Question about Homelite ZR10926 16 Chain Saw
Wire is on the botom of the motor and i dont konw what is is
I bought this homelite super 2 chainsaw for a guy and it didnt run, i cleaned the carb and bought a new chain and put it all back togather, saw runs great, the cutoff switch doesnt work and it seems to be hooked up right, but i seen a wire on the bottom of block that is neer the clutch that is cut off, i was wondering what that wire is for?
  • 211 Answers
Remove the fan housing.There you can see the coil.Follow those wires(2) towards the on/off switch.Replace that wire with a new one and start the engine.
best regards savumihai71
Posted on Feb 12, 2009
How do I set idle on my homelite super2 chainsaw
Homelite XL 2 Automatic Chainsaw - YouTube
? 6:12
Apr 20, 2012 - Uploaded by Alec Ulm's Busted Knuckles
Homelite XL 2 Automatic Chainsaw ... free to shoot me a question or comment and I'll do my best to answer as accurately as I can . ... Homelite SUPER 2 Chainsaw OILER REPAIR & TEST RUN - Duration: ... HOW TO ADJUST A Homelite Carburetor - Duration: 5:01. by smallenginemaster1 177,482 views.
How to Adjust the Carburetor on a Homelite Super VI Chain ... > Construction & Remodeling > Siding
Homelite Super VI chain saws are equipped with a Walbro HDC diaphragm, and ...Adjust the idle mixture screw and idle speed screws clockwise one-quarter turn at a ...Homelite Super 2 Chain Saw Oil Type · How to Replace a Carburetor on a .... MyRidevisit'Cars-My Ride'navigation-www'4 · Sell Your Carvisit'Cars-Sell ...
Need carb settings for Homelite chainsaw - My Tracto
Jan 03, 2016 | Homelite Garden
I have a old homelite that won't start new plug fresh gas no spark
Most of the time on older engines, the carb needs to be rebuilt or replaced. Dont panic rebuilding is cheap an easy. The ports get clogged up sitting an varnish up. Try to clean out all orifices with small pieces of wire from steel or brass brush. Use carb cleaner to clean replace all gaskets an parts with kit. Dont forget to check fuel hose in tank they go bad often an should be replaced when carb work is done. Fresh gas an it should work
Mar 11, 2014 | Homelite Garden
I have an older homelite super ez chainsaw with a carburator problem. What is the proper adjustment for th two setting screws on the sie of the unit? I believe one is high speed adjustment and one is...
In side linkage plate thers a screen may b clogged, check this before adjusting carb. if carb needs ajusting turn in but dont over turn, back out 1/4 turn at first but no more than 1/2 turn.
Sep 01, 2011 | Homelite Garden
Chainsaw dont run right
carb adjustment,hi circuit,bring it to max rpms then richen hi idle side til saw loses a small amount of rpm.This and a tad richer mix ratio will ensure a longer saw life.Use itasca as a chain oiler,never motor oil.
Jan 11, 2010 | Homelite ZR10926 16 Chain Saw
Carb settings for my Chainsaw
most all of them are 1 1/2 turns out from bottmed out which must be done gently to avoid bending the needle tip
Aug 13, 2009 | Garden
My homelite super 2 chainsaw keeps flooding. it was running fine and all of a sudden its flooding. any help is welcome
Needle valve in carb. maybe hung open. Or diaphragm may be bad. You will need to remove carb. and clean and replace all worn parts. Go to to find manual for the saw.
Apr 15, 2009 | Homelite ZR10926 16 Chain Saw
Homelite 16'' chain saw runs rough and backfires
One of two things is wrong. This saw is so old I doubt it has electronic ignition. Pull the flywheel off and clean the points with carb cleaner and sand the contacts very, very lightly with super fine sandpaper or a little file. Second option, the coil is bad, take it to the shop and they should be able to test it for you.
Mar 15, 2009 | Garden
Homelite ZR10926 16 Chain Saw Logo
137 people viewed this question
Top Homelite Garden Experts
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
