Question about Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher doesn't clean the top rack whwn we riun it.
I have a Whirlpool Quietpartner 3 that doesn't clean the dishes on the top rack. Can you fix it?
  • 1 more comment
  • Anonymous Feb 12, 2009
    what would cause a pressure problem, pump going out?
  • Anonymous Mar 02, 2009
    I had a dishwasher repairmain come out for this same problem. He said to run CLR through the dishwasher and if that didn't work just replace it. (Charged me $75 for his "services"!) I did the CLR and it worked for a few weeks and then the problem started up again. I'm going to try using it on a regular basis to see if I can prevent the problem from starting up again.
  • Anonymous Mar 27, 2009
    My dishwasher is a Whirlpool Quiet partner II. We bought it because our other one wouldn't clean the top rack. This is rediculous . My new one ( only had it a couple of years) has the same problem and now some of the bottom rack doesn't get clean either! This started soon after we got it.
Sounds like the jets are cloged you can try a small wire to try and unglog the jets that or you water does not have enoph pressuer hope this helps
Posted on Feb 12, 2009
My Whirlpool Quiet Partner II does not clean the upper rack of dishes properly. They are greasy. I have checked the top spray arm for blockages. There were none. I am fairly certain that water is
Make sure the center loading is not obstructing the water jet to the top shelf. Top shelf is only for glasses and saucers , use Jet-Dry .Pre rinse and clean bottom pan strainer from dirt debris.
May 14, 2012 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool DU1055XTSS Quiet Partner 1 is not cleaning top rack
the sprayer is clogged with ****. I had the exact same problem. my mother-in-law gave me of some 80 year old man that has fixed appliances all his life. Ten minuets after he got to the house it was fixed. cost $70.00. He just took a couple things apart dumped out the **** inside the parts and put it back together. Hope this helps.
Jun 02, 2010 | Whirlpool 24 in. DU1055XTPS Stainless...
Whirlpool du1055xtsq 3 not cleaning top rack of
In my experience, you probably have a clog in the spray arm/arms for the top rack. Take the arm(s) out and see if the holes in them are clogged. Rice, plastic wrappers, and glass from dishes that broke in there are the most common culprits I've seen.
Nov 25, 2009 | Whirlpool Dishwashers
Dishwasher acts up
sounds like you have a bad chopper. put a cup upright on the top rack. turn the dishwasher on let it wash for about 2 minutes. open the door and see if the cup has water in it. let me know. what brand is this?
Jun 15, 2009 | Dishwashers
Whirlpool quietpartner I Dishwasher wont clean anymore.
you need to take the blades that spin out and clean them off they have grime on them, is there water still in the bottom of the dishwasher when done> if so there is a plastic grate in the bottom rear of the dishwasher you need a 1/4 inch nut driver take the cover off and clean the debris out, there is a small stainless steele cutting blade in there be careful, it is to cut up foods that might not be washed off before putting dishes in the washer, also it is pressure that makes the detergent door open make sure you are getting full pressure comming into the waher, if non of this works the pump should be replace or it;s new dishwasher time
May 30, 2009 | Dishwashers
Whirlpool dishwasher quietpartner 2-soap residue
check that the sump screens are clear in the tank,also check that the wash arm holes arent obstructed.
Dec 30, 2007 | Dishwashers
Whirlpool GU2400XTP Built-in Dishwasher Logo
1,009 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
