Question about Coleman Mach 15 Air Conditioner
Fan is not blowing cold air
Fan blows fast, filters are clean, outside fins are clean. NO COLD AIR Does anyone have an suggestions? Thanks
  • gokartracer2 Feb 12, 2009
    also i am not hear the compressor even try to come on.
    President:
  • 1,902 Answers
Sounds like the freon is gone in the system. These small system will lose freon and then you get air and nothing else
Posted on Feb 12, 2009
  • Jeremy Reddick
    Jeremy Reddick Feb 12, 2009
    If you are not hearing the compressor then, the compressor is shot.You know that the unit is getting power so the compressor would be getting power also. Either get a tech to replace the compressor about 200 dollars or replace the unit.
Air conditioner shudders, stops blowing cold, then resets every 5 mins
Cleaned the filter this AM and closed the door but now a red
light keeps flashing.
Jul 19, 2013 | Sharp Cv-p12lx 11500 Btu Portable Air...
2000 NISSAN 4X4 P/U A/C SYSTEM WILL BLOW COLD WHEN OUTSIDE AIR TEMP IS COOL, WHEN HOT OUTSIDE AIR BLOWS HOT.
your auxillary fan is not working. this fan is responsible for cooling the freon that is being circulated in your cooling system... check if there are any loose wires in front of the engine bay.
the auxillary fan is located right beside your radiator fan.
May 17, 2012 | 2000 Nissan Frontier
My air condotioner is blowing out warmair.It blows out cold air forabout 5 minutes then warm again it's a 5050 series
It sounds like the unit is cycling on internal overload. The overload is switch the protects the motor from getting too warm. This would explain your cooling "cycling".
Check the condenser (the outside coil with vertical fins, the back of the unit). Is it clear of any debris? If not clean it using water or compressed air, using care not to bend or damage the fins or electrical wires/components.
Check the condenser fan motor. You can usually see the condenser fan motor through vents in the sheet metal. Check to see the the condenser fan motor runs when cooling is turned on, secondly check to make sure the fan blade is not broken, usually the blades are plastic. If the motor or fan blade is bad, you need a replacement.
Jul 12, 2011 | Goldstar WG5000 Air Conditioner
I have a ruud ubhc-17j11sfd that does not blow cold air. it blows room temperature air only. the unit seems to run ok and the outside fan runs ok also. The filter is cleaned and the thermostat is set to...
Hello, if the airflow seems good and the unit is clean it is possible that the unit has a low refrigerant charge due to a leak, if you have a thermometer measure the return air and the supply air, tjen find the differance between the two, if it is below 15 then the unit is undercharged and will neec to be recharged.
Jun 15, 2011 | Ruud UBHC Air Conditioner
Wall A/C only SPORADICALLY blowing cold air. Turn it off and back on, you can feel it's cold, but only if you're 5 inches from it. After a couple of minutes, fan is only blowing warm air again. Vacuumed...
if it blows be not with force like it used to it can be fan motor capacitor not boosting fan speed. but if speed is not the issuse. remove and clean both coils water hose
Aug 29, 2009 | Heating & Cooling
Ac fan on, blowing air, but not cold
Check outside unit if unit and compressor are running feel the large line to see if it is cold. If compressor is running and line is not cold possible charge problems. You may have a capacitor problem outside. they go out quite often. You can change this yourself, Open up outside unit and the cap is the silver bullet with terminals out the top. Bad cap can cause compressor to not operate and also the fan. You need to clean the coil inside or at leat check the coil to see if it is clean. You can clean theis with a toilet brush do not go against the coil bit brush with the fins. You may need to call a service tech but try these options first. russ
Aug 15, 2009 | Heating & Cooling
Panasonic air con unit is not blowing cold air out.
This unit is use in motels etc. Check the ouside coil ( conderser) from the inside (discharge fan ) for dirt. Most of these units are floor level . This can cause a unit to short cycle ( cold air is at the floor) .
Jul 17, 2009 | Carrier 52PQ307 Wall/Window Air...
GE Refrigerator external fan - air flow?
This really depends on the manufacturer and their preference on design. First, the fins at the compressor are part of the condensing coil. Most all makers have air pulled into the condenser coil and blown across the compressor. You should be moving room temerature air across the condenser and the air from that is usually then moved across the compressor.
Hope this helps clear it up .
May 08, 2009 | Refrigerators
No Cold Air
Have you removed inside filters and cleaned them? have you gone up and removed the cover to see if fins are dirty, or perhaps wasps etc. Does fan only have one speed on thermostat. Does fan run faster on fan only operation? Is it tripping your breaker at all?
Jul 25, 2008 | Dometic Rooftop RV Air Conditioner
Coleman Mach 15 Air Conditioner Logo
261 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
