Question about Panasonic ER 145 Hair Trimmer
Panasonic Er 145 clipper
I've had Panasonic clipper er145 for 4 years, It suddenly stopped recharging and now will only work with the electrical cord. now even plugged in the motor is very weak and surges intermittently when I touch the blades. any suggestions?
5 Suggested Answers
geokohler
  • 304 Answers
SOURCE: barber clipper blades
Soak them in motor oil the use 400 grit wet sandpaper (The black kind available at the hardware store) and lightly sand off the rust. They will be good as new when you are done.
George
Posted on Jul 25, 2008
  • 22 Answers
SOURCE: Oster clipper blades get red hot and won't cut.
see this link, its for the A5. The A5 is the animal version of the 76.
http://www.peasridge.co.uk/clipper-advice/clippers-products-oster-a5.shtml
I dont know what model you have, but if you need schematics for YOUR model see this link.
http://www.clipperrepair.com/parts.htm?brand=8
Posted on Feb 02, 2009
SOURCE: THE BLADE HAS COME OUT, AND IAM UNABLE TO REINSERT IT
poor website to get any helpful information, don't waste your time
Posted on Feb 01, 2010
brector3
  • 1585 Answers
SOURCE: My Panasonic ER 203 with problem spring of
If the spring on the blade has come out, the blade has to be broken. The manufacturing process for this type of blade makes it impossible to take it apart without breaking the plastic that holds the spring. There is simply no way to effectively repair the blade.
You will need to replace the blade or the entire unit.
Posted on Feb 14, 2010
  • 10 Answers
SOURCE: oster clippers blade
John! No Problem!
First put the bigger of the two blades witht the size/number facing down, put the cutter on top. (with the side with the flat side of the teeth facing down) Then put the tongue guide inside the tension spring, make sure the tension spring rail is on the tension rail and place them on top of the cutter. To see which bits these are go to: http://www.sheareaseltd.com/clipper-blade-sharpening/clipper-blades-the-parts
This picture whows the front and back, it differs slightly from your blade, but its same meat different gravy!
Hold all this together with your finger and thumb, flip it over and scre the whole lot together!
Posted on Aug 03, 2010
Where can I purchase the Wahl Wahl Hair Clipper Taper Replacement Round Power Cord 00647-500
Wahl Clipper
3001 Locust St
Sterling IL 61081
815-625-6525
OR--Electric Shaver Service 888-476-1785
Aug 25, 2014 | Wahl Hair Clipper Taper Replacement Round...
Gateway ZX4300 - power adapter problem
Verify all specifications of your previous charger and new chargers/adaptors.
Jun 24, 2013 | Computers & Internet
Adapter for panasonic hair clipper ER147
panasonic ER147 hair clipper adapter is AP-22290 charger power cord replacement recharge adapter 220 volt for panasonic er147 national or panasonic hair clipper.
http://www.menelectricrazor.com/panasonic-er147-charger-power-cord/
Jan 13, 2013 | Health & Beauty
How do I reduce my clipper's rattling noise and still be able to cut properly?
The power screw is the correct way to adjust the problem you describe. If you have attempted to adjust it as instructed in the user manual and have not had satisfactory results, there may be a problem with the clippers.
Most Wahl clippers have a 1 year or longer warranty. You can call Wahl for warranty service at 1-800-334-4627
Nov 12, 2011 | Health & Beauty
My Panasonic Lumix DMC-FX8 suddenly stopped working. I've tried recharging the battery. It's a few years old, is it just done?
My suggestion would be to try with new set of battery.
You can also try this.
Remove the battery and clean the contacts between the camera and battery and insert it. Sometimes tapping the camera on the palm 3-4 times bit gently too fixes the problem.
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Dec 29, 2010 | Panasonic Lumix DMC-FX8 Digital Camera
Runs if tipped to the right. Not if tipped to the left
check the electrical cord at the clipper connection by bending the electrical cord at clipper end with the clipper on if the clipper stops the electrical cord is broken in side.if this will dose not locate the problem, the next possible problem will be the coil inside the clipper the coil has a broken field winding wire. Have a Wahl clipper repair shop repair the problem.
Mar 30, 2010 | Wahl Magic Clip Clippers Hair Trimmer
Panasonic clipper
Buy Wahl....best clipper/low maintenance
Feb 12, 2009 | Panasonic ER 145 Hair Trimmer
Pansonic er200 need new rechargable battery
two AA rechargable batteries can be used, and yes you can replace them yourself.
Dec 05, 2008 | Panasonic ER 240 Beard Trimmer
Hair clippers that don't work
The unit should be sent into the manufacturer for a complete review.
Mar 30, 2008 | Norelco 8883 XL Electric Shaver
Panasonic ER 145 Hair Trimmer Logo
302 people viewed this question
Top Panasonic Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Jerry Greenberg
Jerry Greenberg
Rick Goldsmith
Rick Goldsmith
Level 1 Expert
Are you a Panasonic Health and Beauty Expert? Answer questions, earn points and help others
