Question about Samsung LN32A330 32 in. LCD TV
Our Samsung 32" flat screen will not turn on
We have tried power connection, batteries in remote, turn on on set.... No luck. THis has been going on for the past few days, It won't turn on and after about 20 to 30 minutes of trying it finally tunrs on. The TV is less that 6 months old.
  • 98 Answers
Need to get service for main board replacing.
Posted on Feb 12, 2009
The red light on my t.v. is flashing but my t.v. wont come on
I would try unplugging everything, then plug back in. Try new batteries in remote if there is one. This sounds like TV is not getting signal to turn on, so I would look carefully at remote power and 'eye' and power button connections. Good luck!
Aug 13, 2012 | Akai LCT3285TA 32 in. LCD Television
I have a new 32" flat screen Samsung TV. I want
Hi:
This is very trick to answer some manufactures make all there remotes to work all their different brands, I suggest you take the remote to the 32" with you before purchasing the 19" to make sure they work. This is not always the case that your remote will on the other set.
Jan 23, 2011 | Samsung TV Remote Control
My samsung 32'' lcd tv
poke it open, you'll find bloated capacitors at power supply board. biggest one, with power cord pluged into. replace with thesame value(s).
you good to go!
don't lie, next time! your set has been acting up fpr a while, before it quit. Remembering: few attempts to turn it on, then it works!
good luck.
Apr 04, 2010 | Samsung LE32R41BD 32 in. HD-Ready LCD...
32" flat screen does not turn on.
then if you have power at the outlet,could be fuse or flyback,
Feb 14, 2010 | Samsung LE32R41BD 32 in. HD-Ready LCD...
My dynex remote control for 32 inch flat screen stopped working, tried new batteries-no fix, any help? Can I use another or do I have to contact the company for a new remote?
I just called Dynex because I had the same problem. Remove the batteries and press the power button and hold it down for 15-20 seconds, put the batteries back in and try to power on and power off, change channels, etc... if so the remote is fine. The guy told me that sometimes when you need to replace the batteries you also have to re-set the remote control.
Jan 09, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
32" Samsung TV, No Power or Sound, power LED on, flashes 3 times
Most likely the set has lost vertical sweep or the feedback from that circuit. This will shut the set down to prevent a horizontal line from burning the face of the CRT. This will have to be looked at by a technician.
Sep 11, 2009 | Samsung LN32A330 32 in. LCD TV
No response to any button on remote or tv except power button
Press the 'Favorite' button on the remote. You may have accidentally pressed it. It locks the channel. Pressing again unlocks.
Apr 22, 2009 | iLO 3200 32 in. LCD Television
Samsung 32 inch remote control problem
I had a similar problem. Take the batteries out of the remote, press down on the number 5 for about two minutes the put the batteries back in. This worked for me.
(I got this tip from a telesales advisor. I was close to buying a replacement remote but this tip worked. Hope it does for you. I'm not sure on the science part of it but it basically resets the remote. Good luck)
Jan 10, 2009 | Samsung LN-R328W 32 in. HD-Ready LCD...
Sky remote tune to samsung
1. Press tv on your Sky remote control.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
3. Press tv again
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Samsung Code: 0060
4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
Aug 13, 2008 | Samsung WS32Z308P 32" TV
Remote control
There could be a cable that is not completely seated inside the set, there may be a software upgrade also that will fix it.
Oct 24, 2006 | Samsung LN-R328W 32 in. HD-Ready LCD...
Samsung LN32A330 32 in. LCD TV Logo
219 people viewed this question
Henry  Thomas
Henry Thomas
