Question about Vulcan ECO2D Electric Single Oven
Vulcan oven chatter
Vulcan eco2d oven contactor chatter when heat comes on
replaced contactor
  • 640 Answers
Sounds like your losing the voltage to the coil on the contactor.Are you handy with a multimeter?I can step you through it.
Posted on Feb 12, 2009
Gas valve on Vulcan oven SG4D-1 makes a chattering noise?
if it is a buzzing noise it is usually not big deal. If it is truly a chatter, I suggest replacing as the electric coil is going bad.
Jun 19, 2017 | Vulcan Ovens
Lincoln oven heating element not working
There are many reasons why the element in the Lincoln oven could not be coming on. The first one is that it could be that the oven temperature settings is bellow room temperature or the probe is not functioning. Secondly the heat relay contactor could be faulty, Thirdly it could be that the oven element are faulty or the wiring connection from the relay contactor to the elements could be open. Lastly you need to to check that the air pressure switch is working and not clogged with dirt otherwise check that the blower motor is working. all that could render the elements not working
Sep 29, 2013 | Lincoln Conveyor Oven - 1133-000-A
Why is the main 24 volt coil contactor chattering? I replaced the 3-pole contactor and thermostat but problem not solved.
chech the voltage going to the contactor if it is less then 21 volts i would change the transformer. sometimes the contactor will chatter because it is not getting enough voltage.
Nov 23, 2011 | Lang Manufacturing LGM-ECCOAP 1 Deck...
Oven does not come up to Heat as Oven control denotes
It is probably the thermistor in the oven cavity top right hand corner sometimes these get scraped by sheet pans or scrape the wires
Nov 17, 2010 | Vulcan SG4D Gas Single Oven
I need h/p fan blower motor for my oven model
You can find it at Heritage Food Service Equipment. You motor is MOTOR,240V 50/60HZ, (2 Speed, 1/3 Hp.)
The part number was 00-358516-00002 but has been changed to 358516-00002 and it list at $557.10. Heritage's wed address is http://www.hfse.com/ .
Please rate solution .
Sep 16, 2009 | Vulcan ECO2D Electric Single Oven
No heat to the oven
if the heating element "rod" doesn't turn orange (hot) when it's on it's bad so; remove the heating element and get a new one from an appliance parts site on the web and install it don't forget to unplug the range first!
Apr 20, 2009 | Vulcan ECO2D Electric Single Oven
Manual
Operations Manual
http://www.vulcanhart.com/manuals/F-30976.pdf
Parts
http://www.vulcanhart.com/manuals/F31000.pdf
Service
http://www.vulcanhart.com/manuals/F-24575.pdf
Hope these help, please rate me if they do or don't
Thanks
Jan 15, 2009 | Vulcan ECO2D Electric Single Oven
VULCAN ECO2D ELECTRIC OVEN
Here's the link for the parts list on the EC02D:
http://www.vulcanhart.com/manuals/F-30998.pdf
Here's the link to the vulcan site with additional product PDF files if you need them later.
http://www.vulcanhart.com/product_lit_action.cfm
Hope that's a Fix it for you! :-)
Jun 26, 2008 | Vulcan ECO2D Electric Single Oven
Vulcan ECO2D Electric Single Oven Logo
174 people viewed this question
Top Vulcan Ovens Experts
John Tripp
John Tripp
Treefrog15
Treefrog15
Are you a Vulcan Oven Expert? Answer questions, earn points and help others
