Question about Whirlpool GB9SHKXL Bottom Freezer Refrigerator
Freezer not freezing food and fridge not staying cold enough
I have a whirlpool fridge with a bottom freezer. The freezer is not freezing the food and the fridge is not keeping the food cold enough.
  • 4 more comments
  • info876 Feb 12, 2009
    Thank you for your reply. My freezer is actually making ice but seems to be frosting up on the inside and not keeping the actual food completely frozen - my husband just took the back off the fridge and there is ice everywhere .... ???????
  • Anonymous Mar 12, 2014
    Freezer compartment is keeping food forzen but the ice tray if not freezing and the I can the fan at the top is not operating. Can I restart it by changing anything or do I need to replace any components and/or get an engineer to do it?
  • Anonymous Mar 21, 2014
    freezer works, bottom is not cold,food spoiling
  • Anonymous Mar 24, 2014
    freezer not working
  • Anonymous Mar 29, 2014
    freezer not keeping icecream hard
    President:
  • 1,902 Answers
Check the compressor with a volt meter, if the compressor is getting proper voltage then check the relay. But this sounds like a problem with the compressor
Posted on Feb 12, 2009
  • Jeremy Reddick
    Jeremy Reddick Feb 12, 2009
    then what is happening is your thermostat has gone bad. Which is causing you to lock up and freeze in the back. What you need to do is to take the food out and try to put it somewhere else and let the system thaw out. Change the thermostat and turn it back on. Once that is done then check to make sure that the fans are working. If the fans are bad then the ice will build up. But the fans will not come on if the thermostats are bad.
    Please rate if I have helped you. Thank you and feel free to ask me anything
Try cleaning the condenser coils and see if that helps.
A little more information on the process in the link below.
May 11, 2015 | Whirlpool Refrigerators
Tip
Whirlpool Fridge
I am having trouble with my Whirlpool Fridge single door fridge. The top freezer is getting too cold and freezing the food too much and the bottom of the fridge is not cold enough, changing the settings on the fridge only makes it worse.
I have just recently chenged the fan, so what could be the proplem and how can I fix it.
on Feb 11, 2008 | Whirlpool ER6AHKXPQ Top Freezer...
Why is my refrigerator is too cold food freezing ?
the door between the freezer and fridge that allows cold air to flow from the freezer to the fridge is likely stuck open,,,
Aug 30, 2014 | Whirlpool Refrigerators
Whirlpool ed22pq refrigerator
It needs repair, better contact whirlpool service center to fix it.
Feb 01, 2014 | Refrigerators
I have a hotpoint freezer fza34 The red high temp
it could be that your fridge,freezer setting is not turned up high enough to keep the freezer cold enough.turn it up to setting number 5 at least and if that dont do it u could have a faulty thermostat.have it checked by a engineer.
Oct 30, 2013 | Freezers
Whirlpool 6wmv43ns/02 Fridge Too Cold & Freezing Food
I would first try replacing the control in the fridge. If that doesn't remedy the situation, I would try replacing the thermostat next.
May 14, 2012 | Whirlpool Refrigerators
The fresh food compartment on my PLHS267za fridge is freezing. Have tried turning the temp all the way down and it is still freezing. What could the problem be?
damper stuck open by the fresh food thermostat. the unit doesnt know that it is cold enough so the damper stays open letting cold air from the freezer to continue to travle over.
Oct 19, 2010 | Frigidaire PLHS267ZA Side by Side...
Coil is freezing up
two options...one drain hole blocked in freezer,clean with copper wire/bleach to clear gunge.
two outside temp too cold i.e. unit in garage/outhouse( too cold for compressor )
also check seal to doors.air leaks...
Feb 06, 2010 | Whirlpool GB9SHDXPS Stainless Steel Bottom...
We have a whirlpool freezer on top but the bottom of the fridge is freezing
Set both freezer and fresh food controls to their mid position.
If after 24 hours the temp is still too cold replace the thermostat aka cold control.
Feb 21, 2009 | Whirlpool ED2FHEXN Side by Side...
Whirlpool GB9SHKXL Bottom Freezer Refrigerator Logo
1,299 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
