instead remove the batteries immediately to prevent shorting any of the internal electrical components. Remove your memory card also, otherwise you may lose the pictures you’ve already taken and saved to the card.
Leaving the battery and memory card compartments open, dab away any excess water with a dry cloth or paper towel. Then, use a household hairdryer set to the lowest heat or no-heat setting and blow dry the camera for 10 to 15 minutes.
Although the outside of the camera may be dry, it’s what’s on the inside that counts. If any moisture is left within the camera, it may, over time, grow mold, which can interfere with the camera’s operation. If the camera was dropped into a chlorinated swimming pool or a saltwater lake, your camera’s components may suffer corrosion over time, and your camera will eventually stop working.
To help draw moisture out of the camera, pack your camera in a bowl filled with silica gel (the packets of small transparent beads often found in various foods, electronics, and clothing packages) or uncooked rice. Both materials can absorb and hold excess water that may be left in your camera. Leave your camera to dry for at least 24 to 48 hours. Once you are certain that your camera has completely dried out, insert fully charged batteries and press the Power button. With any luck, your camera will function properly. If not, you may try contacting a camera repair company to ask advice or inquire about repair options.
Jun 26, 2010 | Olympus Stylus / mju 1040 Digital Camera
My phone got wet
Try removing the battery, using a blow dryer to air everything out in battery compartment. If there are any tiny screws or way to open up the phone itself, open it up, and blow everything inside there too.
Let it dry out completely and then see if it will work again. My guess is no, because once the circuits get wet, they are pretty much damaged and irrepairable.
Hope this helps at least some. Good luck!
Jul 31, 2009 | Samsung Hue (SCH-r500) Cellular Phone
My cell phone got dropped in the swimming pool.
take the battery and sim card out. put the phone, sim card and battery in a bag of regular dry rice for two days. reassembly, this has worked for my phone and ipod.
Jul 03, 2009 | Nokia N70 Cellular Phone
KX-TG5632 fell into the swimming pool. Can it be fixed?
soak in rubbing alcohol and let dry for a couple of days shake out excess alcohol and make sure(take out battery first)is completly dry before recharging!!!! Good Luck!!! had cell phone drop in lake did that and worked!!!
Jun 24, 2009 | Panasonic KX-TG5632 Phone
Sony Ericsson Walkman W810i Cellular Phone Logo
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
