Question about Radio Shack Pro-96 Scanner
V-scan channels missing
I have a RadioShack Pro 96 Digital Trunking scanner that works fine. My friend sent his to me and asked me to program it to pick up the Ohio Marcs channels. I followed the instructions for the pre-programmed channels and now it says that all channels are locked out and if I try to scan manually, it appears that the banks are all empty. Did I lose the pre-programmed channels? I've tried the reset buttong and nothing changes. If the channels are gone, is there anyway to get them back. I am not a scanner expert by any means.....my friend simply sent this to me because I have one and it works fine. I pick up the Ohio Marcs channels just fine. Any pointers would be greatly appreciated. Thank you
    President:
  • 1,902 Answers
Sounds like all that is happening is that the channels are locked out, you need to go through manually and unlock them. I have the same scanner and that is what I needed to do.
Posted on Feb 12, 2009
My scanner will not transmit digital trunking channels
There may have been a change in the digital transmitting system
Oct 19, 2012 | Radio Shack Pro-2096 Base Scanner
My pro 96 says all channels lkocked out
Here is a link to the users manual in PDF Since I don't know if you are locked out of one channel of locked out of a band this manual will get you back to trunking in no time.
http://support.radioshack.com/support_electronics/doc71/71778.pdf
Mar 15, 2011 | Radio Shack Pro-96 Scanner
I have moved to a new area how do I reprogram my scanner to receive local bands
The best programming instructions for your scanner are found in the owners manual which you can download and print, at no cost, here:
http://scancat.com/OnLineHelp/OEM_Radio_Owners_Manuals/RadioShack-OlderManuals/Pro-96/pro96.pdf
For a comprehensive database of active frequencies and trunking systems in your new area, and a lot of other useful scanning information, visit:
www.RadioReference.com
Bill B.
Listening in since the 60's
Dec 06, 2010 | Radio Shack Pro-96 Scanner
I have a uniden bearcat scanner and cant pick up my local police dept. I put the frequency in and still dont hear anything. I have a bc145xl 16 channel scanning radio and want to know if its compatible...
If you programmed the correct frequency, you should be getting reception. Check www.RadioReference.com to verify the frequency. Otherwise, you may be too far from the transmitter to receive signals. Try your scanner in other locations, check your antenna, and try receiving the PD on another scanner.
The MARCS - Ohio Multi-Agency Radio Communications system - is a Motorola Type II SmartZone Omnilink Trunking system that utilizes APCO-25 digital transmissions. Your BC145XL is not compatible with trunking or digital systems. In order to follow the MARCS you will need one of the following scanners:
GRE PSR-500, PSR-600
Radio Shack PRO-106, PRO-197, PRO-96, PRO-2096
Uniden BC250D, BC785D, BC296D, BC796D, BCD396T, BCD396T, BCD996T, BCD996XT, or the brand new HomePatrol-1
Bill B.
Nov 11, 2010 | Radio Communications
I'm not picking up any local police channels can I program some in? and where can I find the codes for Philadelphia?
Your PRO-82 is fairly simple to program, and you can find detailed instructions in the factory manual which you can download and print, at no cost, here:
http://support.radioshack.com/support_electronics/doc69/69887.pdf
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning information, visit:
FYI, though, many areas have upgraded to trunking systems for their law enforcement communications. If this is the case in your community, you will need to purchase a trunking scanner to listen in.
Bill B
Listening since the 60's
Sep 20, 2010 | Radio Shack Pro-82 Scanner
WHAT CHANNELS CAN YOU USE IF YOU HAVE A POLICE SCANNER 53218
Your PRO-96 has 10 banks of 50 channels, giving you access to 500 channels for conventional systems. It also has 11 banks of 500 channels, giving you access to 5500 users on trunked systems. Detailed instructions for programming the scanner are contained in the factory operating instructions, which you can download and print at no cost here:
For a comprehensive database of active frequencies and trunking systems in your area, and a lot of other useful scanning information, visit:
Bill B
Aug 04, 2010 | Radio Shack Pro-96 Scanner
How do I program it for triple truncking?
There is no such thing as "dual trunking" or "triple trunking." Such terms are used by manufacturers to indicate the number of trunking systems that a scanner is capable of monitoring. The PRO-95 is designated as a Dual Trunk-Tracking scanner because it is capable of monitoring both Motorola and EDACS systems. Programming a trunking system in to a scanner is a detailed process that requires a bit of research.
For details on active trunking systems in your area, and a lot of other useful scanning information, visit:
Once you have the system information you can follow the programming steps outlined in your scanner's operating instructions. If you don't already have the manual, you can download and print it here:
http://scancat.com/OnLineHelp/OEM_Radio_Owners_Manuals/RadioShack-OlderManuals/Pro-95/pro95.pdf
Bill B
Jul 24, 2010 | Radio Shack Pro-95 Handheld Scanner
When in the MO mode, I hear nothing. In the FM mode, I hear everything. I want just to listen to local FD. I have their codes loaded in. Just doesn't seem to scan the channels when in MO. What am I doing...
MO is for monitoring MOtorola trunking systems and will only work if you have programmed a system into your scanner. Most fire departments are using conventional, (FM) transmissions, not trunked systems - mainly so that volunteers and neighboring departments can follow the action and respond if needed. For a comprehensive database of active frequencies and systems in your area, visit:
Need the manual for your scanner? You can download and print it here:
Bill B
Feb 21, 2010 | Radio Shack Pro-96 Scanner
Need police channels for butler mo
http://www.radioreference.com/apps/db/?ctid=1485 Make note of radio reference.com......This is probably the best resource for frequencies in the United States - and it's free! It is particularly helpful with info on digital trunking and how to program your pro 96 for your specific area. Where I live in Wake County, North Carolina EVERYTHING is now trunked digitally and I found radio reference very helpful.....Happy scan ning!
Oct 17, 2009 | Radio Shack Pro-96 Scanner
RadioShack PRO-94 Scanner
is there a vista program avalib.for pro-94 pc-interface cable
Sep 19, 2007 | Radio Shack Pro-94 Scanner
Radio Shack Pro-96 Scanner Logo
236 people viewed this question
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
