Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet steam washer has no power!
There is power going though the electrical outlet, it was tested with another device. I press power on washer and it's DEAD! No power what so ever, no lights on, no delay on.... I tried everything the trouble shoot says to check and the washer completely powerless! I purchased this washer 2 weeks ago.
    President:
  • Whirlpool Master
  • 2,651 Answers
Call whirlpool, sounds as if you have a faulty electronic control board( power supply board) warranty issue, non need for you to get involved with the repairing of this
Posted on Feb 12, 2009
Can you stack this washer and dryer?
You can stack, will you be able to reach. Racks can be made to stack any normal washer and dryer.
Mar 14, 2016 | Whirlpool WFW9750WW Duet Steam Front Load...
F-35 code My washing machine Whirlpool duet steam machine keeps going into the F-35 Code and stops washing.  I don't have the book.  Please, if anyone knows what this means or how to fix it, my email is...
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump,
pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic test or any
cycle.
Sep 12, 2008 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
No power to my whirpool duet steam washer is there fuses in it
No I don't think there is any fuse and problem most likely main board problem
Dec 09, 2013 | Whirlpool Duet Steam WFW9700V Front Load...
Power will not turn on
Test the resistance of the power button you will need to remove the wires from it first hold button down put test leads on each side or button it should read 0 if not replace it.
Jul 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool WFW9600T Washer - How do I run diagnostic mode?
Actually, on my particular whirlpool steam duet model, I had to press the deep clean button four times to make it go into diagnostic mode.
Apr 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Steam Dryer Beeps 3 Times But Does Not Start
Brand new unit - same problem. After an hour of investigating, I found the issue.
You don't actually have to SLAM the door. If you look closely, there are 3 separate pins that must latch. One is a simple push-button style which latches no problem.
The others are little prongs at the top and bottom of door. The bottom prong latches cleanly, but the top one will not latch because the door is a bit too flexible.
Close the door normally, then firmly press on the top edge of the door. You will hear the final latch grab, then you press and hold the start button. The dryer starts normally.
Yay!
Nov 02, 2008 | Dryers
Whirlpool duet ht wouldn't start
remove the lower front panel,3 screws,side up and off,there is a tech sheet inside on the panel that should help you ,let me know what you find-mike
Oct 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
374 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
